Old 03-21-2013, 01:41 PM   #476
coulter
coulter's Avatar
Re: DLoE's Dropmembered 65 StepSiDe Build
that front/rear bumper looks pretty cool!!!
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 03-21-2013, 02:01 PM   #477
ChevyFreak60
ChevyFreak60's Avatar
Bumper looks awesome bro!
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 03-21-2013, 11:09 PM   #478
Dinos63
chevy only
Dinos63's Avatar
Originally Posted by denz72 View Post
yeah..John and I are leaving La Habra probably around 1:00 p.m. that Friday and heading down let us know if that works for you I haven't heard when anyone else is leaving
Originally Posted by DLOE65 View Post
yeah definately making del mar, you guys going? lets get a crew together and roll!
i am coming in on friday with my dually
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 03-22-2013, 12:41 PM   #479
DLOE65
DLOE65's Avatar
sweet! I booked my room today too!
DLOE65 is offline   Reply With Quote
Old 03-28-2013, 07:37 PM   #480
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I think somthings wrong. You should be making alot more power than that!
Expert racers that ride these say that yer setup should make over 200 hp and
over or around 280 torque. Somthings wrong. According to factory 292 stock
makes 265 torque and 150 hp. Somthing not right!
TJ's Chevy is offline   Reply With Quote
Old 03-28-2013, 08:27 PM   #481
paintman
I mentioned this as well a few posts back. I spoke with an inliner named Walt Pearce. He has a 250 that he drag races out in Washington State. From what I could gather from people who know him, he is "the man," when it comes to 250-292 race engines. He is also the guy responsible for making the new harmonic balancers for these motors. Anyway, he told me that the biggest mistake guys are making is when they put lumps in the head they don't use a big enough cam. He said most guys just put in the Clifford cam and think they will be good to go.
However, what people are missing is that the Clifford cams are only designed for a standard head and their intakes, not for the additional flow that the lumps provide. Furthermore Walt went on to say that when you add lumps you not only need more cam, but then you must also have more carb. Apparently the Holley 390 is fine for just a standard say Clifford or Offy intake.
Walt also told me that with lumps a 650 minimum on the carb but ideally you should be running a dual carb setup. This is because both the Clifford and Offy intakes have an inherent flaw. That is because of their design they do not flow the fuel supply evenly to all the cylinders. It seems as if the middle cylinders run lean on these sixes. Just some food for thought.
paintman is offline   Reply With Quote
Old 03-28-2013, 10:57 PM   #482
DLOE65
DLOE65's Avatar
I'll post the specs of my cam later when I get home. dont have lump ports either. if feels like it has power, hmmm....
Old 03-28-2013, 11:01 PM   #483
DLOE65
DLOE65's Avatar
welded on some license plate mounts to my rear bumper and slapped a coat of paint on her.
Old 03-29-2013, 01:06 AM   #484
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
well had the engine tuned and Dyno'd. . 137.04 HP and 193.19 Max Torque think I should have went with the 600 Holley instead of the 390. guys at the shop said to run it for awhile and see how I like it.
That is bizzar! I almost went with a clifford cam and high flow lumps! Are you using
a lump port head? You would think that cliffords cam would work well do to the high lift! Do you have any cam reccomendations when using the lump port head?
Old 03-29-2013, 01:27 AM   #485
DLOE65
DLOE65's Avatar
no im not running lump ports.
Old 03-29-2013, 05:45 AM   #486
Jmorales3181
Jmorales3181's Avatar
Bumper came out nice!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 03-29-2013, 12:05 PM   #487
Neatbeard
Neatbeard's Avatar
Damn dude this truck looks awesome!! Ive been thinking about painting mine brown at some point and this is making me think that it'd work....
Good build dude.
Neatbeard is offline   Reply With Quote
Old 03-30-2013, 10:54 PM   #488
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Are you sure your cam did not go flat? Cause my old stock 292 seems to have
alot more torque and hores power than that! Some say that the clifford cam
is not very good quality. I went and looked at a clifford cam in person and they
seemed to be good quality, but I know that a 292 should have alot more power
than that. Especially since the clifford cam is high lift. And a holley 390 is a good
carb for that. If you think about getting a new carb I would get an edelbrock
600 cfm double pump carb 4 barrel, thay are better quality by far than the holley.
If your cam is flat you could get a delta cam they are great for racing and good
quality.
Old 03-31-2013, 11:57 AM   #489
socallowboy
Del Mar Right on! Loking forward to checking out your truck in person and meeting you-Rob
socallowboy is offline   Reply With Quote
Old 04-02-2013, 12:07 PM   #490
DLOE65
DLOE65's Avatar
thanks Rodrick (MadRods) for the Stepside sticker!
Old 04-02-2013, 12:28 PM   #491
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
No problem! If Dloes valves get famous hook me up with a sticker too
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 04-02-2013, 12:42 PM   #492
DLOE65
DLOE65's Avatar
haha you got it!
Old 04-02-2013, 12:47 PM   #493
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Sweeeet! ya gotta get a hook me up with a couple stickers too!!ha ha.
Old 04-02-2013, 01:33 PM   #494
xxlf250
xxlf250's Avatar
such a nice step.....cant wait to see it this weekend
xxlf250 is offline   Reply With Quote
Old 04-03-2013, 01:18 AM   #495
Dinos63
chevy only
Dinos63's Avatar
x2
Old 04-03-2013, 01:32 PM   #496
DLOE65
DLOE65's Avatar
alignment shop this morning, man I cant believe how much smoother it rides now, should have done that earlier lol.
Old 04-03-2013, 10:38 PM   #497
paintman
Hey DLoE!!!!!!!!!!!!!! I was hoping you could help me out. I am looking for a 292 water pump like yours. Are you using the original pump (just cleaned up),that came with your motor, or did you buy a new one for your build. Where can I find one? Thanks man! Looking killer!!!!!!!!!
Old 04-04-2013, 12:38 PM   #498
DLOE65
DLOE65's Avatar
Hey paintman, its a new one I got from the truck shop in orange. you can get them at regular autoparts stores too. they are still avail.
Old 04-05-2013, 11:01 AM   #499
TommyDuncan
Nice build!
This is the first DMed step side build I have read. It came out great!
Couple questions:
Did they give you any other dyno sheets? I was curious how much torque it made at lower rpms? I always thought straight 6's were known for that. I've owned and built a few Jeep straight 6's and they were pretty much done by 3200rpms, which is about where your dyno pull started. I am also assuming that is rear wheel horsepower?
I worked at a high end engine shop with 3 engine dynos and a chassis dyno. Street cars rarely made the power numbers that they were expected to, particularly on the chassis dyno.
You said it feels like it makes good power. Other than maybe some carb experimenting I would just be happy with it. You don't seem too worried about it actually
If you needed to how much lower could the bed floor be? I told the old lady I brought one more car home because I really needed a truck for trips to Home Depot and the plant nursery
...I also have dirt bikes so a little more depth might be a good idea for me.
TommyDuncan is offline   Reply With Quote
Old 04-07-2013, 11:35 AM   #500
DLOE65
DLOE65's Avatar
good guys pics..
