#476 |
Re: Extreme Powder Coating '65 C-10 Shop Truck
Just ordered some RAL 7042 ..
edited by staff |
#477 |
Man, that is going to set it off. You said you were shooting video? I look forward to that. I know how well it laid with my ghetto $400 powder gun, can't wait to see it shot proper like.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#478 | |
2 layers will not be heavy in the welds. I like to make sure my coats are even and details are visible. I don't like gloss frames, either.
#479 | |
![]() Join Date: Mar 2005
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#480 | |
The nice thing about powder is it isn't done until its baked. So you can shoot a frame, see build up in a corner or a weld, just blow on it slightly until the area is uniform, or reshoot to add areas that look light, then bake. With good product (Tiger makes nice stuff) and good equipment, you can lay powder that looks as good or better than wet paint. But if you drop a wrench on it, you won't cry. ![]() With the equipment Greg has, I can't wait to see the level of detail that frame shows when finished. Best of all it will be wet and wipe!
#481 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The powder coater I use 2 coats about 95% of the parts, but they do it a little differently. They preheat the parts, pull them out and shoot a medium coat. Let the parts cool some, then another medium coat, and then bake them for about 40 minutes or so depending on the parts. Their powder always holds up very well.
I think that RAL-7042 will look awesome on that frame ![]() A low gloss on a frame is the way to go IMO.......
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-20-2011 at 12:41 AM. |
#482 | |
Greg, not to hijack your thread, but would you mind sharing the process you'll use for shooting the frame?
#483 |
Ral 7042 from Tiger is a hi gloss 90 % gloss . Here is how we will coat the frame. We will wash it in our stainless steel 3 stage washer with Fremont 621 phosphate wash. We will seal it with Fremont 439 sealer/ rust protectant. We will then apply Cardinal Gr-533 epoxy primer ... may have to hot flock it too get it in the speed holes... jell the primer.. then topcoat it possibly 2 coats depending how it works in the speed holes. Hot flocking works well.
![]() Final bake 392 degrees for 10 minutes peek metal temp. Watch it when you coat parts hot... hotflocking.... you can really get a high mil. coverage.... which leads to orange peel issues with some lower flow powders.
edited by staff Last edited by kart34; 06-17-2012 at 09:43 PM. |
#484 |
^^^That's great info, and again, I'm just blown away at the steps that the pros use to apply powder.
I'll lock that into my memory banks, and the next time I go to the local shop, I'll ask them if they wash, seal, and prime before they shoot the powder. Also, if they use the heating/cooling process when they're laying down coats. Most of the stuff I see has excessive mil thickness in the joints, heavy particulates in the powder, and orange peel.
#485 |
Getting ready to coat today......
edited by staff |
#486 |
We carefully hoisted the C-10 frame onto the trolley system in our shop...it went into the stainless steel washer and washed with Fremont 621 phosphate wash, and rinsed. From this point the frame went into the curing oven to dry and get ready for the next step in the process. The Fremont 439 sealer can be applied hot or cold. This product works very well to also stop flash rusting.
Randy Harris running the Komatsu forklift.... I got to run the hooks... Gary Harris running the washer.
edited by staff Last edited by kart34; 05-24-2011 at 07:12 AM. |
#487 |
The frame came out of the oven hot, and we then sealed it with Fremont 439 sealer/ rust protectant. The frame will follow the path of the trolley system into the paint booth for a thorough coat of primer GR-533. I am the dude sitting in the shop stool, supervising !!!!!
Bryan Hernandez appling the Fremont 439 sealer... Jesse Hernandez and Tiffany " social media networking manager" Peterson working the video and camera.
edited by staff Last edited by kart34; 05-24-2011 at 11:04 PM. |
#488 |
All necessary holes are plugged in the frame and start the hot flocking process into the speed holes. Soon the entire frame is coated with primer GR-533 and will move to the curing oven. Dain Schultz and Daryl Bouwman rocked the primer basecoat.
edited by staff Last edited by kart34; 05-24-2011 at 07:07 AM. |
#489 |
This is the curing oven...these next photos show the hot flocking and this worked very well to coat the space between...and finally the frame complete, smoothly and perfectly primed!!!
edited by staff Last edited by kart34; 05-24-2011 at 07:06 AM. |
#490 |
Damn, can't wait to see some color! I only wish I had your shop! Nice work, that primer looks awesome.
#491 |
60-66 Nut
That frame is looking very nice. You obviously have a first class powder coating shop. I'm anxiously awaiting to see some color on this frame.
#492 |
Today we will block out some areas... scuff the chassis... hot flock coat the speed holes... and give it the Tiger Drylac Ral 7042 topcoat.
edited by staff |
#493 |
What does the term "hot flocking" mean?
#494 |
applying the powder when the part is hot ( Hotflocking) ... for hard to coat areas it will melt on impact
![]() blocking out the chassis now will be video taping this PM
edited by staff Last edited by kart34; 05-24-2011 at 09:32 AM. |
#495 |
I never had much luck hot flocking with my home setup. The powder didn't seem to melt fully and left a lot more texture than I was going for. Can't wait to see how that Tiger powder lays with that high speed gun you have.
#496 |
If it orange peeled ? you need to turn the gun down... added too much material. Did you do a powder mil. reading?
edited by staff |
#497 |
2010 Gema OptiFlex 100,000 volt. powder gun.
edited by staff |
#498 | |
#499 |
![]() Join Date: Nov 2008
looken good
#500 |
Chassis is in the bake oven... stay tuned !!!!
edited by staff |
Tags |
'65, c-10, carter hickman designs, extreme powder coating |
