11-25-2022, 11:00 PM | #26 | |
Re: 4 Inch Drop in rear, what's needed to do it right?
https://www.classicperform.com/Store...ck/RCS603S.htm https://www.classicperform.com/Cshop/cart.html RCS6034 1960-72 rear 4 inch drop, pair $129.00 I used 2.5" drop spindles and -1" springs in the front. If you're interested, here's how my truck sets: http://67-72chevytrucks.com/vboard/p...ictureid=26506
Insert clever text here: |
11-26-2022, 05:23 AM | #27 | |
70+ ( Old Skool Club )
Most folks just do a front sway bar on their trucks as its a great upgrade especially for the price. I put a rear one on my truck ( pictured ) because I wanted to and for my usage of the truck really didn't need it. Check out this link from this site on front and rear sway bars. http://67-72chevytrucks.com/vboard/s...d.php?t=728503
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-26-2022, 11:08 AM | #28 | |
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
11-26-2022, 11:10 AM | #29 | |
11-26-2022, 11:37 AM | #30 |
The front is heavy and the motor moves the center of gravity up. I like the front sway bars for these reasons. I have a rear sway-bar and am going to remove it to see if I can get my truck to track straight when the tires are spinning. It becomes a handful fast and I am not really sure why. So I agree, the rear one is not really needed.
You should re-shim the rear to correct the spindle angle when lowering the trailing arm trucks. When I lowered my truck 4 inches, I avoided the re-shimming by moving the front of the trailing arms up. I did this by turning the brackets, at the forward attachment points, upside down. Drilled out the rivets and used bolts to reattach the bracket. I may have had to re-drill two holes, that I can't remember for sure. I confirmed the u-joint angles, after lowering, and it was withing GM tolerances. I wish I could get pictures but not possible right now. The aftermarket rear cross-members do the same thing, raise the attachment points. I really couldn't see any advantage, to the aftermarket part, over what I did. Allegedly, it retains the anti-squat built into the factory geometry. Cheers |
11-27-2022, 08:00 PM | #31 |
Another 4” static drop here. Progressive rate 4” drop springs, new spring retainer hardware, new U bolts, shock relocation kit, adjustable trac bar, and drop shocks. Sounds like a lot but it goes together pretty quick and easy.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
