Old 11-28-2010, 02:43 AM   #476
SCOTI
SCOTI's Avatar
Re: Project: Recycle
A-arms installed (temporarily).
Bags installed.
Spindles installed.
Calipers mounted.
Shocks mounted.
Brake lines (flex lines) routed.
Rear housing cleaned & shot w/a quick coat o' color.
Rear housing in place.
Truck arms bolted up & snugged to the rear housing.
Rear bags installed.
Got alot done, but a bunch of it is just 'connected' (not finished) which is frustrating. I couldn't tighten the rear u-bolts (didn't have the right size wrench), still need the front a-arm bushing washers, & still need the rotors painted. The parts house was supposed to have my HD brake parts (shoes, wheel cylinders, & spring kit) but only got the shoes.
I'm spent . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-28-2010, 10:03 AM   #477
Jonboy
Slots go on anything!
Right on!
1974 Jimmy- 5.3/4L80e/NP241
Old 11-28-2010, 11:42 AM   #478
67cheby
67cheby
67cheby's Avatar
great progress
67cheby is offline   Reply With Quote
Old 11-28-2010, 12:02 PM   #479
n2billet
Village Idiot....
n2billet's Avatar
All this and still no pictures.....................
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 11-28-2010, 12:22 PM   #480
kev2809
low n' slo
kev2809's Avatar
^^^ lol
progress is progress man, your doin some nice detailed work!
......now post some pics
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-28-2010, 01:31 PM   #481
SCOTI
SCOTI's Avatar
Originally Posted by kev2809
^^^ lol
Crappy lighting, parts, steel, tools, & other various equipment in the way of decent pics. My hope was to roll it out for some pics in the sun....
Edit: I added these cell pics I took mid day to send to Matt. He also took a couple of pics from his phone which are typically very decent. I'm waiting for them to upload to my e-mail & I'll post them up once they do....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-29-2010, 10:38 AM   #482
N2TRUX
Happy to be here
N2TRUX's Avatar
Progress looks good Scot. Crappy pics, set backs, and all aside it still looks much better than a bare frame.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-29-2010, 11:24 AM   #483
67cheby
67cheby
67cheby's Avatar
looks sweet did you have the billet brake line clamps made or is it something you can buy, they look great !!
Old 11-29-2010, 11:31 AM   #484
SCOTI
SCOTI's Avatar
Had some made after ordering in something similar (but different size). **Edited w/the pics Matt took.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-02-2010, 12:26 AM   #485
SCOTI
SCOTI's Avatar
Truck arms tight w/pinion shims installed. Prob will swap the 3° shims for the 2.5° set.
Got the correct 'front' truck arm bolts & nylock nuts. The one's previously installed were coarse thread & barely long enough. I swapped them for some longer, fine thread bolts (I used fine thread on the TA mounts too).
I got new upper a-arm nuts & got them installed. I decided to just clean & paint the existing OE washers & run them. It's not 100% tight but snugged down (waiting to set it on the ground under weight before final tightening). I then went to snug up the lower a-arm hardware & realized the bushing 'sleeves' were too long. A quick text to Mr. Porter confirmed they're trim to fit so I took care of that.
I didn't have the correct upper shock bolts (too short) so I got longer ones & swapped them in place. Other than that, trips to Fastenall & Lowes to swap some 'un-used' hardware for different stuff I will use.
I've been moving the rear HD drum set-up in & out of the truck hoping to have enough time to get them in color & swapped into place but haven't had enough time yet. Need to get the front rotors in color as well so they can be installed . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-02-2010, 10:17 AM   #486
67cheby
67cheby
67cheby's Avatar
the new pics look super nice , very detailed nice work !!
Old 12-02-2010, 03:33 PM   #487
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good SCOTI!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-03-2010, 01:06 AM   #488
SCOTI
SCOTI's Avatar
Today I took one step back, then two forward....
A week or so ago, I had managed to scratch one of the spindles when mocking the spindle/caliper in place. It had been about 3-4 days since I had painted it so I didn't hesitate to grab the rattle can for a little touch-up. The result was the previous paint under the 'fresh' paint started bubbling up bad.
Per manufacturer (VHT) recommendations, I had to let it cure for @ least 7-days before fixing the fix. Ten days later (today), I cut down the problem area w/some 320 dry paper, wiped it w/degreaser, & re-shot some color. Everything went on nice & smooth this time. You'd have a hard time figuring out where the 'repair' was (not that it can even be seen ).
While that was going on, I covered up the other spindle & used it as a turn-table to paint the new replacement rotors. While everything was drying, I swapped the last 2 lower a-arm sleeves into place. Now all 4 bushings are 'snug' & waiting for the chassis to be on the ground for final torqing.
I re-assembled the spindles to the control arms & went to install the rotors only to realize I no longer had the spindle nut hardware. After yet another trip to the parts store, the spindles/calipers/rotors are joined.
I wanted to throw the wheels on for a lil' look but . . ...... no lug nuts. Lug nuts are in the dually now. Getting closer though....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-03-2010, 07:00 AM   #489
n2billet
Village Idiot....
n2billet's Avatar
DANG!!!! I'm about to tear up........looks really good Scot.
Old 12-03-2010, 07:44 AM   #490
darkhorse970
darkhorse970's Avatar
Chassis looks great Scot! I love the look of fresh black paint and new hardware!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 12-03-2010, 08:03 AM   #491
joe231
joe231's Avatar
WOW!
nice work!!!
CHEVY ONLY
Old 12-03-2010, 08:47 AM   #492
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Damn she is looking good... Cant wait to see some rollers on her.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-03-2010, 09:27 AM   #493
N2TRUX
Happy to be here
N2TRUX's Avatar
Wooohooo! Now thats some nice looking parts. No longer piled in the corner, but actually making a truck frame.
I really like that billet hose clamp. Wish I ahd a piar of them...
Articles-
"Refining Sierra"
Old 12-03-2010, 09:34 AM   #494
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Man that thing is starting to look good .....!
ksbrktracer is offline   Reply With Quote
Old 12-03-2010, 09:50 AM   #495
Jonboy
It's really coming along well, Scot. Those rallies are going to be awesome on there!
Old 12-03-2010, 10:00 AM   #496
SCOTI
SCOTI's Avatar
No Ralleys on this one....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-03-2010, 10:05 AM   #497
SCOTI
SCOTI's Avatar
Originally Posted by joe231
WOW!
nice work!!!
Thanks guys!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-03-2010, 10:20 AM   #498
67cheby
67cheby
67cheby's Avatar
that would make two of us... I WONDER.......what the chance are of a guy like me and a clamp like, getting together would be???
Old 12-03-2010, 10:34 AM   #499
SCOTI
SCOTI's Avatar
The guy that made them is the next door neighbor of my buddy (Detroit Customs). He's semi-retired & likes this kind of stuff. I wanted to do a run of 50 (25 sets) but needed to make sure they worked before asking to have more made.
If it happens, I'll let you guys know.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-03-2010, 10:38 AM   #500
67cheby
67cheby
67cheby's Avatar
.........So what your saying is THERE IS A CHANCE ?? (DUMB AND DUMBER)
