Old 01-07-2024, 12:13 AM   #26
novaX522
Re: Control arm shaft torque?
Originally Posted by jumpsoffrock View Post
Thank you for including the socket size, now I know what to look for. What size truck do you run? I wonder if they are the same size for a 1-ton.
Not sure on the 1 ton. I bet if you post the question, one of these guys will know.
novaX522 is offline   Reply With Quote
Old 01-07-2024, 12:18 AM   #27
novaX522
Originally Posted by MikeB View Post
I forget which manual I used for specs when I did mine years ago, but no way were they the "new" numbers in the chart above. That chart is a bit strange showing the torque for "bushings" when there are no bushings.
Couldn’t agree more Mike. Real confusing. I got the nuts as tight as I could with a 1/2” ratchet. I then used a 3’ long 3/4” torque wrench to check the torque. I was able to get them tight enough with the 1/2” ratchet. I don’t think they are going anywhere.
