Old 10-15-2020, 09:30 PM   #26
SatinSeventy2
Re: What should I do with this truck
I would lower it as you stated. If you go with torq thrust, a slight rake looks ok. But, if you go with hub caps, I would get it level. Now for my preference, I would go with 17" wheel vintiques with the caps, white walls and beauty rings.
SatinSeventy2 is offline   Reply With Quote
Old 10-25-2020, 11:27 AM   #27
raylube
raylube's Avatar
What did you decide to do? Maybe you could talk to your local film commission and it can be used for period correct films/TV or in advertising,or wedding or other photo shoots as long as it's not damaged. That could be fun for you and your family.
raylube is offline   Reply With Quote
Old 10-26-2020, 10:16 AM   #28
LT1 Burb
LT1 Burb's Avatar
Shoved it in the back garage, am doing a frame off build on an early Bronco with a coyote conversion, so at least it will keep me busy.
LT1 Burb is offline   Reply With Quote
