11-05-2021, 11:48 PM | #26 |
Re: Break Man
The Pressure Differential Warning Switch, Piston centering tool is a tool I have never owned or even given any thought about doing so.
If I ever push the piston to one side and the lamp turns ON, I simply crack a bleeder on the other side and push the switch piston back with the brake pedal. I would suggest not using the plastic version of that tool. I was watching that RoadKill Garage with David Freiburger and Steve Dulcich. Hay, I have to get my laughs somewhere. They were attempting to bleed the brakes on one of their junk mobiles and snapped the nipple off of a plastic version of that tool. They were able to get it out without too much trouble. Kids!!!
'67 GMC 2500, 292, 4spd, AC |
11-06-2021, 07:49 AM | #27 |
Re: Break Man
Love road kill and all of there troubles.
11-07-2021, 09:37 PM | #28 |
Re: Break Man
Hey Everyone,
First off I want to thank you for the feedback. Well I believe I have figured out the mystery. ACCELO, thanks for the advice on shortening the bolt in the master cylinder, that seemed to help some. I noticed that when I pulled the hose off of the caliper, there never seemed to be any fluid coming out out the Banjo Bolt, but I would get fluid out of the hose. I replaced the Banjo bolt and the problem went away. I think it was a couple of small problems causing one big one. But the good news the passenger side is releasing now, I'm not going to question why and I am backing away slowing. But again I wanted to thank everyone for your input and suggestions. |
11-08-2021, 04:59 PM | #29 |
Mr. Cheyenne
Re: Break Man
its good to see you got it sorted and that you replied that you did and listed the things you think were the problem!
happy truck'n (and stop'n)!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
