02-01-2024, 08:59 PM | #26 |
Re: Lifter issue?
I no longer use flat tappet lifters. Today's oil is not formulated for these older style lifters. If you are using an older SBC, and not spinning the engine more than 5500 or so the retro roller lifters work just fine. They are a little heavy for very high rpm. I had a cam fail last year. Lots of junk in the system. It was old motor so I took a chance and ran diesel fuel through the oil system by using a primer tool. Then very thin oil. Then my normal weight changing filter each time. Driven about 5k since the change without issue. I would not recommend for a newly built engine or one with high end crank, but for older driver, you are not risking much to attemp a wash out.
02-01-2024, 11:11 PM | #27 |
70+ ( Old Skool Club )
Re: Lifter issue?
A friend rebuilt a small block 400 for me, 817 virgin block that got a .30 bore, and besides the crankshaft and bare block all other parts were new. He recommended I use Lucas Hot Rod oil in the truck which has Zinc in it. Spun the cam with a drill to get oil up to the rockers and then the 2000 RPM break in for 20 mins or 1/2 hour. Got it installed and running last summer and have driven the truck 1000 miles no issues.
https://www.summitracing.com/parts/nal-12371044 https://www.lunatipower.com/voodoo-h...k-256-262.html
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-02-2024, 08:12 AM | #28 |
Re: Lifter issue?
Zinc or lack thereof in most oils is the easy scapegoat, but in reality it is mostly crap metallurgy and machining. The metallurgy is so bad that even roller lifters are failing!
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
02-02-2024, 11:18 AM | #29 |
Location: Herculaneum MO (20 minutes south of St. Louis
Re: Lifter issue?
This! This right here. I've easily put 100k collective miles on the trucks in my signature. I use modern oils. Nothing fancy, no hot rod oil, no high zinc no oil additve. Also no oil related failures.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
02-02-2024, 02:26 PM | #30 |
Re: Lifter issue?
Agree on crap metel we have today. Just compare a 1970s tool in your box to today's stuff. I think there is a way better chance of success using a roller cam and lifter over the flat design. For a few more dollars and a hour or so setting up the button, I have a much more confidence the cam will run in correctly.
02-04-2024, 05:03 AM | #31 | |
Re: Lifter issue?
