Old 05-14-2016, 05:22 PM   #476
racecougar
racecougar's Avatar
Re: Bringing the '65 back to life
One done, and one in progress.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 05-15-2016, 05:24 PM   #477
racecougar
racecougar's Avatar
You know what's boring? Sanding. Almost done with the second one.
Old 05-15-2016, 08:42 PM   #478
RANDY COX
RANDY COX's Avatar
Amen to that I hate sanding...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-21-2016, 04:34 PM   #479
racecougar
racecougar's Avatar
Finished blocking out the filler and shot some primer on the tubs today.
Old 05-22-2016, 05:03 PM   #480
racecougar
racecougar's Avatar
It was a day filled with other priorities, but we were able to get the first coat of high build on the tubs. A few more coats, some blocking, and they'll be ready for paint.
Old 05-25-2016, 08:31 PM   #481
racecougar
racecougar's Avatar
Sand it out and shoot it again.
Old 05-27-2016, 03:07 PM   #482
racecougar
racecougar's Avatar
Broke out the torch today. Had to warm a few areas up to straighten them out.
Old 05-28-2016, 03:06 PM   #483
racecougar
racecougar's Avatar
Fixed a substantial crease on the driverside panel, then started to blow the bed apart and prep the inside for paint.
Old 05-28-2016, 09:30 PM   #484
Ta2Don
Ta2Don's Avatar
Finally catching up on your progress
Looking great
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 05-29-2016, 03:25 PM   #485
racecougar
racecougar's Avatar
Thanks, Don!
Dad blasted the tight spots/corners of both bed sides while I prepped the front panel and finished cleaning up the inside of the drivers bed side, then we laid down the first coat of primer.
Old 05-30-2016, 05:54 PM   #486
racecougar
racecougar's Avatar
Day 249: Prepped and primed the inside of the passenger bed side. It should all start seeing paint next weekend.
Old 05-31-2016, 06:03 PM   #487
CURSED GEARS
I've enjoyed all 20 pages. Keep it up!
CURSED GEARS is offline   Reply With Quote
Old 06-04-2016, 03:39 PM   #488
racecougar
racecougar's Avatar
Thanks!
We shot the black on the front panel, inside of the bedsides and inside of the tubs today. Well over three hours of prep for 20 minutes of shooting.
Old 06-05-2016, 07:19 PM   #489
racecougar
racecougar's Avatar
Done painting the inside of the bed. We'll shoot some bed liner in the wheel tubs and between the inner and outer bedsides next weekend, then it can be reassembled the weekend after.
Old 06-12-2016, 01:43 PM   #490
racecougar
racecougar's Avatar
Got a very early start at the shop this morning to beat the heat and shoot the bedliner. We coated the inside of the tubs and between the inner/outer sheetmetal on the bedsides.
It goes back together next weekend!
Old 06-18-2016, 03:25 PM   #491
racecougar
racecougar's Avatar
Dad routed the bed wood at the wheelwells and touched up the paint in all of the bolt holes while I blocked out the tubs for another coat of high-build today.
Old 06-19-2016, 03:16 PM   #492
racecougar
racecougar's Avatar
Reassembled and ready for body work.
Old 06-24-2016, 06:55 PM   #493
racecougar
racecougar's Avatar
Back to my favorite activity. You know, for a build that is "not supposed to be a show truck", there sure has been a lot of blocking.
Old 06-25-2016, 07:22 AM   #494
Ta2Don
Ta2Don's Avatar
Been awhile since I have been checking in... Looking great and all the hard, tedious work will pay off in the end... You're killing it!
DON
Proverbs 27:17
Old 06-26-2016, 01:50 PM   #495
racecougar
racecougar's Avatar
Thanks Don. We're still plugging away at it.
We took a break from the bed today to make the brake lines for the rear axle. We used Copper-Nickel D.O.T.-rated tubing and stainless stone guard. The tubing was very easy to work with, and this flaring kit was soooo much better than the cheapo flaring tools we've used in the past. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 07-16-2016, 06:34 PM   #496
racecougar
racecougar's Avatar
Took a couple of weeks off for a family trip to the Southwest, but I was back at it today. Finished blocking out the tubs. They should see paint next weekend.
Old 07-23-2016, 12:45 PM   #497
racecougar
racecougar's Avatar
Shot the first coat of satin black on the tubs this morning, then knocked out the rest of the brake line under the bed. The truck is going to have to roll outside for a bath before long.
Old 07-24-2016, 10:29 AM   #498
racecougar
racecougar's Avatar
A little early morning paint application.
Old 07-30-2016, 07:48 PM   #499
racecougar
racecougar's Avatar
The tubs are installed. Please disregard the dust. It'll get a bath after the body work is finished.
Old 07-31-2016, 10:43 AM   #500
Ta2Don
Ta2Don's Avatar
Diggin' the progress!!!
DON
Proverbs 27:17
