04-29-2023, 09:55 PM | #26 | |
Re: Hidden Ignition Kill switch install - Best wire to put the switch on?
Ok then. Tell me what positions the four 3 way switches need to be in to start the truck? It’s just another layer of protection to go along with the alarm system. The Problem with simple kill switches is they are generally installed within reach of the drivers seat and thus easy to find. the relay wired into the highbeam switch or cig lighter is pretty known. A fuel cut off switch is one of the best anti theft devices . The truck stops 1/4 down the road after the carb bowl empties out. Leaves the thief in middle of road. I never did this because I was worried I would forget to reset it which could be dangerous. I believe electric fuel cuts offs are available to be wired into an alarm system.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 04-29-2023 at 10:19 PM. Reason: Added info and typo |
04-29-2023, 10:33 PM | #27 |
HEI tach lead kill switch plus hood lock and battery disconnect for longer periods.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
04-29-2023, 10:41 PM | #28 |
I wouldn't fuss with the electrical side, that can be circumnavigated too easy.
Back about 25 years ago I bought a 64 GMC from my buddy who had taken it in trade from someone else. I could fill the float bowl and it would fire right up but wouldn't pick up gas out of the tank, I went and got gas for it and fussed with it for a day or more until I decided to get under the truck and trace the fuel line from the 35 gallon stainless tank in the bed to the fuel pump. Right under the seat was a 3 way manual fuel valve like we used to use with auxillary tanks on trucks back in the 60's and early 70's before the square body trucks with dual tanks and the electric switch. It was turned to off. It's easy enough to cut the ignition wire from the switch to the coil and add some wire and a hidden but reachable switch. Trouble is that a jumper wire with a pair of alligator clips under the hood bypasses that and it is too easy to bypass the starter switch. Shut off the fuel and they aren't going to drive it away especially if let it idle and run the bowl dry or almost dry.
04-30-2023, 12:47 AM | #29 | |
04-30-2023, 09:30 AM | #30 |
I installed cameras outside. Really looking forward to being forced into doing another.
04-30-2023, 07:17 PM | #31 |
Your truck is only really safe when you have the trunk monkey .
https://www.youtube.com/watch?v=_qtG82HJB2I&t=70s
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
