#26 |
low n' slo
![]() Join Date: Mar 2009
Re: Easy way to remove motor and trans from donor?
figured I'd post in this thread since I had a few people checking in.....huge disappointment tonight
figured I would drain the oil before pulling the trans off.....
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#27 |
low n' slo
drive side valve cover
#28 |
You would have to cut both ends of the TAC wiring harness to get it out of a 2001. The easier solution is to get a harness out of a 2003 truck since they're a separate harness. Otherwise, just splice the wires back together to fit your application.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#29 |
This is why I always pull a valve cover before buying an engine. Did you drive this truck?
#30 |
Post Whore
![]() ![]() Join Date: May 2015
oh man..!!!!...that sure sucks..!!!!!
#31 | |
low n' slo
no smoke either and it sounded pretty good imo.
#32 |
What a bummer. Was the truck in a flood? That's a lot of water. I suspect it can be saved but it will need to be a complete tear down and rebuild. Need to check for cracks in the cylinders and heads. I would pull the pan on the trans.
Still a bummer but you can build it back better. Lots of used stuff over on LS1tech.com. I had something similar happen to me. Bought a "low mileage" (40,000) LS1 engine and 4L60E trans many years ago. Pulled the pan and front cover to just check stuff. Shiny chunks in the pan and a very loose timing chain. Took it to engine shop and it wasn't pretty. More like 240,000 miles. Put in good rods and pistons. New bearings. Small cam. The block and heads were sound. Heads got a slight port job along with a valve job. Its been in my 98 Wrangler for 13 years. It runs great. |
#33 | |
low n' slo
I'm going pull the heads tomorrow and see what I can find. guess it's hard to tell with out the heads pulled and oil pan off. I'm hoping it's just a blown head gasket.
#34 |
I have down this road just recently. Engine in my donor ran good when I test drove it. Drained oil and globs came out...uh oh, coolant and oil mix...probably means cracked cylinder head. Pull valve cover and man was it dirty with baked oil. Pulled heads and they passed pressure test. Cleaned engine best I could, replaced oil pump, resealed entire engine.
After my LS swap was complete, the engine started right up and sounded great, but it immediately left a puddle of oil under the rear main...damn, I messed that seal up. new seal and same results...turned out the crank was moving radially due to worn out main bearing. So, I bailed and bought an engine from a salvage yard. Used my boroscope to look inside the engine to ensure spotlessly clean. 2nd engine is great! So, maybe don't waste your time on the engine you have and get a better one. I got my 5.3L from the salvage yard for $425. |
#35 | |
low n' slo
#36 |
Post Whore
![]() Join Date: Aug 2014
I recall years ago I went to Pick N Pull by myself to pull my first engine, I was planning to call my buddies to come help me later on, I got there and picked a Tahoe in the middle of 5 fresh new cars, two on one side and two on the other, the time was 9 am
a crew of 3 guys showed up next to me, they knew what they were doing, by 11 am I had everything loosened up ready for extraction, meanwhile these guys were yanking their fourth motor and transmission combo, no joke, no lie this is how they did it, one guy went from the top in the engine bay and cut all the belts and hoses and disconnected the wiring harness the second guy went under the trucks and disconnected the driveshaft and the transmission crossmember etc, the third had a saws all and literally cut the front subframe off the trucks on either side and the whole front clip came crashing forward, and then they hoisted the engines out of the carcasses, in California they cut out the catalytic converters so the exhaust was already taken care of and cut off |
#37 | |
low n' slo
#38 |
They have been sawing the frames around here for a long time. Occasionally they saw the fenders and all....😬
#39 |
low n' slo
#40 |
I pulled motor only from a 4x4 Yukon. I ended up cutting the tunnel in order to get at the bell housing bolts.
#41 |
The wires from the tac to the pedal are impossible to remove in one piece (from an '08 at least). Get as much wire as you can and cut it. It can be lengthened and rejoined.
