08-01-2021, 09:26 PM | #476 |
Re: Yet another GMC build
good reason to go automatic then, haha.
the guys at work used to give me a hard time bout my boot size, 8.5w, they would say "oh, look. they make our boots in girl sizes". those were the guys asking me to crawl into the tight spots cause they were too big. (firefighter) |
08-02-2021, 08:13 AM | #477 |
not going to lie, i was not picturing the wheelbarrow ... but that's hot. the stamping is really going to look perfect all finished out.
08-08-2021, 08:21 PM | #478 |
I spent a whole day cutting the dash and putting in a new gauge panel because 1. The fuel gauge in my quad doesn’t work and 2. I spent a ton of money on gauges for a turbo engine so I should use them.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 Last edited by OKGMC4; 08-09-2021 at 04:56 PM. |
08-13-2021, 05:09 PM | #479 |
I bolted in the crossover and screamer pipe that I built when this was going in the c10. It fit but I realized the engine was too low. So I cut the engine mounts and raised it til it fit better. Then the exhaust manifold hit the floor and I had to scootch the engine forward about 3/4 of an inch. Rebuilt the trans mount and now having to expand the driveshaft loop from a circle to an oval so the shaft can go in.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
08-13-2021, 05:14 PM | #480 |
And since the trans moved up I had to cut the floor some more. Then I needed something bigger to cover the hole. I needed a hump. A big hump. And I discovered that all one needs to do to get a hump is go online and pay for one. My wife doesn’t appreciate my sense of humor about paying for humps…anyhow, after butchering a 67-72 high hump I think I’ll be fine once it’s welded in.
08-18-2021, 05:31 AM | #481 |
Devising brackets to mount intercooler and radiator. Looks like the engine and radiator setback are roughly the same. My hoses will still fit. Yay!
08-18-2021, 06:22 AM | #482 |
6>8 Plugless........
Nice work on the upgrades!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-19-2021, 07:15 PM | #483 |
08-19-2021, 07:18 PM | #484 |
Getting closer on my brackets. Really just a spacer to move the radiator out. I could put it back later if all this turbo stuff doesn’t work. I’m on a big learning curve.
08-22-2021, 04:38 PM | #485 |
Making a cover for the intercooler. Also to help direct air through the front rather than recycling hot engine bay air.
08-23-2021, 07:38 AM | #486 |
you have so much room for activities in there!
learning curve's can be frustrating when you find a way better solution to a problem 2 steps ago. don't be afraid to go back, will still be way easier now vs later. i've never driven my truck and am on the 3rd chassis design |
08-27-2021, 05:37 PM | #487 |
Bought a pipe, bead rolled the ends, and welded my BOV flange on. Waiting on couplers to see if my homemade S bend will fit the other side. My coils were too close to the wheelbarrow so I’m making new brackets to scoot them farther forward. Takes forever but cheaper than custom wires or relocation brackets. Collecting AN fittings and ordered a breather tank. Just can’t decide whether to mount the tank on the firewall where the battery was or on the frame rail. One way is easier to drain but the other will look cleaner and keep any oily mist on the frame and not the engine bay.
08-30-2021, 07:40 AM | #488 |
if you put it on the firewall, it should be high enough to have a return line from the bottom into the pan right? self-draining!
08-30-2021, 06:08 PM | #489 |
After seeing all the condensation that came out of the catch can on my 6.0 it scares me to drain the stuff back into the crankcase.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 Last edited by OKGMC4; 08-31-2021 at 02:44 PM. |
09-03-2021, 05:12 PM | #490 |
Firewall it is. Made a bracket that uses two of the old battery tray bolt locations to mount the tank. AN hose kit on the way. My S pipe fits and the AFE filter I got fits perfect in the space but….don’t like how it will be pulling hot air right off the electric fan. I imagine under hood temps will be stupid high. Want to try and build a fiberglass air box / scoop that takes advantage of that otherwise useless giant hole in the GMC hood. Lower IATs should mean less knock and more power. Still need to relocate ac drier and coolant tank plus mounting the booster, it’s going to be packed in there.
10-22-2021, 05:59 AM | #491 |
Fat coat of epoxy and 2K high build, runs and all. At least the sandpaper scratches are filled. lol. Now I have an idea where I’m at and can start block sanding.
10-22-2021, 10:23 AM | #492 |
Forward progress. Let'er harden up and scuff'er down. Fill the low spots and smooth it all out. A few coats of high build and some elbow grease and you'll be done.
Yeah, I know. Nobody likes block sanding especially in cramped quarters with lots of corners. |
11-22-2021, 10:05 AM | #493 |
Since I moved the engine back, the steering pump hit the rack. I had to buy a bracket for a narrow street rod application so had to buy a corvette pump which means I had to add an external reservoir which means I had to buy more fittings and hoses. It’s a lot like dominoes. Really expensive dominoes.
11-29-2021, 08:02 PM | #494 |
Engine bay coming together. Still so much to do, though!
11-30-2021, 03:25 PM | #495 |
Very nice...
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
12-01-2021, 12:12 PM | #496 |
oh yeah, this is guna be good
12-01-2021, 07:44 PM | #497 |
I swear I just heard Syndrome from the Incredibles!
12-01-2021, 08:05 PM | #498 |
Thanks! To illustrate how out of touch I am, I don't even think I knew you sold the 48'. I think you were building that truck about the same time I was going through my 56 the first time. Kind of wish I had something with more seating like a burb but my kids are pretty much grown and could give a crap about cars. Maybe I should build one anyway and pray to get auto enthusiast grandkids someday. LOL
12-02-2021, 09:09 AM | #499 |
Very nice work! That is going to be fun to drive!
12-02-2021, 03:41 PM | #500 |
