11-28-2022, 04:00 PM | #26 |
Re: Pinion angle
drive shaft run out???
4:10's...that DS better be balanced dead nits and with a high RPM balancer....which few shops have Tire balance good? and rim bent or have run out? |
11-28-2022, 05:05 PM | #27 |
Re: Pinion angle
Nope, that's why I asked how he had the driveshaft shortened. The clocking could be off or the front section-- if shortened by itself-- may not be in balance with the rear now
11-28-2022, 05:47 PM | #28 |
Re: Pinion angle
I took the whole thing to a driveline shop. They shortened the front section and installed all new u-joints and carrier bearing. I can only assume they rebalanced it.
11-28-2022, 06:04 PM | #29 | |
Re: Pinion angle
I ran it supported on jack stands without wheels, tires and brake drums. The vibration is still there. BTW: at 45 driveshaft speed is about 2K max. At 70 nice and smooth.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-28-2022, 06:53 PM | #30 | |
Re: Pinion angle
I'd be looking at tires and rims--possible alignment--shocks, bushings not seated etc. Can you get us a picture of the rear with the d-line showing |
11-28-2022, 08:19 PM | #31 |
Re: Pinion angle
I used an app off play store seems to be pretty accurate and yes take the case off phone. I double and triple checked mine even bought a digital one to check it. I am a 1 piece shaft and installed a 700r4 that sits way low on stock crossmember 7*down on tail end and rear pinion was 2* up got the rear trans at 3*down should be good to go now.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-28-2022, 08:21 PM | #32 |
Re: Pinion angle
OP
Are you sure this is a DL induced vibration?? Have you ruled out torque converter shutter? (most common at 45mph...) |
11-28-2022, 11:49 PM | #33 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Pinion angle
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
11-29-2022, 03:40 PM | #34 |
Re: Pinion angle
No, not positive if it's the driveshaft. The torque converter is a brand new Hughes unit.
11-29-2022, 03:44 PM | #35 |
Re: Pinion angle
Hughes is a very good TC. what I run in other cars.
Trans fluid is a typical "shutter" problem...so assume you are running the right type. This assumes trans/TC shutter is even the issue. Just thought I would add hat to the ? list if the vibration was possibly not a DL angle issue or DS balance issue |
11-30-2022, 10:56 AM | #36 |
Re: Pinion angle
Before changing a bunch of stuff, try re-using the previous rubber trans mount. There's been more than one complaint about vibrations after switching to Poly driveline mounts.
12-02-2022, 05:08 PM | #37 |
Re: Pinion angle
to the OP, did you ever get this resolved?
12-02-2022, 09:49 PM | #38 |
Re: Pinion angle
12-03-2022, 02:14 AM | #39 | |
Re: Pinion angle
12-05-2022, 08:11 PM | #40 |
Re: Pinion angle
If it helps any I used 1 of them ol school mechanical dials compared to my smart phone which I compared to a store bought digital which I compared to the tremec phone app and they all read different Couldnt hardly pinpoint the mechanical dial but the phone app seemed to be pretty close to it and the tremc toolbox app for the phone was way different reading. This was me squished under the car trying to get good readings . Good luck
12-11-2022, 12:15 AM | #41 |
Re: Pinion angle
I spent a great deal of time perfecting my driveline angles. Ended up being the polyurethane transmission and engine mounts. Back to rubber now and the vibration us gone
Poly has its place..in a race car.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-11-2022, 02:42 PM | #42 |
Re: Pinion angle
I mentioned this above. Many overlook this as a possibility yet it's common. Easy enough to verify as well w/o requiring other changes & should be a 1st step IMO.
12-11-2022, 06:07 PM | #43 |
Re: Pinion angle
My engine mounts are rubber. The trans mount is poly. Maybe that's it....
12-11-2022, 07:01 PM | #44 |
Re: Pinion angle
Anything is possible & it's easy enough to verify.
12-14-2022, 02:49 AM | #45 | |
Re: Pinion angle
12-14-2022, 02:54 AM | #46 |
Re: Pinion angle
I have the 72 manual. Page 4-24, the 70 manual should have the same spline phasing procedure maybe not on the same page?
