05-02-2022, 01:07 PM | #26 |
Re: New Aftermarket Cabs
Is it EDP coated or is that epoxy primer ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-02-2022, 01:18 PM | #27 |
I’d bet 99.9% of these will be titled by sticking the vin plate from a rusty old cab onto the new cab and not telling the state.
05-02-2022, 01:53 PM | #28 |
05-02-2022, 03:35 PM | #29 |
I have noooo idea. Way above my pay grade.
But it sure doesn’t look like the EDP. Looks like a primer to me.
Please be patient. I’m a ford guy. This is my 1st Chevy. Previous cars: 1973 mustang convertible 2003 mustang Mach 1 Now building resto mod 68 C10 step |
05-02-2022, 04:02 PM | #30 | |
Friend of a friend, that owns a restoration shop has used Dynacorn before and has used bodies from them. He said the Re-pop has come a long way. but it's Dynacorn or AMD to buy from. Dynacorn is building a C10 now at their california shop. All Re-pop to showcase their work and have done a few other cars like that too that are in the showroom.
Please be patient. I’m a ford guy. This is my 1st Chevy. Previous cars: 1973 mustang convertible 2003 mustang Mach 1 Now building resto mod 68 C10 step Last edited by NJ68stepside; 05-02-2022 at 04:17 PM. |
05-02-2022, 07:45 PM | #31 |
Noticed some stuff in the video, like no seam sealer in the back cab corners, I could be wrong.
Would also be trying to figure out if they dip or spray? Thats a big one in the Salt States. Great to see your video NJ68 I was hoping someone would be doing one right now and you came through. Let us know how it goes. I just want to get to done also and as much as I love seeing something old get clean and shiny it is a s@#* ton of work to do a entire cab. Keep us posted, I am sure many are wishing to see the final outcome and all the details. |
05-02-2022, 08:58 PM | #32 |
I didn't see any seem sealer anywhere. Even the drip rail. Which is OK, I just never thought about it being just the iron and primer. Definitely need to review the old cab to make sure you seal it correctly. I can think of:
-upper and lower where the A pillar meets the roof and the firewall. -left and right inside firewall to everything: kick panels, floors, trans tunnel. -driprail -back of cab to floor - the one I'm worried about, the upper side of the lower cowl (I don't think it can be done) I'm sure there are others I am missing. |
05-02-2022, 09:24 PM | #33 |
In regards to the vin in MN they have a process for assigning vin numbers to scratch built vehicles. Couple of buddies of mine have built street rods, aftermarket bodies and frames.
They went down to DMV and the DMV had clear guide lines on how to document all parts purchased. When the cars had most of the parts in hand the DMV wanted pics. Then they assigned a vin. Come to find out the DMV was really looking for was stolen parts and the pics were to determine a value of the car to figure out the cars worth for tabs. I would do it the right way per your local DMV. If you were to sell it in the future as a buyer I would want all that paper work with the truck. |
05-03-2022, 03:22 AM | #34 |
[quote=Grumpy old man;9074170] I don't see the toe panel braces installed ,I'm not sure they are reproduced ?
the floor to firewall braces are reproduced Key parts 0849-317 and 0849-318
1972 C10 SWB 383 M22 1972 K20 454 1970 K5 1985 M1008 1986 M1008 2020 2500HD Duramax |
05-03-2022, 06:37 AM | #35 |
Wished I could afford one of these - having a hard time finding an original one that isn't rotted out along the bottom, not to mention holes punched through the roof for a CB radio antenna.
05-03-2022, 04:55 PM | #36 |
Did a better look at it.
It is Regular primer sprayed on. They did a pretty good job covering it. Even in the cowl and vents. No seam sealer. Which is a good thing. Imagine if you’re going to modify it and then have to mess around with that. Plus I’d want to further paint/preventative coat pieces before I get it to sealer and final paint. I’ll ask my body shop for direction on this stuff.
05-03-2022, 05:44 PM | #37 | |
I had to laugh when I read your cb radio comment. I think from about the mid 70s to the middle 80s, that was the thing to do. Sometimes they would clamp them the rear view mirrors or Ive even seen them clamping the antennas to the rain gutter. These things were just trucks to most folks. Parked outside, hardly ever washed off, driven in salt and cinders, left with a bed full of stuff, hardly ever re-seam sealed. If the paint wore off, who cares, you could pick up a decent longbed (67-72) in 1979 for 6-800 bucks. This new repop cab will save a lot of work for a lot of people. Im glad to see it.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
05-03-2022, 10:11 PM | #38 | |
NJ no longer does safety inspections on passenger vehicles and no emissions testing on anything pre ODBC-II (~1995). I don't think that they have ever looked at the VIN tags on anything I've had inspected, however nothing I have should have any issues that way. My '70 C10 did pass safety and emission inspection back in 2014 for two years. IIRC when it was due again in 2016 they didn't want to see the truck for either inspection anymore.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
05-04-2022, 09:07 AM | #39 | |
I would also be very concerned with the cowl area. There is actual 3 cowl pieces. You see 2 on your cab and then the body cowl. Those lower seams in the windsheild area are where I have the most problems now on a 50 year truck. |
