#26 |
Re: One piece vs two piece drive shaft
I guess now it's obvious why I try to stay away from these types of threads.
This was cutting edge technology back in 1990. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-06-2022 at 09:46 AM. |
#27 |
![]() Join Date: Mar 2015
I guess now it's obvious why I try to stay away from these types of threads. LOL
I read it to the end. Explained the dampeners I have seen on so many vehicles. Happy you got "sucked in". From a "give me the data" guy. Cheers Last edited by Accelo; 06-06-2022 at 11:21 AM. |
#28 |
I think the hardest part of the whole project was typing the formulas.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#29 |
#30 |
My buddy had a CM d/s let go at 140 and damages were brutal. broken 3rd member, ear broken off aluminum LS block where starter mounted. Since we copied his build in my truck I went C/F from QA1.
#31 | ||
![]() Quote:
There have been a couple updates since then - https://www.motortrend.com/features/...-still-family/ http://wildaboutcarsonline.com/cgi-b...=9990396621018 https://oneownercollectorcar.com/ind...-keith-seymore
#32 | |
I was just reminded of my favorite "twisted driveshaft" story.
I grew up hearing about this '67 GTO that broke the drive shaft, which proceeded to beat the floor out of the car as it tried to come inside. Denny was so disgusted that he parked the car and it sat for probably 25 years - until he restored it. So now he has an original owner '67 Ram Air GTO with about 10,000 miles on it. K Quote:
#33 |
When I was a kid we had a guy that lived down the road die, when his u joint failed by the transmission, the front of driveshaft hit the pavement then pole vaulted the truck which flipped over and killed the guy.
So if you go one piece check your u joints and add a driveshaft loop if you want to drive hard and be safe.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
#34 |
I put a LT1 and a 700r4 in my 69 C-10 all I did was shorten the front shaft 3ins. Fast cheap easy. Anyway thats my two cents worth
