#476 | |
Its lookin' like a Blazer!
Re: Building a Blazer - vtblazer's Way
#477 |
When I spoke to Ballistic on Fri and they told me the parts still hadn't shipped, I asked them if they'd ship em out 2nd day air for me since they were so late and he said okay.
Well he did what he said, they arrived today. Turns out the TR ends on my cross over are larger, might be able to get the one end machined out hopefully. Also turns out that the factory TR has the correct ends, so if I can get enough adjustment out of it, I can use it and I get my high steer too. |
#478 |
urban fourwheelin
I'm assuming that the new drag link connects to the box and the old one is connecting the knuckles. Other than the obvious, the draglink is no longer hanging out front and subject to damage.. Is the way you are doing your steering make the truck drive better?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
#479 | |
The cross over set up is what will make it drive better, the high steer is a side benefit. |
#480 |
urban fourwheelin
would I see much of a benefit with crossover and 33 inch tires?
#481 | |
Cross over is only really appicable when you get into bigger tires (36+) or around 6"s or more of lift. (mainly the lift issue) Are you running a D60? Last edited by vtblazer; 01-13-2009 at 06:37 AM. |
#482 |
GEARHEAD
Does cross-over steering improve turning radius at all? Are there other tricks used to improve turning radius?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#483 |
urban fourwheelin
No, D60 here. i'm 5'8 and my lady is 5'2 on a good day. so My truck won't ever get bigger than 33 and I only do light logging road wheeling. So I will be sticking with the dana 44. I was just curious if it would help my truck handle a little better.
#484 |
Axle is done and it's at least a roller again.
It's currently having to share the space, those 37's don't seem to look so big anymore... ![]() The interesting part is, how can one blazer with 37's & 2.5" springs, sit just as high as one with 42's & 6"s of lift? ![]() |
#485 |
Can't wait to retire!!
Cool pics! Wish I had two of 'em.
What am I talking about...I can't find the time to work on one. ![]()
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#486 |
That could be the question of the day, actually the orange one sits 1"-2" higher from the first pic
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#487 | |
Two is a lot, this could change in the coming months. Initially the tires on the blue blazer were pretty 'aired down' lets say but even when I pumped em back up, there's not a whole lot of difference between the two as far as sitting static. |
#488 | |
#489 |
#490 |
Neat way to fill up a shop
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
#491 |
*Full* - ya got that right!
![]() Less than 2ft all around, that's all the walking room that's left. |
#492 | |
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-16-2009 at 09:59 AM. |
#493 |
DeeeeLishous
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#494 | |
![]() Join Date: Mar 2004
Is 2.5" the exact lift on the front of the red one? You have a shackle lift on the rear which should be 4" or more and it looks to be sitting level. Just curious. BTW. They look good in there together. I'm glad the ballistic arm showed up finally. The H2 rims look good to. I always like the way they look on the older trucks. Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) Last edited by 4bynut; 01-16-2009 at 11:28 AM. |
#495 |
I think its time to add on to your garage
![]() and what does this mean? "Two is a lot, this could change in the coming months." Sellin' the fun truck? |
#496 |
![]() ![]() Last edited by vtblazer; 01-16-2009 at 06:17 PM. |
#497 |
You kiddin'. I'd be honored to own it. I'd have a ball around here with one built like that. But I'm broke so no I couldn't buy it
#498 |
#499 | ||
You want it before or after the taper job? ![]() |
#500 |
