10-10-2022, 11:28 AM | #26 | |
Re: Upgrading Headlights
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
10-13-2022, 09:41 AM | #27 |
Post Whore
Currently I have 25 year old pair of Hella H-4's with relays installed. But I have a brand new set of the Koito H-4's in the garage that I plan on using to do a comparison test with when I install them.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-13-2022, 09:50 AM | #28 | |
+2 on the Head Light Harness. I use Sylvania Silverstar bulbs, 5500k ALL your lights will be brighter after relay install as the full volt load is taken out of the switch plug & play install. No cutting any wires. Just mount 2 relays near the battery |
10-14-2022, 04:56 PM | #29 | |
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
10-15-2022, 09:51 AM | #30 |
I have the LMC and yes the packageing says made in china....but so far it works fine
I also have one in my 67 Camaro I bought from Speedway for about the same $ a few years ago. It just came in a zip loc bag. IDK origin but assume some place in US make it. I also have had no issues with it either Time will tell if either presents issues or if a relay needs replacing |
10-17-2022, 08:23 PM | #31 |
10-17-2022, 09:36 PM | #32 | |
https://www.octanelighting.com/5-34-...sa-reviews-tab
Doug 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
10-18-2022, 04:07 AM | #33 | |
10-18-2022, 05:17 AM | #34 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
https://www.lmctruck.com/1967-72-che...stom-headlight
More my style and is my current setup. DOT, clear glass housing with replaceable bulb. I prefer regular halogen bulbs. Cheaper to replace. Easier to find. More of an OEM look. Wiring setup is required and is brighter than OEM with better light pattern. I've done the same style setup with my '87 Chevy and my Jeep. It reads "Each headlight includes a wiring adaptor to connect to the appropriate factory wiring." But I'd recommend the headlight harness. Last edited by desert-rat; 10-18-2022 at 05:26 AM. |
10-18-2022, 05:19 AM | #35 | |
10-18-2022, 05:28 AM | #36 |
10-18-2022, 05:46 AM | #37 |
Just plug into the stock harness
10-18-2022, 10:01 AM | #38 |
Does it not need a harness? The way the comments on the bottom of the links page read you need a relay wiring harness.
10-18-2022, 04:05 PM | #39 |
Mine plugs into the stock harness..
10-18-2022, 07:23 PM | #40 |
The kit I bought suggested buying the relay harness as the relays will take the amperage draw away from the switch which will keep it from failing prematurely. Which after thinking about it thats why all todays automotive suff uses relays. I installed the harness on mine.
10-19-2022, 09:23 AM | #41 |
my .02 worth on the original question, have always found the Hella E-code housings, good quality H4 bulbs and the relay harness to be as bright or brighter than any Chinese-made LED "kits"
