Closed Thread
Old 04-02-2014, 09:32 PM   #476
veedubshafer
Re: What did you do to your truck today? Chapter II
Originally Posted by Econman View Post
Pics????
Me?
veedubshafer is offline
Old 04-02-2014, 09:43 PM   #477
Econman
Econman's Avatar
Yes, your truck you drove for the first time...
Econman is offline
Old 04-02-2014, 09:49 PM   #478
Econman
Econman's Avatar
I partially disassembled my stock distributor and thoroughly cleaned every individual piece. Tossed the points and condenser in the trash. Going with the Crane XR-i points conversion kit.
Econman is offline
Old 04-02-2014, 10:17 PM   #479
colgad
colgad's Avatar
Pulled the truck outside into the sunshine to work on it in the light for once. Hopefully tomorrow the driver fender install.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 04-02-2014, 10:19 PM   #480
veedubshafer
No it's nothing out of the ordinary. Maybe someday I'll post some.
Old 04-02-2014, 10:30 PM   #481
Bennett68C10
Bennett68C10's Avatar
Wow nice looking truck, do you have a build thread for it?
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 04-05-2014, 12:45 AM   #482
texjake
texjake's Avatar
I got the dash pad mounted, the center speaker installed, the stereo installed, the center A/C vent painted and installed (the chrome paint had flaked off so I repainted it black to go with my theme) & got the ash tray put back in. Finally making progress, slow & steady wins the race right?...so I have heard. Just takes more time going back in with after market items. They don't fit like the original stuff did. My dash pad seems more rubbery & is about a 1/4" short on both ends and the bracket for the dash speaker sure does not fit like I wanted it to, had to bend it to make it fit which took half an afternoon to get it to fit just right.
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 04-05-2014, 01:13 AM   #483
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by texjake View Post
[SIZE="3"]I got the dash pad mounted, the center speaker installed, the stereo installed, the center A/C vent painted and installed (the chrome paint had flaked off so I repainted it black to go with my theme) & got the ash tray put back in......
Looks really good. One day, I'm going for one of those radios. To keep the stock look, I sliced off almost everything behind the
"face" of the radio. Not so good for tunes. But I was back given about a bazillion bucks worth of electronics that I put in a home
made box/console under the dash.
Not the best set up, given that it turns out that I generally don't care much about Bluetooth/GPS/XM/DVD/FM/CD library/hands
free cell phone/AM-FM while driving the truck.
But a nice gesture by a friend. And so, in she went... into my sort-of cobby, home made box!
All that stuff running through fifty whole bucks worth of speakers.....
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 04-05-2014, 01:34 AM   #484
texjake
texjake's Avatar
I like the center box. Looks clean. I went with the Custom Autosound USA-230 because my old radio was AM only & I wanted something with FM too. Plus it has the AUX jack to plug in my iPhone. And because it seems that everything in & behind the dash was either broken or deteriorated. So almost everything got replaced or refurbished in & behind the dash.
texjake is offline
Old 04-05-2014, 09:06 PM   #485
Ridgeclimber
I finish the final sanding on the exterior of the cab and door jams. I then put the self levelling seem sealer on the front drip rail.
Ridgeclimber is offline
Old 04-06-2014, 01:33 AM   #486
Willys47
Willys47's Avatar
did a test fit the of box
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline
Old 04-06-2014, 02:38 AM   #487
66pnl
66pnl's Avatar
All I wanted to do was seal up a couple of water leaks, but of course I couldn't stop there.
66pnl is offline
Old 04-06-2014, 02:42 AM   #488
66pnl
66pnl's Avatar
Dug out a lot of junk from the cowl/kick panel vents. Sand blasted and epoxy/high build primed the cowl panel and new antenna.
66pnl is offline
Old 04-06-2014, 06:58 PM   #489
ironbutter
Had a couple buddies over to pull the front clip... New 383 and Trans swap on deck...
ironbutter is offline
Old 04-06-2014, 07:08 PM   #490
Motoxrrar
Sweet ! Nice gmc love them
Motoxrrar is offline
Old 04-07-2014, 06:18 AM   #491
71Dually
71Dually's Avatar
A couple days ago I dragged home an Eaton HO72 with a 14BFF brake conversion upgrade from the local pick your part. I had to drag it home cause with those huge drums it was real heavy and I couldn't carry it all by myself. The brake conversion was done right there in the junk yard and I snagged the complete axle as seen below for just under a whopping $131.56.
The brakes were pulled from a 1982 Step Van with the JB8 brake option and are 13" x 3.5" verses the Eaton's original 13" x 2.5" setup. This larger rear brake system also has larger wheel cylinder bores for additional stopping power.
The rear end has 4.56 open gears and the 14 bolt drums are beyond tolerance but I know they fit and I was planning on purchasing new drums for the final install on my truck anyway.
The quest for the 14BFF brake swap started while fixing a leaky axle hub seal in early January and discovering the unobtainable original Eaton drums on the truck were out of round and beyond tolerance.
I went to what I call "The Mens Mall" to window shop and browse for parts to complete an HEI upgrade and this Eaton jumped out at me from under a 1970 C30. It jumped out so hard it darn near knocked me over. Needless to say, now I want to put the rest of the JB8 option on my 71 C30 with the larger front rotors, bigger piston calipers and the hydra boost system to boot. This big brake upgrade was never a thought in my original plans for the truck but it just seems like one thing leads to another.
But this axle and the brake upgrade is a desirable another and this little deal just wouldn't stop screaming "Daddy, take me home, now!!! I don't want to get crushed and made into a Kia Sorento or a poor fitting imported reproduction part!!!".
I forked over the required adoption papers without hesitation. In all the excitement I forgot all about ignition parts. But tomorrow is another day.
Oh and what I did today was get the lights all vehicle code approved after completing the fabrication of an ICC bumper.
This is what I ended up with today:
The above photo was a continuation from this late January configuration:
That all began like this with a temporary light bar to retain at least a minimal bit of the required rear lighting:
The temporary light bar photo was taken on December 17th 2013 and I picked up the stake bed on January 12th. It's been a little bit of progress at a time but I figure slow progress is better than no progress. Of course life's big and small projects oftentimes get in the way but I keep getting back to the big girl and giving her the attentions I feel she deserves.
Now if that big hole in the cab would just go away I can start looking harder for the stainless rear window trim and proper rubber seal.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72
1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code"
1970 Mercury Cougar "Eliminator" 351C-4V C6
1972 Ford Ranchero GT 351C-2V C6
1974 Honda XL-350
Member of the "6 C's and a D" 1-Ton Fun Club!
71Dually is offline
Old 04-07-2014, 10:24 AM   #492
In The Ten Ring
It's too cold to work in my garage this time of year still so I have been making plans. Lots of detailed plans and the plans are ambitious! The next warm day, I plan to seal out last year's attic birds, clean yp their mess, and begin attic flooring preparations. I need to build a set of heavy duty sawhorse that I can disassemble for storage. I think I can slip in the new fuel lines and then the renewed gas tank and seat. That will clear up significant space. I then need to rent a storage container to make room for the garage rewire and new shelving build idea. Then I can get on with the new radiator core support install and all the other things that remain. Space is at such a premium right now, no more really hard work can continue. I'll post pics as I go. I did buy some parts the other day that were in much worse shape than I expected and those must be returned. Naturally the seller blamed me for "not asking." Typical....I am considering outing the felllow so that others may be forewarned for dealing with him and then avoiding getting blamed for the lack of forethcoming as to part condition. Geeze!
In The Ten Ring is offline
Old 04-07-2014, 11:07 AM   #493
74baggedbug
Gonna slap the heads back on and hope for the best.. If not a 383 or ls may be in the near future
74baggedbug is offline
Old 04-07-2014, 12:24 PM   #494
71Dually
71Dually's Avatar
Now that photo is a nice candidate for a wallpaper. Might be a little difficult to find all the desktop icons but it sure is a great image. It would make a sweet puzzle, a nice gear heads variation on the traditional field of tulips, waterfall and puffy clouds in the blue sky stuff.
1974 Honda XL-350
71Dually is offline
Old 04-07-2014, 06:02 PM   #495
CST10
CST10's Avatar
I changed both inner fenders and painted my engine bay finally.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 04-07-2014, 06:05 PM   #496
CST10
CST10's Avatar
Why did it flip the picture? Try again.
MyToys:
CST10 is offline
Old 04-07-2014, 09:22 PM   #497
Lanman1972
Lanman1972's Avatar
Started the rust repair, outer floor, both pillars, inner outer rockers, cab supports and cab corners. Removed the box, door, seat, gas tank, and fender. Did some exploring and just what I was expecting. I'll post pics as I go and maybe start build thread. Wish me Luck! Thanks to everyone on this forum for all info!
Lanman1972 is offline
Old 04-07-2014, 09:47 PM   #498
Ozzy2013
Ozzy2013's Avatar
Originally Posted by Burgie70 View Post
I put on a new fuel pump. What a pain trying to keep that rod up in there and get the gaskets situated. Required another set of hands from my friend. Now I know why people go with an electric one.
Next time put some grease on the rod it will hold it up while you do the pump.
Ozzy2013 is offline
Old 04-07-2014, 09:53 PM   #499
ole dollor
ole dollor's Avatar
grease works good ,and you can use a small round long screw driver and hold it up till you get the pump in place.. just make sure the rod is all the way up. its helps a lot.
ole dollor is offline
Old 04-09-2014, 12:13 AM   #500
74baggedbug
Took right at 5hrs from when we opened up the garage to cleaning up and shutting the doors for the night..
Closed Thread
