03-22-2022, 01:34 PM | #26 |
Re: My '71
Much better. Before, you could barely tell the roof was white.
03-22-2022, 01:37 PM | #27 |
Re: My '71
Added sound deadener EVERYWHERE! Floors, roof, sides...
03-22-2022, 01:39 PM | #28 |
Re: My '71
Covered metal door panels with vinyl.
03-22-2022, 01:43 PM | #29 |
Re: My '71
Found a set of factory headliner panels, but the rear one was in sad shape. I decided to cover them in headliner material and added a 1/2" of foam for insulation and a little more sound deadener.
03-22-2022, 01:45 PM | #30 |
Re: My '71
Also added another rear dome light.
03-22-2022, 01:47 PM | #31 |
Re: My '71
Found a set of rear cargo panels. They were white, but I dyed them black to match.
03-22-2022, 01:49 PM | #32 |
Re: My '71
I made some panels to cover the barn doors covered with the same headliner material.
03-22-2022, 01:52 PM | #33 |
Re: My '71
New Red Head quick-ratio steering gear. Dog approved.
03-22-2022, 01:55 PM | #34 |
Re: My '71
Had my gauge cluster redone and added a tach, changed the ammeter to volts, and added a vacuum gauge.
03-22-2022, 01:58 PM | #35 |
Re: My '71
Changed the 21gal. fuel tank to a 40gal.
03-22-2022, 01:59 PM | #36 |
Re: My '71
New tilt column and later model wheel.
03-22-2022, 02:02 PM | #37 |
Re: My '71
Beware the Red Bowtie!!! Yeah, yeah, I know, it's a 307...
03-22-2022, 02:05 PM | #38 |
Re: My '71
Added exhaust openings in the center crossmember. Perfect for the X-pipe I bought.
03-22-2022, 02:07 PM | #39 |
Re: My '71
Decided to go with the Flowmaster 50-series (the quietest ones to control interior drone).
03-22-2022, 02:11 PM | #40 |
Re: My '71
Forgot to add all body mounts and core support mounts were changed to Energy Suspension polyurethane. Rear sway bar.
Another thind to add was I covered the entire under carriage with a brush-on bed liner. |
03-22-2022, 02:18 PM | #41 |
Re: My '71
I still have to do both rocker panels and both front cab mounts. All panels have been purchased. This has been a long road to get this far, but it shouldn't be too much longer. I hope...
03-22-2022, 02:56 PM | #42 |
The Older Generation
Re: My '71
That thing is lookin' great! You certainly have done a lot of work to it. Keep us posted on the progress..... LockDoc -
03-22-2022, 03:17 PM | #43 |
Re: My '71
Thanks, Doc! I've been looking forward to being able to post for a long time. Looking forward to get new updates posted.
03-22-2022, 07:20 PM | #44 |
Re: My '71
Wow!
That’s a transformation. I like all the upgrades, especially the HO 307 and OD. Should be a great runner. Keep up the great work!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
03-23-2022, 01:56 AM | #45 |
Re: My '71
You’re doing an awesome job saving the old girl. Looks great. What is that gas tank from? I have a somewhat dual tank setup that gives me around 42 gallons but a single tank would be better I think.
03-23-2022, 07:39 AM | #46 |
Re: My '71
Looks like a square body Suburban tank. I have one in mine. It requires a little bit of filler tube work to make it fit.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
03-23-2022, 09:28 AM | #47 |
Post Whore
Re: My '71
Looking good. You've accomplished a lot of great work.
Did you have much of a burnt smell inside? If so what did you do to clear it out? I'm looking forward to more updates.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-23-2022, 11:08 AM | #48 |
Re: My '71
BigDav is right. The 40gal. tank is from an '88 (If I remember) Suburban ordered from LMC.
03-23-2022, 11:12 AM | #49 |
Re: My '71
I haven't noticed any smoky smell. There was actually very little interior damage. The heat from outside the firewall (fire-wall ) melted some of the fuse block, but that's it.
03-23-2022, 11:21 AM | #50 |
Re: My '71
I did add two vent tubes to the tank to make the standpipe on the inside functional. There was a little of a mis-allignment of the fill tube that's almost worked out. Still needs a little tweaking. Not bad though.
