Old 04-01-2020, 02:43 PM   #26
Jemezcrusher
Re: Driver's side door adjustment? Or Altman Latch adjustment
Originally Posted by Chris(NJ) View Post
I would think cutting 1/8" off the bottom of that plate would be tough. Harder than drilling a hole, at least lol. I tried getting a response from them on IG about some strike plate ideas but it fell on deaf ears
Still working on this too. I did grind off a bit on the plate but looking at my doors, it looks as if the whole door could come up a bit as the belt Lin’s dont match the front or back. Problem is that the door is perfect on the bottom where it meets the cab. Guess I can sacrifice that perfect fit to try to get a better beltline fit and latches that work
Jemezcrusher is offline   Reply With Quote
Old 04-08-2020, 09:32 AM   #27
Chris(NJ)
One last pic to finish this off. Tied up the passenger side. Painted. All back together. Officially checking this off the list .....
Chris(NJ) is offline   Reply With Quote
Old 04-08-2020, 10:12 AM   #28
Tempest67
Tempest67's Avatar
Looks really good, nice job..... love your interior
I don't see any screw heads on your door panel, how is it attached?
Tempest67 is offline   Reply With Quote
Old 04-08-2020, 09:01 PM   #29
Chris(NJ)
Thanks! it's installed w/ push pins. In the first pic you can see some holes drilled in the door. The material on the panel covers the head of the push pin. Kinda like these.....
https://www.summitracing.com/parts/r...-757?rrec=true
Old 04-09-2020, 10:37 AM   #30
Tempest67
Tempest67's Avatar
Nice, similar to the pins the factory uses in newer vehicles.
I will think about that when I make my door panels, Thanks.
.......your truck looks great
Old 04-09-2020, 01:26 PM   #31
Chris(NJ)
Exactly!
