Old 05-20-2010, 10:02 PM   #476
threeonthetree
threeonthetree's Avatar
Re: Project' 69 c10 aka sin.
its a 76 cj5 i think or 8 there all the same.
my cousin's got big plans for it!
and thanks shes not quite done but getting there.
any ideas on why my 250 deisels?
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 05-20-2010, 10:03 PM   #477
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
pics didnt work for me,,it may be me though, the 2nd one did..looks good man i wanna see the other pics thought
John
1999 Toyota Tacoma 4x4
Old 05-20-2010, 10:07 PM   #478
threeonthetree
awh man... get on a different computer
here are a 2 more.
i currently am working on my crf.. blew a head gasket had to strip the thing down. my dads 75 in the back ground.
and one more of the truck
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 05-20-2010, 10:23 PM   #479
292farmer
292farmer's Avatar
have u rebuilt your carb yet? my 350 had a sticky float, and would drip fuel into the intake, and when the truck was hot enough the fuel would burn, after i shut it off. try putting marvel mystery oil in, ive had good luck with it, or run some injector/carb cleaner in gas, might clean out any carbon creating heat spots.
292farmer is offline   Reply With Quote
Old 05-20-2010, 10:25 PM   #480
oldblue1968chevy
I only see the dirtbike but its all good!
John
Old 06-14-2010, 04:06 PM   #481
threeonthetree
got to do some work.
oh and the reason the truck was desiling, my idle was set to high.
turned her down and shes running good now.
was driving it around till i found out that you need insurance in wisconsin now. its the law, so i haven't cruised around lately. truck goes down the road really pretty straight even with the cut springs, and no alignment done to it. 3 on the tree is a pain in the ass sometimes when she locks up,, thinking about getting a stick on the floor.
ive really been thinking about getting a 73 and up front end and swapping them out, and then getting drop spindles but idk how much work that would requie.
or just going with drop spindles, on this set up the fronts up a little high for my taste. but i dont have disk brakes and dont really have the money for a kit right now.
still got to finish up the bed and weld some metal in and screw it alll down but ive been kinda lazy lately since i cant really drive it or anything.
But summer is here and i should be enjoying the weather anyways.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 06-14-2010, 04:53 PM   #482
oldblue1968chevy
get some conversion drop spindles and then get a 71 and up frontend and use those parts..you'll need a diff. mc prop valve best swap ever i will help you thru if if you need it! duhh you need insurance to drive lol
John
Old 06-14-2010, 05:34 PM   #483
threeonthetree
well you it wasn't against the law in the state of Wisconsin till like the beginning of this month.
yeah i was thinking about doing that. I'm more in it cause of the drop not so much the disc brakes. but it would be a plus. idk if i can find a 71 and up front end in my area.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 06-14-2010, 05:39 PM   #484
threeonthetree
so whats the valve for and where do you buy it.
im gonna head over to the junk yard and see if they have a 71 and up truck with discs there right now.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 06-14-2010, 06:05 PM   #485
threeonthetree
junkyard doesn't have any front end set ups
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 06-14-2010, 06:19 PM   #486
threeonthetree
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 06-14-2010, 08:32 PM   #487
oldblue1968chevy
I think you could use 73 and up rotors calipers etc...
Are you wantin to rebuild your front suspension (tierod ends bjs' etc)...
If no Just get conversion drop spindles (will bolt right up) then get bearings seals and a rotors/calipers pads, then a mc and prop. valve
id try to find some of this stuff used..good luck! I just had a whole frontend from a 77 you coulda had free if you were closer shipping is nuts on that heavy stuff
check out early classic enterprizes ive seen the drop spindles in there catalogs.
John
Old 06-15-2010, 07:40 PM   #488
threeonthetree
okay well i found a truck
its a heavy half ton.. will half ton spindles still work on these brakes
i like it cause its 6 lug
and where thinking about putting the 454 in the bel air of mine.
aha
check it out
http://wausau.craigslist.org/pts/1793421799.html
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 06-15-2010, 09:18 PM   #489
oldblue1968chevy
dude the belair needs that big block!!!
wait its 6 lug..but half ton discs?...
never knew such a thing, I guess it would work..?
John
Old 06-15-2010, 10:04 PM   #490
threeonthetree
Yeah the bel air does need it.
where gonna go and look at the truck tomorrow
hopefully we end up with it.
yeah the guy said its six lug, and its a heavy half ton, idk if that means its a 3/4 ton or what will find out tomorrow i guess.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 06-25-2010, 11:55 AM   #491
threeonthetree
Good...Well I finally got my plates!
Bad... I roasted my clutch I got a new one already but I have to start the install on it . Drop the tranny. I'm excited.., not doing anymore burnouts after I get the new one in..
I'll prolly have some ?'s later on.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 07-01-2010, 12:57 PM   #492
threeonthetree
Well I've been busy with work but I'm hoping I can bust the clutch out today.
I'll have some pics up tonight I'm planning on just getting it done!!
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 07-01-2010, 09:23 PM   #493
threeonthetree
I almost got it done clutch is in I just got to get the tranny in and put fluid in it. Then take it for a drive.
I'm having some trouble with the clutch housing I can't get the bolts in the housing threw the crossmember bolts arn't lineing up with the housing. Hopefully I'll get er tonight gonna go home and work on till it's done.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 07-06-2010, 04:56 PM   #494
threeonthetree
got the clutch in everything seems to be running good.
pics
tranny out.
new clutch
the truck
and the crf is running good.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 07-06-2010, 05:53 PM   #495
oldblue1968chevy
haha awesome, I just rode my buds new trx450 thats a pretty stout motor i cant imagein it on a 2 wheeler!!!
John
Old 07-16-2010, 12:13 PM   #496
threeonthetree
little update
got the bed all done screwed it down its solid.
been driving it alot. drove it to iola a couple weekends ago. that was a blast got some looks the ol 250 is running good and the new clutch is really solid.
also took it up north this week for a few days love driving her around
get complemtns all the time. this one guy said i had the nicest chevy in town haha.
well here are some pics.
one from iola's lot and one from up north by my k5
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 07-19-2010, 06:19 AM   #497
292farmer
292farmer's Avatar
that black and white photo looks really cool
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
Old 10-06-2010, 08:57 PM   #498
threeonthetree
well i havent updated for a while but i have been working on the truck
just put a new carrier bearing in tonight. trucks running realll good.
i wanna put some stock rims on and im looking for a good tire size. got any suggestions.
ill put some updated pics up sooon.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 10-06-2010, 09:16 PM   #499
oldblue1968chevy
hey man we thought you fell off the face of the earth! Pictures? Also, ima ask this cause I dont wanna re read, but what kind of paint did you use? Im thinking blitz black or something, from where and how'd you spray it? Now im going back to re read..
I wanna get all 1 color..
John
Old 10-08-2010, 12:22 PM   #500
threeonthetree
i used the blitz black.
john deere paint right from the john deere dealer
sprayed easy is holding up pretty well. i sprayed it with a standerd gun. prolly would wanna get a gravity feed gun tho. and a nice compresser. if your gonna paint you better soon times starting to run out. find a cab yet?
1969 c10 AKA SIN
1985 SSWB TRAZER
