02-13-2024, 12:21 PM | #26 |
Re: Steering wheel choices
It really does.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-13-2024, 12:24 PM | #27 |
I have one of those too, looks great with all that wood grain.
Also, that was the steering wheel everyone had when I was in high school so there is that nostalgia factor, too.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
02-13-2024, 12:35 PM | #28 |
New Member
02-13-2024, 01:18 PM | #29 |
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350 and 700r4. ~ James |
02-13-2024, 11:49 PM | #30 | |
I was 45 Y.O. I had soloed a Cessna 150 when I was 19. I've been in worse places. Since I was still on the ground, and going about 20 MPH, making a turn -- I put the wheel back on the hub -- maybe not aligned perfectly, but enough to still steer. Guy behind me honked, but I had bigger things to deal with than jerks. I pulled into a parking lot and looked at the situation. The center of that Grant wheel was lead, [or potmetal] And it was maleable. I gave it a whack with a framing hammer, so it would stay on enough to get home, and got the hell out of dodge. As soon as I could, I mounted the OEM wheel the PO had included with the deal, and never looked back. I HATE GRANT WHEELS
02-15-2024, 09:05 PM | #31 |
Here's a Nardi wheel I adapted to fit my blazer. Finished it 3 years ago and still haven't installed it!
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
02-16-2024, 06:41 AM | #32 |
I did not know they made a 15 inch version of the 67-68 wheel. Where did u get that?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
02-16-2024, 08:26 AM | #33 |
02-16-2024, 08:28 AM | #34 | |
But I see there are a few different places to get them. https://www.google.com/search?client...eering%20wheel
02-16-2024, 08:36 AM | #35 |
Lol, that's what the wheel in my truck looked like when I bought it.
02-16-2024, 08:46 AM | #36 |
I ended up going for the 15 inch because after getting a 17 inch wheel, putting it on the truck and sitting there for a second I just started laughing. It was so ridiculously big. I felt like I was in the driver's seat of a big yellow school bus.
02-16-2024, 05:44 PM | #37 |
That's about like the 3 Stooges Wheel that the PO had on my '71 Jimmy when I first bought it
02-17-2024, 08:03 AM | #38 |
I don't intend to offend anyone, but I find it comical when I see guys talk about the original steering wheels as being too big or referring to them as school bus or semi truck wheels. The 17" are just how it is in these trucks and school bus wheels are even bigger. I don't know anyone's age, but to me it shows how much younger many of you are. You obviously started driving once everything had power steering and steering wheels became smaller. It's the same as when guys come to these trucks and are afraid the truck will blow up if they drive 65-70 mph because they rev 2,500 to 3,000. Those guys obviously started driving once overdrive had become the standard. I've driven cross-country and back in these trucks at whatever speed suited me, school bus wheel and all
02-17-2024, 08:08 AM | #39 | |
02-17-2024, 08:15 AM | #40 |
Junior Member
Blue comfort grip wheel
1970 Chevy C10 Stepside, 350 with 700r4 1990 GMC Jimmy |
02-17-2024, 10:46 AM | #41 |
Depends on the truck . I put the comfort grip on my 72 because it has power steering. My 68 I restored the original no power on this truck .
02-17-2024, 11:15 AM | #42 | |
02-17-2024, 06:07 PM | #43 |
Yeah, the Large diameter helps leverage immensely when using Armstrong Steering.
67-68 wheels are 16 or 16-1/2''. 69-72 wheels are 17''. I tried to put P/S on my '67 K/10 Suburban. Four wheel drive and a 454 BBC in front it was a beast to steer manually. But I screwed up and used a C/10 69-Later style P/S gear box. Steering geometry was all off, and it was shearing off 1/2'' grade 8 bolts from the frame. Couldn't pull a U-Turn from the Left Lane. So I tried to restore the manual box. Put a bead of JB Weld on the long crack over the case and hoped for the best. I never could get it back to the way it was. I got 1/2'' ID foam pipe insulation [''Donkey D!ck''] and put it over the 3 spokes and around the rim, and taped it over with black adhesive tape. The foam padding helped when catching the spokes as the wheel spun back -- straightening out from a turn. Kept from bruising my hands. Someday when I rebuild that Sub, I'll put a post-MY '71 Dana 44 front end on -- w/ P/S and Power Disc Brakes. Two cures in one shot. But working on the '67 Suburban isn't in the current budget.
02-17-2024, 11:57 PM | #44 |
here's mine .....was a 50 anniversary wheel I repainted and have the CST button ....as far as dating myself I cut my teeth on a (no CDLs back then) 66 Brockway with a 220 Cummings no blower and a 13 speed the steering wheel was the size of a covered wagon wheel and it was fun steering and shifting all day long and at night when I was dreaming .....Happy Motoring ....LOL
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-18-2024, 02:05 AM | #45 | |
02-18-2024, 01:44 PM | #46 |
70+ ( Old Skool Club )
I had a Le Carra on my original truck to replace the one that was on it when I bought it in 2001 and kept it when I sold the truck and put an OBS one on for the sale. I put the Le Carra on my present truck after removing the original leather wrapped one , which is now wrapped up sans the leather and in storage. Couple years ago replaced the Le Carra witha comfort grip one which i like and looks great in the truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-20-2024, 11:28 AM | #47 | |||
For the big boys.
Great thread. Almost makes me want to build another truck.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-20-2024 at 11:44 AM. |
02-20-2024, 11:42 AM | #48 | |
Active Member
02-20-2024, 11:43 AM | #49 | |
Post Whore
I've been thinking about putting a larger wheel in my new S10 since it has manual steering and the added leverage of the bigger wheel would be nice. To me driving the GMC with the split windshield and the big wheel makes the world outside look better.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-20-2024, 01:09 PM | #50 |
can you restore a oem steering wheel or change the color?
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
