08-08-2020, 11:41 PM | #26 | |
Re: LS swap coolant temps
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! Last edited by First c10; 08-09-2020 at 11:07 AM. |
08-09-2020, 07:40 AM | #27 |
Perfect. Thanks!
08-12-2020, 10:00 PM | #28 |
Roto Reuter thats the name...
Now that my K10 5.3L truck is up and running I'm finding out that my truck runs between 200-205 deg-F. This seems normal from what I've read. I have dual Spal fans and heard the same as MD Potter, so my fans run independently of one another at full speed. I'm not sure what the fan set points were set to, but I believe the first one comes on around 200. I'll have to watch it closer since I just got it going. Second fan has never turned on.
I haven't charged the AC system yet, and I never wired in the resistor and diode. I'm charging the AC this weekend and plan to try it out first to see if my MIL comes on.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
09-06-2020, 01:08 PM | #29 |
Radiator is back in with the 3 relay mod. Took it for a test drive this morning and stopped to let it idle up to the first set point temperature (185) and nothing happened. Uh-oh, thought I was going to have to pull everything apart to figure out what went wrong with the wiring. Drove the short distance home, popped the hood, and both fans were actually running! With both fans running at half speed, you couldn't even hear them. Once it hit the second set point (205) both fans kicked into high gear and sounded like a jet engine. Overall, very please with the mod.
