Old 08-26-2020, 07:47 AM   #26
Dleslie212
Re: Contact pattern
Originally Posted by kwmech View Post
I'd say that's a keeper. Little tight on the back lash, but it will loosen up a little after everything breaks in. Do you have decent bearing preload on the carrier?
I have to tap the shims in to get them to slide in. As long as there's no side to side play on the carrier, all good?
Also, I’m hoping to get the crush sleeve eliminator dialed in tonight. I know I need around 20 inch pounds of rotational force on the pinion with carrier removed, but do you know at what torque the pinion nut should be before I check rotational force on the pinion?
Dleslie212 is offline   Reply With Quote
Old 08-26-2020, 12:44 PM   #27
kwmech
Re: Contact pattern
With the crush eliminator, tighten it down without torque or get a different nut to use so the locking nut is not abused. Once the shims are tight torqueing down to specs should not change rotational drag. Personally I use a different nut and snap it down with my impact for set up.
Old 08-26-2020, 12:46 PM   #28
kwmech
Re: Contact pattern
Shim pack should be tighter so the carrier bearings have preload also. Packs can be held on the sides with a light coat of grease. Carrier can then be tapped in with either a rubber or plastic mallet
Old 08-26-2020, 12:48 PM   #29
Dleslie212
Re: Contact pattern
Thanks for the advice. I'm going to get the crush sleeve eliminator set up and maybe final install of pinion tonight. I'll update after that
Old 05-05-2024, 11:56 AM   #30
Dleslie212
Re: Contact pattern
This was 4 years ago lol.
Anyway, my diff cover has been leaking oil a bit so I pulled it off to replace it. The oil was pretty sparkly - more than I would have anticipated. Granted, I don't think I've even put 500 miles on this rear end in four years. Probably closer to 250, so I don't even think it's all the way broken in yet. But there was alot of sparkly. Is this to be expected?
Old 05-06-2024, 11:14 AM   #31
kwmech
Re: Contact pattern
Somewhat, how did the final pattern come out? any unusual noises?
Old 05-06-2024, 11:16 AM   #32
Dleslie212
Re: Contact pattern
If you look back in this thread, there's some pics of my final pattern. No noises, everything has been great other than the leaking diff cover gasket, and the higher than expected amount of shavings
