Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-13-2023, 04:40 PM   #26
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1972 Suburban 4X4 3/4 Ton K20 "The Beast"
Glad you got it dissembled without breaking anything.
Maybe you already know this but there are 2 different windshield rubber seals for the stainless trim. Deep and shallow. Just make sure you get the correct one for the trim you have.
LockDoc
Leon
Old 06-13-2023, 05:04 PM   #27
nsiti
Junior Member
Leon, thanks for the head's up on the seal. I purchased a 71-72 Deluxe Trim equipped version (P-WCR685A) from GMC Paul's. Does that sound correct?
Also, another question, the lower part of the windshield glass has delaminated over time. Is that something that a professional can address/fix? Or do we just live with the patina
Regards,
Nick
nsiti is offline   Reply With Quote
Old 06-13-2023, 11:09 PM   #28
LockDoc
LockDoc's Avatar
Regards,
Nick
Yes, that sounds correct.
To the best of my knowledge I don't think the delamination is repairable but you never know in this day and age. People do some amazing things....
LockDoc
Leon
Old 06-15-2023, 01:31 PM   #29
nsiti
Junior Member
Metal work to fix rusted areas around the windshield frame (both internal and external) commenced.
Old 06-15-2023, 01:32 PM   #30
nsiti
Junior Member
A few more photos of the rust repair around the windshield frame.
Old 06-21-2023, 11:36 AM   #31
nsiti
Junior Member
Bodywork and rust repair continues...
Old 06-21-2023, 11:38 AM   #32
nsiti
Junior Member
Front cowl area, floorpan, rear barn doors, and window frames all needed some TLC
Old 06-27-2023, 12:38 PM   #33
nsiti
Junior Member
Metalwork continues, chasing down some of the less obvious rusted areas.
Old 06-27-2023, 12:40 PM   #34
nsiti
Junior Member
Some more photos for your viewing pleasure!
Old 07-02-2023, 10:46 AM   #35
BAD1916
Great job on the rust repair. Looks like you’re moving right along!
BAD1916 is offline   Reply With Quote
Old 08-05-2023, 10:52 AM   #36
nsiti
Junior Member
Metalwork and rust repair of the body is nearly finished (excluding some small imperfections) and we've prepped for filling. Featheredge and filler work to follow.
Old 08-05-2023, 11:01 AM   #37
nsiti
Junior Member
I have a question or two maybe some of you can share your opinion on. The next daunting task is to remove the rear wooden floor, which has rotted, especially around the edges. The metal below has also disintegrated and will need to be repaired.
I understand from researching the matter that the wooden floor can be removed in two pieces, one large and one small (the front passenger side corner). Any tricks to ease the removal?
Once out I'm thinking to replicate the floor using a marine grade plywood, and epoxy coat it.
My dilemma afterwards is, do I cover the floor with insulation and carpeting, or put some veneer on top and leave the wood exposed (for aesthetic purposes)?
Cheers,
Nick
Old 08-05-2023, 07:56 PM   #38
LockDoc
LockDoc's Avatar
Cheers,
Nick
I haven't had to replace any wood floors. I know there are posts on it but I think most of them are buried in build threads. Maybe someone that follows the Suburban build threads will remember.
LockDoc
Leon
Old 08-06-2023, 03:48 AM   #39
nsiti
Junior Member
Thanks Leon, I took your advice and found the following thread (posts):
http://67-72chevytrucks.com/vboard/s...698377&page=20
Page 20 (see post #489 - #496 for removal), through page 23 (for replacement).
Old 08-06-2023, 09:45 AM   #40
BAD1916
First off, your suburban is coming out great and you’re making amazing progress..
“My dilemma afterwards is, do I cover the floor with insulation and carpeting, or put some veneer on top and leave the wood exposed (for aesthetic purposes)?”
Personally I think the exposed wood would look sexy. However if you plan on using it to haul anything I’m not sure about leaving it uncovered. If it has a third row even people getting in and out would mark it up.
Old 08-06-2023, 11:30 AM   #41
LockDoc
LockDoc's Avatar
Good deal!
LockDoc
Leon
Old 08-06-2023, 01:54 PM   #42
nsiti
Junior Member
Thank you! Good point about the potential for wear and tear. I'm inevitably going to use the space to move things and you're right that veneered wood would get roughed up.
Old 09-18-2023, 07:47 PM   #43
nsiti
Junior Member
Some photos of the minor progress made since my last update. The summer was slow due to lots of other obligations.
The upper metal decor trim has been removed revealing the expected rusted and broken clips. My understanding is that the metal strips are not being reproduced, which means that they'll need some TLC to make them look nice again. Any advice as to where I can source clips to reattach them? Also, I assume the screws (visible in the photos) used to attach some some of the strips to the body are not original?
Thanks in advance for your help and suggestions!
Nick
Old 09-18-2023, 09:33 PM   #44
LockDoc
LockDoc's Avatar
My Suburban did not have the trim so I'm not much help on that.
You might try these suppliers.
https://www.classicindustries.com/sh...ips-fasteners/
https://www.auveco.com/moulding-clips-retainers
You have to scroll through the plastic ones to find the metal ones.....
A lot of them will interchange.
LockDoc
Leon
Old 09-23-2023, 05:34 PM   #45
nsiti
Junior Member
Leon, thanks for the links, and good point on the interchangeability. From my initial search the molding clips are going to be a challenge. I'm still researching the matter and will post my findings when I figure out which ones work.
In the meantime, a coat of epoxy primer was applied, in preparation for a coat of surfacer, and body work.
Old 09-23-2023, 08:33 PM   #46
LockDoc
LockDoc's Avatar
Looking good! At least you aren't getting rain like we are here. No painting for me ....
LockDoc
Leon
Old 09-25-2023, 08:57 PM   #47
allen71
I have a 1971 K10 (1/2 ton) 4x4 suburban. I've had it since ordered from the factory. Your work is very impressive!
Where are you located? I'm in Southern California.
I have many questions but if possible I'd like to see your vehicle and talk in person about it and the work you've done to it.
Allen
allen71 is offline   Reply With Quote
Old 09-26-2023, 09:35 AM   #48
nsiti
Junior Member
Hi Allen, thanks for the kind words.
I love reading that you've owned your Suburban for 52 years! And that you ordered it from the factory to boot.
I'm located in New York, which is unfortunately far from you. But I'm happy to chat and will send you a PM with my phone number. Happy to help in any way I can.
Adding a little color to my restoration, I've teamed up with a friend/colleague who specializes in restoring Jeep Willys and is generally an expert on repair and maintenance 4x4 vehicles (he also helped me refresh my classic Ford Bronco). I spent between 6 and 12 months (and still going) researching the specifications for the build, including the overall plan, parts and materials. My buddy is responsible for the workmanship and mechanicals. So far so good. I estimate we are at about the 20-25% mark.
Kind regards,
Nick
Old 09-26-2023, 10:47 AM   #49
allen71
Nick,
For some reason PM doesn't work for me on this site.
Can you email me at aseengel@ca.rr.com?
Allen
Old 10-06-2023, 04:42 PM   #50
nsiti
Junior Member
Starting the dreaded rear wooden bed removal and replacement process.
Removed the tank which will be replaced by a 40 gallon w/skidplate purchased from Aero Tank in CA. That's gonna be (insert expletive) expensive to fill, but will give a great range.
