Old 07-08-2015, 11:43 AM   #476
Bomp
Bomp's Avatar
Re: 55 Wagon Progress
Sat down with my morning coffee to get caught back up, read through the last couple of pages and yup, mind blown ready to start the day.
Great work
Bomp is offline   Reply With Quote
Old 07-09-2015, 10:40 PM   #477
MP&C
MP&C's Avatar
Thanks for the comments guys!
Well, we had gotten some more sanding done......
.....and since it was still early in the evening, mixed up some more epoxy....
Robert
MP&C is offline   Reply With Quote
Old 07-10-2015, 09:49 AM   #478
4mulaSvaliant
4mulaSvaliant's Avatar
Ok so I have sat here for probably 2 hours reading through this entire thread! Hahahah.
First i have to say what everyone else has lead with as well. Your attention to detail makes me happy and it isnt even my car! I consider myself quite novice with this type of work, but at the same time, I have put a few "notches in my belt" and have some decent projects behind me. I have started to make a good name for myself and my attention to detail is what has made it happen. So as I said before.... I love the attention to detail.... Thousandths of an inch details that most would never notice obviously bother you... Its nice to witness is all.
Beyond that... the making of tools is another "hobby" I am fond of. To see your creative mind find solutions to some of the tight spaces, or how to accomplish a particular shape is inspiring.
Lastly, thanks for showing all of the steps in your process and methods. Ill be honest I have been in a bit of a "writers / builders block" on the 28 Ford Roadster I am building for a friend because of the designs and shaping I presented to him. He loved it, and I have been hesitant to start as I wasnt sure with my limited tools that I could accomplish them. After reading through this I am ready to slide out from behind my desk right this moment and head home to start it back up! Your thread and methods have motivated me and I already feel confident that I can make it happen.
So a huge thank you from yet another on looker! Your helper is one lucky guy to have you as a personal one on one mentor for this art!
64 LWB to SWB Step build. Daily driven!
http://67-72chevytrucks.com/vboard/s...d.php?t=647168
4mulaSvaliant is offline   Reply With Quote
Old 07-15-2015, 12:26 AM   #479
MP&C
MP&C's Avatar
Thanks for taking time to post fellas!
Doesn't seem like much to show, we're still sanding away....
Got about half done with the tail gate and remembered we needed some holes drilled in the new skin for the emblem. Only issue was that I had done some spring cleaning earlier this year and the original skin with the hole pattern and location was now gone. So I sent an email to Mikey at The Stainless Shoppe, as he had an original, and he got me squared away... Thanks Mikey!
I located the hole for the center alignment pin first, and planned on using some spotters for the remaining 4 holes... Some measurements were taken to insure the emblem was on straight, and then some "backstops" used. The spotters come in a set of various sizes, and typically you never find the exact size you need...
These will go in some 10-24 threaded holes on the emblem. The closest size was the 1/8" spotters, so we'll need to adjust the fit..
A couple wraps of fineline tape and we now have a snug fit so the spotters don't fall out..
Then the emblem is located on the tail gate with the center alignment pin, then the back stops. The emblem is pressed onto the tail gate, and the spotters leave their mark on the epoxy paint finish..
Next, the studs are installed finger tight using sleeve retainer. This will hopefully keep them from spinning inward any further risking possible damage to the chrome bezel...
The nuts that come with the emblem are the split thread variety, and I had some threaded ones left over from the Fairlane build, that also are slightly larger in diameter, which may help out as the emblem also serves as a lift handle..
Holes drilled and emblem fitted
Robert
Old 07-15-2015, 08:54 AM   #480
oldman3
oldman3's Avatar
Panels looking good, and the emblem came out great...Jim
oldman3 is offline   Reply With Quote
Old 07-15-2015, 08:57 PM   #481
duallyjams
duallyjams's Avatar
Huh blind hole spotter who knew, definitely not me, learn so many cool little tricks.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-18-2015, 08:27 PM   #482
MP&C
MP&C's Avatar
I was blocking out the tailgate the other day and had a "halo" effect appear in the epoxy, shown below just to the right of the latch hole. This has a light skim of Evercoat 416 beneath the epoxy in that area. It was nice and flat while in bare metal, after spraying epoxy, after blocking the Evercoat/ before spraying the last coat of epoxy. I was baffled at what would cause such a nicely formed circle in the paint...
Even scratched the area to see if there was any softness to the Evercoat, but no..
Here's the panel in bare steel before paint and after first coat of epoxy...
No dings, or defects otherwise seen. I had posted a query on the SPI forum to see if anyone had ever run into this. I don't know why I didn't think of this first, but it was suggested to: 1) look inside 2) only time this type of defect had been seen was dropping screwdriver inside door and left similar mark on outside of door bottom after sanding.
So in full investigative mode, I first measured the distance of the defect from the turn latch hole..
The Halo is approx. 3" away from the handle hole..
Measuring that distance on the inside shows.....oh wait....what's that bare metal?
As soon as I saw this I realized there had only been one thing inside that could have caused it... the painting fixture we made..
This was made to hold the tail gate in correct alignment as on the car for painting. I had radiused the lower bar but failed to do so on the top one. A check of the skin with body sweeps shows that a #15 sweep is about correct, so it was used to verify some relief grinding on the top bar...
As added insurance, some truck cap gasket seal was added to further isolate the issue on both top and bottom bar....
On a positive note, glad to find this issue in the primer stage......
But let's back up a second and look at this picture, it should have been my red flag. Where the second mark to the left in the picture was not as round, looking at it now does show a rather symmetrical device was causing this..
So please use my lesson in dumassery to prevent a similar occurrence.
Robert
Old 07-19-2015, 05:20 PM   #483
MP&C
MP&C's Avatar
Another job in the shop, here's one of the downfalls of the insulation blankets the factory used above exhaust systems...
Nice moisture traps and rust generators. All the used beds found either had similar rust issues or the lower quarters rounded under where the salvage yards had removed them and set them down on the ground. So we went back to the local dealer and ordered the bed floor and new cross members. We have a couple cross members that still haven't arrived, but we can get started in prepping for epoxy primer on the parts we do have..
Scuffing up the floor using 400 grit. Here's the new apprentice for this job, my niece Katie. (her truck) She's not afraid of work and needed little instruction.
All scuffed, now to wait on the cross members to come in..
Meanwhile Kyle and I have continued blocking body parts for another dose of epoxy...
Robert
Old 07-19-2015, 09:25 PM   #484
duallyjams
duallyjams's Avatar
So if your name starts with a K you can hang out in the shop with Robert and have fun while learning.
James
IG duallyjams
Old 07-24-2015, 09:32 PM   #485
swamp rat
swamp rat's Avatar
Been a while but just caught up. Nice work aws always!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-25-2015, 01:51 PM   #486
Advanced Design
Advanced Design's Avatar
Tons of great work, cool ideas and useful tools. Thanks again for continuing to share.
Advanced Design is offline   Reply With Quote
Old 07-26-2015, 11:40 PM   #487
MP&C
MP&C's Avatar
It would seem so....
Got some more SPI Epoxy sprayed, here's the parts for Katie's truck that she prepped...
....and some more on the wagon parts....
Robert
Old 07-27-2015, 08:56 AM   #488
oldman3
oldman3's Avatar
Parts look good...Jim
Old 08-04-2015, 10:40 PM   #489
MP&C
MP&C's Avatar
Thanks Jim!
Tonight's post offers some blocking pointers.
We had already done a couple sessions of priming/blocking the door across to the quarter and to the fender, all installed on the car. After this, more primer and put a perimeter of tape on the door skin. Now block separately, and the tape allows you to block the door and keep off the edge to prevent losing your match to the fender/quarter.
I don't stick with 45* angles, if you want to keep a long direction flat, you need the long block to better follow that direction. So change up to some sharper angles, about 30* off the long direction every now and then. Work one end to the other, consistent spacing, consistent angle, end to end. Then alternate to passes in the opposite direction.
Once done, and the inner part is good and blocked, now remove the tape and GENTLY block to the edge, taking care to not pull down at the edge and round things back off again. Whatever hand is holding the block make sure it is minimal pressure and stays on the door skin. In other words, no pressure pulling down past the edge.
One other point, to keep the inner end of the sanding block from sanding out all your hard work in the center of the door, put a wrap of tape around the end of the sanding block that is towards the center of the door. This helps that end to glide across the center of the door without cutting primer there.
Now to show the importance of the long board..
We had done some blocking with the 27" AFS and seemed to have two high spots with a low in the middle of the door..
Note the high areas marked by the green tape...
Now we can see that as the sander is moved to the left, the left portion of the AFS is over the high spot on the left, and a bit more movement and the right portion of the AFS will start dropping into the low void. Effectively, this is still cutting material out of the low, keeping it low.
Looking at the next size up, a 36" AFS....
Here we can see this one does a much better job of spanning the high spots and staying up on top, for a more effective job of knocking down the highs and leaving the low in the center alone...
After a few horizontal passes at slight angles, like so with the 36".......
We follow up with some vertical passes at slight angles with the 27".... all rods removed to better follow the contour. Then alternate back to the 36 and another horizontal session..
Robert
Old 08-06-2015, 01:31 AM   #490
swamp rat
swamp rat's Avatar
Nice work, wish you could do my truck next.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-09-2015, 07:18 AM   #491
MP&C
MP&C's Avatar
Got a 54 Divco milk truck coming in next, sorry.
Well, the shop truck has left the building..
Sold it today, now have a bit more breathing room in the shop..
.....and another dose of epoxy
Robert
Old 08-22-2015, 11:38 PM   #492
theastronaut
theastronaut's Avatar
So you're not using high build? Just make the filler work slick enough and then epoxy? Or does the SPI epoxy build more than other epoxies? Been wanting to try SPI epoxy...
theastronaut is offline   Reply With Quote
Old 08-23-2015, 12:45 AM   #493
NASTY-LSX
AWESOME. You have MAD SKILLS..
NASTY-LSX is offline   Reply With Quote
Old 08-23-2015, 07:25 AM   #494
MP&C
MP&C's Avatar
John, I've found both H/K and SPI to have a decent amount of build. Not as much as spraying Slick Sand, but I'd venture a guess that SPI on SPI would have less adhesion issues and be more stable overall than mixing products.
Thanks Nasty!
Robert
Old 08-25-2015, 02:43 PM   #495
Low Elco
That's good to know- Nason's epoxy is only good for a scratch coat. About the consistency of basecoat. Parts look fantastic.
Low Elco is offline   Reply With Quote
Old 08-26-2015, 10:22 AM   #496
theastronaut
I'm definitely going to try some SPI. We've been using Slick Sand over DPLF within the 7 day recoat window, and the SS etches into the epoxy pretty hard so adhesion hasn't been a problem. But if SPI builds enough then we could skip the SS step, at least on some areas. The one thing I really like about SS is you can get the size/shape/diameter of your edges and body lines all even since there is plenty of material to work with, especially when blocking body lines across multiple panels. But, sometimes you don't need that much of a build primer if the metal/bodywork is already close before priming. It'll be interesting to try it out, I'm always looking for anything that'll make for a better job.
Old 08-26-2015, 12:58 PM   #497
Low Elco
If you don't want that much build, look at Evercoat G2. Same stuff, not as thick. Moves a bit easier and lays down better. I usually throw a splash of thinner in my SS to get it movin' a bit easier, as it were. I'm interested in the SPI stuff as well.
Old 09-12-2015, 05:48 PM   #498
MP&C
MP&C's Avatar
Well there has been a slight break in the updates, as I've been in Okinawa for about a month. Not to fear, Kyle has been plugging away on the wagon, it even has a floor in it, as you can see here...
He did get a quite a bit of blocking done while I was gone....
And did get some wet sanding done on a few of the interior trim pieces. Today he started on the rear floor, part of the problem with welding a flat plate is that it doesn't stay flat. The plug welds to secure the floor to the bracing beneath caused some shrinking, which resulted in the metal between bulging outward, some up, some down. Looks about like the Atlantic on a calm day.
Today, as I was going to be wet sanding, he was going to try some torch shrinking. To better make this a one person job with minimal risk of open flame, we thought to give the "electric" torch a go.
The plastic dust pan served as a tray to hold the wet rag, keeping it in closer proximity to where it was needed and attempt to limit the amount of water elsewhere. The results showed quite an improvement, and it's in need of some bumping at this point..
But alas, the gas tank is in the way, so we will likely get the body back on the rotisserie here soon in an effort to get the remaining prep prior to paint completed.
Meanwhile, I was wet sanding and couldn't find the squeegee, so a trip to the local Ace Hardware at lunch, and we had a replacement. Works well, and no metal hardware on this new one to add any scratches....
Exterior of the hood is about done...
Robert
Old 09-12-2015, 07:47 PM   #499
duallyjams
duallyjams's Avatar
I was just thinking today, wonder how Kyle progress was coming along, get home from work and poof there's a update.
James
IG duallyjams
Old 09-12-2015, 11:53 PM   #500
Bomp
Bomp's Avatar
Looks great. Was thanking you'all today when I was welding in my dash modifications, blending & bumping.
Thanks for all the helpful tips
