08-02-2020, 09:14 AM | #26 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 396 experts need help
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 08-02-2020 at 09:33 AM. |
08-15-2020, 01:11 PM | #27 |
Well turn out I had a mess. I took things apart again and wonder if this was the case the first time and I just did not notice it ....... 5 Broken valves springs. Broken on the outter spring so the valves were still closing. Also noticed the Valve guides were too loose. I bought these heads ready to go from someone on ebay. They were beautifully cleaned and had all new hardware. Crappy job ! So I am getting new guides and cleaning them up again and getting the correct springs for MTC6 Melling Camshaft. I am thinking they were not the right springs. I should have looked closer but I have never had a broken spring in all my years of automotive since 1992. I have probably worked on 30 different engines of various types LOL. Oh also the valves were all Snow white on the bottom. Lean condition........
Mike |
08-15-2020, 02:26 PM | #28 | |
10-24-2020, 11:57 AM | #29 |
Got it all back together with the correct valve springs and sleeved valve guides so everything is tight. Not getting enough oil to driver side valve train. It chatters . Oil pressure is 50 psi cold at idle. I just realized something......... The HEI distributors I have been using do not have the 3rd ring up high on the shaft like the original points type distributor I had. Could this be letting oil out of the galley ??
10-24-2020, 06:13 PM | #30 |
Moderator
Please post a pic of the shaft where you believe ye 3rd O ring is located....
The lower section of the distributor body is a slip fit into the bore above the cam. As the engine heats up, the aluminum body of the distributor expands, closing up the clearances. Question...when you rebuilt the engine...did you drill small holes in the plugs that go into the front of the oil galleries? The holes, one in center of each plug, are 1/16" usually...to allow trapped air out of the galleries....air lock is a common issue with BBC engines....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-29-2020, 08:42 PM | #31 |
I would put a cam in it. You will be on lifter set number 3. The cam stands little chance of survival. The new cam and new lifters need to be broke in together. You cant mix the order if you take the lifters out for some reason. In 45 years I have not seen good results with a used cam and new lifters. After you head experience I would review your entire build.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
