05-18-2021, 07:11 AM | #1 |
Moderator
Re: Quick question on fitment - power steering gear
Yes pressure port nearest the frame.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-18-2021 at 07:18 AM. |
05-18-2021, 01:08 PM | #2 |
Moderator
Yep that's inverted flare. In my notes I have me using: Pressure - Edelmann 70917. I made the return line.
But I have a small block chevy, short water pump brackets.
05-18-2021, 02:08 PM | #3 | |
How did you make the return hose? Would I need an inverted flare tool?
1963 C20, small window, long bed 292, 4-speed |
05-18-2021, 02:17 PM | #4 |
Moderator
You know I think I found the "pig tail" from the box end from inline tube. It didnt fit very well so I had to adjust the bends, so much so I creased the tube. So I had extra 3/8 tube around and made my own. If I had to do it over again I'd use copper nickel. Yes you have to have a crimper. I have a hydraulic unit I purchased on a previous build, love it. My hose section (from my notes) is Edelman 71236.
05-18-2021, 02:18 PM | #5 | |
05-18-2021, 02:22 PM | #6 | |
05-18-2021, 02:22 PM | #7 |
Moderator
Yes I was discussing the return hose.
LMC shows the pig tail section item #6 here: https://www.lmctruck.com/1967-72-che...ing-components
05-18-2021, 02:54 PM | #8 |
Moderator
Can't seem to find any right now.
05-18-2021, 03:44 PM | #9 |
So, if my 3/8 tube fitting is 0.61" (OD), would this be a 7/16 fitting?
And, the tube in the pic is not called an inverted flare, is it?
05-18-2021, 03:48 PM | #10 |
Moderator
Throw that away, its not for your box.
The picture in your post 26 is the type if fitting.
05-18-2021, 04:04 PM | #11 |
this one--goggle power steering return line fittings----------
one part# edelman 39135
1961 chevy K10 my build is------------61K10 build |
05-18-2021, 04:46 PM | #12 | ||
Just ordered this one.
05-18-2021, 04:58 PM | #13 |
Moderator
A 3/8 Tube flare nut (if your going to make your own) is 5/8-18 threads - 1st pic.
The screwed up tube I made - 2nd pic.
05-21-2021, 03:06 AM | #14 |
Well, for the bracket and power steering pump installed; just gotta get a belt that will fit.
Hoses seem to fit well too.
