06-15-2023, 08:24 AM | #26 |
Re: Speedo leak
I will, Thank you sir
MY Facebook ( saad_alhajri ) on Instagram
06-15-2023, 02:19 PM | #27 |
Re: Speedo leak
It seems that it is getting more complicated. The speedometer is not working now and it was working in the past. I don't know everything is in its right place.
06-15-2023, 02:31 PM | #28 |
Re: Speedo leak
I think I did not make sure to install this part correctly. I will try again
06-15-2023, 09:49 PM | #29 |
Carpe manana
Re: Speedo leak
It can be tricky to center the geared piece inside the transfer case and within the nut. Once these are aligned and in place it can take a few tries to seat the speedometer cable in the transfer case. The cable can get pushed into the cable casing and not be seated in the transfer case.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-16-2023, 03:29 AM | #30 | |
Re: Speedo leak
I followed your installation method. It works now. Thank you from the heart
06-16-2023, 08:16 AM | #31 |
Carpe manana
Re: Speedo leak
Cheers man! Enjoy.
