02-10-2022, 06:10 PM | #26 | |
Re: New Qjet carb - Starts, then dies
The spring tension is adjustable. In your case, the spring needs to have a looser setting.. The setting is done with absolutely no heat in the engine. With the engine stone cold, having sat overnight, loosen those 3 retaining screws. It's not necessary to remove them, just loosen them a turn or two. Prop the throttle open to release tension on the fast idle mechanism. Rotate the black cover in the direction that causes the choke blade to open. Rotate it until the choke is fully open. Rotate the cover back the other direction until the choke fully closes. Rotate the cover another 1/8". Hold it in position and tighten the screws. If all other adjustments are correct, the choke should be fully open after about 3 - 5 minutes of run time, depending on outside air temperature. If the choke opens too fast, turn the cover another 1/8". After initial adjustment of the spring, any additional adjustments should be very small amounts. For fast idle speed adjustments, refer to my previous posts on this thread for those settings. |
02-10-2022, 07:59 PM | #27 |
Good post Rusty, but he has a divorced choke.
Could you explain how to set one up for leaner or richer settings. |
02-10-2022, 08:30 PM | #28 | |
First, the heat riser passage in the intake manifold and heads must be clean and clear. The heat riser valve must be fully operational. With mileage accumulation, this passage often becomes clogged with carbon buildup. This inhibits the transfer of heat into the choke stove. Here's the adjustment procedure. Move choke rod in coil to end of its travel. Top of the choke rod should be even with the bottom of the hole it goes in. Bend rod in middle to adjust to top of rod even with bottom of hole, rod should be against the travel stop. This does not adjust the tension that controls opening speed, it adjusts closing tension. If done properly and the choke still opens too slowly, the bi-metal spring is going bad. Replace it. Last edited by RustyPile; 02-10-2022 at 08:36 PM. |
02-10-2022, 08:44 PM | #29 |
I couldn’t get my divorce chock to release quickly enough, so I got rid of it with an LS swap…no more choke issue. Worth it!
02-10-2022, 08:48 PM | #30 |
He has another thread about the high idle on his carb.
I found this. Has a diagram of what you described. To cure his problem likely he just needs to make his rod slightly longer. Lots of times the coil isn’t worn out. A new one might do the same. The crossover passage can get plugged too. I always had two rods available. One for summer, one for winter. Made from old wire coat hangers. https://forums.aaca.org/topic/355944...966-chevy-396/ |
02-10-2022, 09:54 PM | #31 | |
Who Changed This?
02-10-2022, 10:20 PM | #32 | |
I had to sneak them outta the house! Stashed them with the turkey baster that I ‘borrowed’ too! |
02-11-2022, 01:26 PM | #33 |
Mr. Cheyenne
I replaced my Divorced Choke with an electronic one. It is still a Divorced Choke and sits in the same place on the intake. Then it has a little sensor mounted on the intake and the power is spliced from the anti dieseling solenoid's power.
Bending choke rod = no fun. I could hardly figure out how to adjusted it correctly with simply twisting it left/right Ha!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
02-11-2022, 03:42 PM | #34 | |
I finally got a chance to get out in the garage and start working on the truck again today. I did exactly as instructed, and my truck fired right up and ran beautifully! Never stalled or hesitated at all. Thank you so much for this info, you helped me get my truck up and running great again. One other thing that I checked was the torque on the carb mounting bolts and they were all a little bit loose. Note to Richard- no worries at all I am glad that this thread also helped you get your truck running great as well. Thanks to those who suggested a different choke setting for summer vs. winter, I will definitely keep that in mind and I may have to re-adjust come summer time. But I am very happy to know how to do that now! Thanks again to everyone who replied to help me get this issue sorted out!
'68 Chevy K20 '72 Chevy K20 - Smokin' Ochre '08 Mercury Grand Marquis - Daily driver/ Parts fetcher Ohh uh, I didn't have time to fix everything... |
02-11-2022, 03:49 PM | #35 |
So in the summer, I will re-adjust my choke as needed.
When driving my truck around in the summer, will I also have to re-adjust the choke pull off? as in re-bend the linkage for summer operation? Or will the current setting be Ok for summer driving as well? Thanks
02-11-2022, 04:25 PM | #36 | |||
Mr. Cheyenne
02-11-2022, 04:40 PM | #37 | |
Now to answer your question on the choke pull. Once you have it adjusted you shouldn't have to adjust it for warmer weather. Some engines are more "cold natured" than others and may require a different setting on the choke spring for extremely cold temperatures vs. hot weather. The choke pull setting should work year 'round for you. I'd suggest you wait until summer (or warmer weather) shows up and see how the choke works for you. If the engine seems to run on the fast idle cam to long, mark the position of the choke housing and loosen those 3 screws. "Unwind" the choke spring. Do this in very small increments, about 1/8" at a time. I'm guessing you won't have to do any summer - winter changing. |
02-11-2022, 04:50 PM | #38 | |
Problem is your season changes aren’t always consistent. The transition times from summer to fall and then winter and spring to summer will vary. You just need to wait and see how your motor reacts. I’ve found I needed a lot of patience to wait as long as possible before I changed Settings. I spent the first 55 years living in 40 below country. Mostly in Alberta where I’ve seen temperature swings of 40 below to zero and back to 40 below in but 6 hours. My ultimate cure was using a manual choke on any carb. Always worked the same way year round. |
02-12-2022, 11:26 AM | #39 | |
02-12-2022, 11:33 AM | #40 |
Thanks guys for the advice about adjusting the choke. I will see how the truck runs in the summer and reference this thread again if I do need to make some adjustments. Most of the driving I will do will be in the summer, but I want the truck to start reliably and consistently in cold weather as well for the few occasions where I do want to use it on freezing cold days the fall.
Thanks again for all the help and knowledge! I couldn't keep these old trucks running without all your help!
02-25-2022, 02:23 PM | #41 | |
Would it be wise to go ahead with an electric choke retrofit on this carb if I'm switching over to an aluminum intake manifold with no divorced choke provision? |
02-25-2022, 02:29 PM | #42 |
Likely the bimetallic coil is fine.
Could be your intake crossover is plugged or partly plugged. Or your heat riser is stuck or has been removed. Electric choke kit is universal. You can use on any intake. Might just need a different mount for it. |
02-25-2022, 03:25 PM | #43 | |
Cross over should be nice and clean as the manifold was cleaned and checked by the machine shop when the engine was rebuilt 8,000 miles ago. The choke system works great @ >60*F. It's when it's colder than that on start that it keeps trying to jump back in to high idle for about five minutes as I'm driving down the road. Just annoying. |
02-25-2022, 04:33 PM | #44 | |
The Older Generation
Heat riser is at the bottom of the exhaust manifold. Between the manifold and the exhaust pipe. https://www.jegs.com/i/OER+Equipment...r%20Categories LockDoc -
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-25-2022 at 04:40 PM. |
02-25-2022, 11:05 PM | #45 | |
