Old 06-02-2021, 11:37 AM   #26
Dexterb
Re: Suburban lowering question
Originally Posted by BlueJeep View Post
Here's 4/6 drop, details are all in the build thread:
And the notch will get you axle clearance, but before the axle hits the frame or the diff hits the floor the tires will rub on the tops of the wheelhouses. That was NOT something I factored in...
Good looking burb BlueJeep!
Do the tires rub at the top of the fender tub or is it in thr back portion? Are your rear tires centered within the wheel tubs after the flip kit? From what I can see it looks like with stock tires there should be about 10' of room from top of tire to top of wheel tub but approx 8" at the rear where the tub shapes down.
Dexterb is offline   Reply With Quote
Old 06-07-2021, 04:58 PM   #27
BlueJeep
BlueJeep's Avatar
Thanks! Top of the fender tub. Yes, tires are centered, see my build thread for details on that. I welded perches on and drilled the pin hole to my specs.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 06-13-2021, 11:11 AM   #28
Dexterb
Thanks for the info.
Do you know how much room is left between the axle tube and notch when the tires are up against the fender tub? I'm just curious how much lower you could be with a smaller tire since i'm planning an air over leaf set up in the back of my burb.
Looking forward to seeing your LS swap completed!
Cheers,
Dexter
