Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 09-02-2012, 05:48 PM   #476
tsnow678
Re: Crash's 72 K10
The anodizing is a real pain to get off. What about a replacement outer? Or powdercoating the old one? I had a 63 Chevy II and like to never got the aluminum to the point of polishing and then it was constant maintenance. Just my .02!
Link to my 69 Camaro 6.0/T56 swap:
http://ls1tech.com/forums/conversion...69-camaro.html
tsnow678 is offline   Reply With Quote
Old 09-02-2012, 05:58 PM   #477
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
I was afraid of that.. I have a nice grill now.. It has just lots it luster.. I will keep looking to see what others have done..
Thanks..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 09-02-2012, 06:03 PM   #478
VA72C10
VA72C10
VA72C10's Avatar
Re: Crash's 72 K10
Looks good on the patches. It's always a learning process and little differences can help a lot. I also keep having to remind myself to tack and wait...have another project to work on or take some pictures between tacks to let it cool down to keep the possible warpage to a minimum...
On the anodizing....search here and youtube for videos of polishing aluminum. Use ZEP brand drain cleaner to strip the anodizing off...then the aluminum can be worked and polished...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-02-2012, 07:16 PM   #479
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Crash's 72 K10
First, if you have oil canning on the bedside around the light, you can remove some of that by heating the high (expanded) area with a propane torch then quench it with a cold wet rag. This will tighten it up. I was leary of doing this myself but I had a severely smashed in bedside and I could take more chances with the repair. It worked fine and didn't add any warping and no more oil canning.
But here is the cautionary note: adding heat to the panel could cause warping. Do this at your own risk. If you look up dent removal with a torch on youtube you can see it being used. Not the greatest for dents, but it works to shrink the metal.
Nice job on the patches though. They look good.
Second, I had similar problems with my aluminum surround. I sanded out the scratches and polished those areas up. To me it gave it a patina look that wasn't all that noticable unless you were right there looking down on it. I did not do the entire surround to even it out because I had already decided to replace it with one of the new chrome steel versions. They are much more durable than the aluminum, which will scratch easily and usually have a dull look no matter what you do. Some places sell the chrome steel version for the same as the OEM style, top banana for example did when I bought mine this spring.
hgs_notes is offline   Reply With Quote
Old 09-03-2012, 04:57 PM   #480
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Got the inside of both bedsides and both sides of the front bed panel primered..
Next week I will primer the outside of the bedsides and start on the body work…
Mark
Crash's 69 4x4 SWB
Old 09-03-2012, 06:05 PM   #481
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
Amazing how fast you are moving on this Mark. Keep it up.
mcbassin is offline   Reply With Quote
Old 09-03-2012, 07:10 PM   #482
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks Mike... still have a long ways to go..
Mark
Crash's 69 4x4 SWB
Old 09-03-2012, 08:03 PM   #483
mud.man.rj
mud.man.rj's Avatar
Re: Crash's 72 K10
Sure is looking nice, glad to see it coming together, each step is a relief isn't it.
mud.man.rj is offline   Reply With Quote
Old 09-04-2012, 01:02 AM   #484
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: Crash's 72 K10
What color do you plan to paint the truck??
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 09-04-2012, 05:31 AM   #485
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Black is the plan right now.. but I am open to other ideas..
Mark
Crash's 69 4x4 SWB
Old 09-04-2012, 05:32 AM   #486
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
thanks.. yes getting the bedsides back on the floor felt good.
Mark
Crash's 69 4x4 SWB
Old 09-04-2012, 05:34 AM   #487
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
thanks for the tips.. I will check into the chrome steel option..
Mark
Crash's 69 4x4 SWB
Old 09-04-2012, 05:37 AM   #488
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
yes, it helps if you slow down and take your time.. thanks for the tip on stripping the anodizing..
Mark
Crash's 69 4x4 SWB
Old 09-04-2012, 11:15 AM   #489
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
Very nice progress Mark. You are making this truck restoration look way too easy....
looking forward to your next update
Old 09-04-2012, 09:39 PM   #490
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks Mike.. Looking forward to see more of your build when time allows..
Mark
Crash's 69 4x4 SWB
Old 09-07-2012, 10:19 AM   #491
in deep 72
in deep 72's Avatar
Re: Crash's 72 K10
Hoping to tear mine down this winter.....Your motivating me
in deep 72 is offline   Reply With Quote
Old 09-08-2012, 11:24 AM   #492
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Wired up the micro relays for the cruise control. Worked out well…
About to go out and start bolting the bedsides to the floor and trial fitting the steering column.
Mark
Crash's 69 4x4 SWB
Old 09-09-2012, 05:50 PM   #493
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Good luck with your build
Mark
Crash's 69 4x4 SWB
Old 09-09-2012, 05:59 PM   #494
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Trail fitted the steering column and wheel.. I think it looks good..
Next up is:
Coming up with a firewall cover/grommet for the PCM wires.
Redoing the relays for the Cruise Control.. They work fine as they are but I want to redo them so that they will work better with the DD gauge cluster.
Figuring out what to do with getting fuel into the new tank. Thinking of putting some type of fuel cap in the bed of the truck near the left inner fender and bedside.
Mark
Crash's 69 4x4 SWB
Old 09-15-2012, 04:59 PM   #495
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
OK.. final post on the Cruise.. Decide to put the relays into a project case and clean everything up. I added a third relay to feed to cruise input on Dakota Digital gauge set.
Just finished meeting with Kyle (screaminchevypickup) to discuss him finishing the bodywork and paint. I enjoyed visiting with him and discussing the process. I am really leaning towards letting him do it..
Need to order the door seals so that I can start fitting the doors and the other gaps before I tear it all down. Anybody have suggestions on where the best place to get the door seals from?
Mark
Crash's 69 4x4 SWB
Old 09-15-2012, 07:25 PM   #496
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Crash's 72 K10
I would suggest ordering from Early Classic Enterprises. They have great customer service and they have only the best products.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 09-15-2012, 07:58 PM   #497
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks.. I will check them out.
Mark
Crash's 69 4x4 SWB
Old 09-15-2012, 08:37 PM   #498
fakerwade
fakerwade's Avatar
Re: Crash's 72 K10
It's been a while since I checked into this build,,, wow, lots of progress (and pictures). Looking good!! I like the work you did on the side marker lights, I think I'm going to try to "french in" some 72 side marker lights on mine. I also like the steering wheel, and cruise control for those long trips, pretty cool! Keep it up!!
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 09-15-2012, 09:58 PM   #499
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks fakerwade... Looking forward to you getting back on your build..
Mark
Crash's 69 4x4 SWB
Old 09-15-2012, 10:16 PM   #500
tsnow678
Re: Crash's 72 K10
I am not sure about the truck weatherstripping but if its anything like 69 Camaro seals I would buy Metro brand and stay away from SofSeal. The Metro is more like OEM. I used a SofSeal trunk lid seal and liked not got the trunk to shut. After it did shut it stood the lid above the quarters a good 1/8" of an inch even after days in the sun. It is Metro all the way for me!!!
