Old 01-26-2011, 08:25 PM   #476
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Sunday????? shoot...more like friday night. Starting friday at 8 or so am. Should not take too long to pull old one and stab new engine in its place. At least that is the plan. Would like to have the exhaust hooked up sat some time.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 01-26-2011, 09:25 PM   #477
85burb
85burb's Avatar
Just went to hardware store and got 6 of 10x1.5x40 and 10x1.5x45 bolts. They look really long to me. But that is what all the fourms say to use. What did yall use?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-26-2011, 09:36 PM   #478
y5mgisi
Second Chance Program
y5mgisi's Avatar
For the intake? They do look insanly long but they are correct.
y5mgisi is offline   Reply With Quote
Old 01-26-2011, 10:23 PM   #479
85burb
85burb's Avatar
For the trans to bellhousing bolts sorry.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-26-2011, 11:37 PM   #480
y5mgisi
y5mgisi's Avatar
THats like an inch and half- two inches right? Should be good.
Old 01-26-2011, 11:42 PM   #481
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
they are roughly 1"- 1.25"? I honestly don't rmember...but maybe this will help?
gen-III-hardware.pdf
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-26-2011, 11:50 PM   #482
harnalien
TruckincrazY
harnalien's Avatar
Super excited for you!
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 01-26-2011, 11:54 PM   #483
85burb
85burb's Avatar
Did not see any in the size i have.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-26-2011, 11:55 PM   #484
85burb
85burb's Avatar
Thanks i am not sure if i can be any more excited. and nervios at same time.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-27-2011, 10:02 PM   #485
85burb
85burb's Avatar
12 hours........ Going threw everything in my head.....may expolode soon.....Did not sleep last night good and tonight does not look good for sleep. CANT Wait. May just drive there and wait now..JK
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-28-2011, 12:22 AM   #486
85burb
85burb's Avatar
My good buddy at work welded these on for me. He used a heliarc or what ever welder....I know absolutly nothing about welding so all i can say is they have not fallen off yet.....YAY
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-28-2011, 11:22 PM   #487
85burb
85burb's Avatar
Well folks.....swap is officaly under way. Got to bros house at 8 or so. Then sat around and bs for while. Then went to get his truck, then went back to his house to get the engine hoist, then to storage, then to paint shop to see if bros blazer is still on scedual for paint and body, then to his house. By the time we got to his house it was after 10:30 am. Had old engine out sitting on its tire buy noon. Every thing is going great at that point. Then installed balancer bolt and touqed it to half a million it seemed like. Then set valves cause i backed them all off to take pressure off the springs. Then made list of stuff i would need. Then went to napa and got powersteering oil, new lower rad hose, powersteering hose, coolant, wire, loome stuff to cover wire. Then the fun came...........hoisted engine into its new home. It did not want to go. After jacking around with mounts and mount plates for what seemed like all freken day it was in and bolted to trans. Then all hell broke loose with pos headers. I must have to say they most deff DO NOT FIT a 4x4 truck. They hit everything within a 10 foot radius. We started with the pass side. No go. Had to cut ear off trans( Did not want to do that by any means.) After we switced off turns with hack saw a few times. It was off. Tryed to put header back on no dice. it still hit the frame, and shackel. SO i tryed the briver side. Went on perfict so i thought. Just needed collector to be moved a tiny bit. Then after giving up for the day went to try to shift into nutral and dang shifter would not move......It was hitting the collector. So pulled that off and pushed it back to clean mess up and go home. Sorry for the long post but it should answer most of questions some may have. Now for the good part.....PICS!!!!!!!!!!!!!!!!!!!!!!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-28-2011, 11:25 PM   #488
85burb
85burb's Avatar
pics
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-28-2011, 11:28 PM   #489
85burb
85burb's Avatar
I am the one that DOES NOT have hat. We are not twins. Just look very simalr... Had to flaten tires to reach everyting with out climbing on front. Dang lifted trucks.......
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-28-2011, 11:30 PM   #490
85burb
85burb's Avatar
bros blazer.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-28-2011, 11:35 PM   #491
85burb
85burb's Avatar
Well i think the headers will fit a 2wd with manual shift or a auto with locar shift cable conversoin thing. Boy the driver side looked great with the header bolted on. Looked lika a million bucks.....Dang slow header companys and there apperent hatred to squars.............
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-28-2011, 11:41 PM   #492
harnalien
TruckincrazY
harnalien's Avatar
It never goes as we plan it. Good luck on getting it all straightened out. Besides the exhaust it seems like things went ok?
Old 01-28-2011, 11:51 PM   #493
85burb
85burb's Avatar
Had to fight the mounts to get them in right place but except for headers went smooth. The mounts kept trans in same place. With some adjustment left to go back ferther still. Tons forward. Wish i could have started it today but i have a factory manifold orderd that will be here at 8:45 am. So should start some time tomorrow. All i have left is msd box carb install and alt wireing. Should go smooth. Ha there i go again.......
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-28-2011, 11:56 PM   #494
harnalien
TruckincrazY
harnalien's Avatar
Awesome I am getting the dingo mounts for mine and will be using a 700r4 so I was hoping they'd work out for you.
Old 01-29-2011, 12:03 AM   #495
85burb
85burb's Avatar
Would deff recomend them.. On mine i had to loosen them tell the bolts were only in a few threads on the plate and loosen the rubber mount on the frame then install the bolt that goes threw them. Then drop engine down and tighen all bolts. As far as i can tell the rear trans mount is not stretched one way or the other. Shifted into nutral and park great. Look good too. Great quality in the manufacturing of them. Can get better pic tomorrow.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-29-2011, 12:38 AM   #496
flamingbig10
6.0 powered square
flamingbig10's Avatar
nice work
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-29-2011, 12:54 AM   #497
85burb
85burb's Avatar
Originally Posted by flamingbig10 View Post
nice work
Thanks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-30-2011, 12:28 AM   #498
85burb
85burb's Avatar
Really crappy video of running. You can deff here the cam a bit at idel and in gear. Need to set up my timing and carb little better but it runs great. No leaks on anything yet. Alt puts out 14 volts with headlights, heater, fuel pump on. Engine has 45 psi oil pressure at hot idle. Will deff spin the TIRE..just one....for as long as i want it to if i punch it from dead stop. If i would have remembered to turn fuel pump on it would have started on first crank. Had to get new starter due to rust on bendix gear not letting it go twards the flywheel. Got to disturbe someones party down the street from my bros house already when i drove by at who knows how many rpm....Sorry if it was you....Will get pics of compleat engine tomorrow.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 01-30-2011, 09:50 AM   #499
harnalien
TruckincrazY
harnalien's Avatar
So the stock manifolds fit fine? Does it have a noticeable amount of increased power? Good job!
Old 01-30-2011, 11:19 AM   #500
85burb
85burb's Avatar
Well the maniflod i have on pass side i had to nothc the frame where the collector bolts are. And had to grind on the egr port to clear. But driver side fits like it was made for it. Did not drive it very far just up and down street. Seems like it has good power. I have to set my carb and timing curve with msd box cause it kind of ran out of power. Pulled hard then flattend out. I had the smallest tuming curve the box came with in it so that may have been most of problem. It had no problem burning tire. When it broke free rpm shot up like it was in nutral. But everyone seen and hurd tire spinning. It is very very loud when you punch on it so i was easy on it most of time. Just punched it two times. After i get exhaust connected and max rpm set with box i will see what it does.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
