08-23-2022, 11:12 AM | #26 |
Re: How low can you go ??
If I were kens65fb I would have given up on reading this thread a long time ago.
08-23-2022, 11:14 AM | #27 | |
My input was on highlighting the issue of clearances once one is curious about 'aggressive' lowering aka asking "how low can you go". Seemed related.
08-23-2022, 07:17 PM | #28 | |
I was only thinking of No Limit's front crossmember since that is what I am going with. Of course I know there is an argument to be made that if I were truly serious about autocross I'd be looking at a full chassis instead. But I have a full prep SCCA STR 2019 MX-5 and even with a full chassis, I'm not going faster at autocross in the 65. Agreed. Always learning and discussing is what improves someone's knowledge.
1965 GMC 910 Short Fleetside. 230 CI 4-speed. |
08-24-2022, 07:44 PM | #29 | |
The setup I had on Goldilocks' build (stock crossmember raised 1.5", 1" narrowed PB tubular arms, .500" taller upper ball joints, and CPP Modular drop spindles) had more camber gain per inch of travel than No Limit's WideRide front end. Depending on how much body roll you have that could be a good thing or a bad thing. I like softer/more compliant suspension that absorbs mid corner bumps and curbing so having more camber gain to add more camber as the body rolls is a good thing- you can run less static camber. Stock camber gain is .86* per inch inch of travel, No Limit is 1.56*, my setup was 1.61*. The PB arms corrected the lack of caster and the No Limit rack & pinion corrected bump steer. The factory crossmember already has about 10* of antidive built in so that's good as-is. Now, if you like stiff suspension and no body roll because everyone thinks that's what makes something handle good... you don't really need geometry anyway, just throw some static camber at it. The factory geometry with a few tweaks, plus an appropriate spring rate and good shock valving can be really good, and plenty good enough for autocross if you're not trying to be top level competitive.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
08-24-2022, 08:35 PM | #30 | |
08-25-2022, 09:12 AM | #31 | |
Obviously, this is assumed. So the discussion is all things being equal.
08-25-2022, 02:02 PM | #32 | |
But this is all off the original topic of how much lower @kens65fb can possibly go. My original concern was making sure he's aware of the pitfalls that extra inch or so of drop can yield. Driving a truck that bottoms out a lot wears on you (& the truck/parts). I loved the ride height on my '74 but the constant bottoming out made driving any area where the roads weren't smooth a PITA thus much less enjoyable. Getting them lower than a 4/6 introduces those concerns. A 5/7 is do-able w/the right combo but will likely bottom out here & there. Again.... I was merely trying to promote awareness. For reference, my CC dually is just as low as my '74 was but has adequate clearance. The 1.5" raised front x-member keeps it far enough away from the ground it's never bottomed out once it hit the roads 'post-mods'. Same for the rear of it.... It's never made contact w/the bumpstops or floor. The only thing that has made contact is the frame rails @ the center of the truck on funky angled entry/exit transitions of some parking lots. I have air so I could technically raise it but it's a coin flip on if it will/won't make contact so it isn't a common issue. Everything I have is lowered & I won't build another aggressively lowered truck w/o necessary clearance. It's night & day difference IMO when it comes to a worry free driving experience.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-25-2022 at 02:58 PM. |
08-25-2022, 03:24 PM | #33 |
I measured today.
The distance from the ground to the bottom of my front fender is 27 1/2 inches, it seems like 26 inches would look perfect I'm curious, what is considered a perfect height. Anybody else measured the distance from the ground to the bottom of the fender ?? |
08-25-2022, 03:36 PM | #34 |
Have you looked through the photos of static drops thread? I would go through there and find one you like and then ask them their specs and for how they did it.
https://67-72chevytrucks.com/vboard/...ht=static+drop |
08-25-2022, 04:10 PM | #35 |
My measurement is 27.0, but I’m running a taller tire that fills the gap more. (235/75R15)
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop. '77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed. '80 jeep CJ-5. ‘14 Chevy 1500 Z71… |
01-16-2024, 03:49 PM | #36 |
im very late to this but my 65 has 3 inch belltech spindels 3 inch coils with a half coil cut in the front 5inch coils and inch and a half blocks
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 |
01-16-2024, 03:58 PM | #37 |
01-16-2024, 04:20 PM | #38 |
2.5 inch drop spindles and 2 inch springs in front and I was told 4 inch springs in the rear. I bought all the parts used and the guy was going by memory. 255-17r15 tires on factory truck rally wheels I've never measured to see how high the frame is off the ground.
1965 C-10 1/2 ton shortbed part time daily driver 1980 C-10 1/2 ton shortbed project |
01-16-2024, 07:16 PM | #39 |
Just an opinion, but taller tires look more "correct" with our body styles....(flame suit on)
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
01-17-2024, 02:41 PM | #40 |
Another example for reference. The front never rubs or bottoms out, plenty of travel and ground/tire clearance. No issues at at. The rear needs a c notch at this height; with trimmed bump stops the axle is only about 1.75" off the frame rail so bump travel is limited. I don't want to chop up the truck so I've tolerated the rear occasionally bottoming out on the bump stop. I used firmer rear shocks to slow down bump travel when empty, but when loaded with the camper shell or trailer it actually rides really well except over really big bumps. I'm looking into adjustable shocks to dial back the damping when it's empty.
Front- CPP drop spindle/disc brake kit. 1 coil cut off stock springs. Bump stop brackets completely cut off. Stock drum brake wheels with 1.5" bolt on spacer. 215/75r15 tires. Rear- D2600 bags bolted directly to trailing arms, short upper cup to clear the air fittings. 1.5" drop blocks. FrizzleFry's method of shock relocation. Trimmed bump stops. 15x8 wheels. 235/75r15 tires.
