Old 02-21-2018, 09:57 PM   #476
99 to Life
99 to Life's Avatar
Re: "Geronimo" 54' 3100 LS built in PA
2-21 Sorry for the lack of updates. I'v actually been working a ton on this truck since my work has been slow I'v had some extra time. Doesn't look like much but tons of little things going on. Made my kill switch for under seat, started routing battery cables and trans controller. Got trans lines ran with all AN fittings, got all the brakes done and fluid to all 4 corners. Had to make my own coupler to connect pedal and booster. Got radiator hoses figured out, took alot of searching! Any of you having an issue with a GM metric PWS pump 16mm x1.5 to a mustang rack (my rack came with 6AN fittings). Done tons of research and just decided to get the AN adapter for the pump (ebay 4-9$) then found a place that premade AN teflon braided hose for $20. I only needed about 1ft distance and for me to make my own line woulda been almost $50. So go that outta the way, also used the borgeson PWS pump reducing washers for the pump to get the pressure closer to the mustang psi of 950.
Final welded my leaf perches as that wasn't done, recoated rear of frame. Got all the fuel line ran, I'm goin to fire engine back up real soon. Made a bracket up front for the regulator. it mounts off the carb studs. I'll clean it up and prolly paint it. Waiting on the retro caddy air cleaner. I gotta put a few things back on engine and do some wiring and she'll fire up. Then I need to get DS made and wire up trans and boom I'm ready to test drive it.
Then onto final assembly of glass and wiring etc. We are getting seat done real soon too. I'v finally hit my 500hr mark. So I'm over the mark there. and we are a little over our parts budget but not by much! She should be on the road very soon. Finally. then back onto my 51' should have that on road this summer. Oh I'll be making my TPS bracket this weekend. Found one on amazon for $10. People want 150-200 for a kit, can't believe what they are asking for something like that. I need to finalize my fuel filler out in bed and that's the last figuring out stuff. I'll have some interior work to do too.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-21-2018, 11:49 PM   #477
Advanced Design
Advanced Design's Avatar
Wow, you've made awesome progress! Looking good. Where is the place making the teflon hoses?
Advanced Design is offline   Reply With Quote
Old 02-22-2018, 12:22 AM   #478
oldman3
oldman3's Avatar
Great update, and lots of work done...Jim
oldman3 is offline   Reply With Quote
Old 02-22-2018, 01:23 AM   #479
iowaboynca
iowaboynca's Avatar
Very nice. You are always the inspiration.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 02-22-2018, 10:52 AM   #480
99 to Life
99 to Life's Avatar
thanks guys, it is getting really close to being a driver. Here is the fitting and hose to adapt the GM pump to mustang rack. Mind you, my rack already came with the -6AN fittings. I got this pump fitting off ebay you can get them cheaper but I paid $9 from getfast1 they have alot of good stuff. the hose came from graystonesystems they are on ebay and amazon. they have every size you can think of, can't beat the price. Glad I found them bc I searched a million options to adapt the stock PWS hose I already had. I didn't wanna make one and pay about $50 to make one to work, so again I got about $30 in this line with fitting. The return line however I am making since I have hose and AN fittings, that doens't need to be a high pressure hose.
Old 02-23-2018, 09:55 PM   #481
gigamanx
Awesome stuff. You'll be driving in no time!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 02-26-2018, 07:17 PM   #482
lower50's
lower50's's Avatar
Sweet!!!! Good progress.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-28-2018, 12:10 AM   #483
99 to Life
99 to Life's Avatar
2-27-18
inching closer. Got the TPS bracket made. between the sensor and the scrap material I had laying around and few hours I ended up saving 130-190 dollars, as I have ten bucks in the sensor. Go the air cleaner. I plan on painting it eventually along with these brackets. I plan to make some nice cnc made brackets this summer. I chose to put the TPS on this side bc the DS of the carb just seemed to be getting clogged up.
Most TPS units have a cable or rod that attach to the arm of the sender and the carb lever. I was able to just butt the two up and let the carb arm come down and run the senders arm. I'v yet to test it and I'm sure it will need some tweaking, but for now I think it should work.
Getting the Drive shaft tomorrow, so really once I wire up a few things its ready to test. Hoping by next weekend to do that.
Old 02-28-2018, 07:56 AM   #484
CURSED GEARS
That last picture is a nice blend with the old and the new. Engine looks tall, almost like it has blower! Good stuff!
CURSED GEARS is offline   Reply With Quote
Old 02-28-2018, 10:14 AM   #485
OutlawDrifter
Good choice of air cleaner!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 02-28-2018, 06:19 PM   #486
Advanced Design
Good solution 99. Engine looks really good!
Old 02-28-2018, 11:10 PM   #487
99 to Life
99 to Life's Avatar
thanks guys. I really wish I woulda done some things different on the engine color scheme. but nothing to loose sleep over. yes I like the old and new. I really hope everything works out and I don't regret carbing the LS. its alot of work either way. Gonna try and work on some wiring this week and see if I can't get it fired back up and really hoping by next weekend I make a maiden voyage! Just got the driveshaft made up today!
Old 03-01-2018, 04:08 PM   #488
lower50's
lower50's's Avatar
You can't go wrong with a carb, try fixing fuel injection on the side of the road.
1951 MG TD
Old 03-01-2018, 04:53 PM   #489
99 to Life
99 to Life's Avatar
I'm not worried about he carb really, more or less the transmission controller LOL. but between the msd box and the transmission controller. just seems like your dependent on two companies product. not to mention all the stuff to actually make this work. I'v often thought why didn't I just go EFI! but I'm sure this will work out. I def wouldn't mind carbing another LS and putting my 5 speed behind it, no controller needed!
Old 03-07-2018, 12:15 AM   #490
99 to Life
99 to Life's Avatar
3-6
Had a short work weekend bc of bday party. But.... I did make a lot of headway. I'm very close to being able to fire this up with the ignition etc all hooked up. So yah I been working on wiring and making a alot of progress. I got all the engine stuff wired pretty much minus the Efan. Got carb choke done, got MSD box done, Trans controller about done, NSS wire up, all starter wires and battery cables, main wire harness pwr ran, got temp senders in the heads, just need the VDO gauge to work with the sender in head. I loom pretty much every wire I deal with also. Ignition is almost done, fuel pump is almost wired up.
Got driveshaft made, need to paint it. My goal is to fire it up next weekend, maybe pop it into gear. Then once I get the temp gauge I can start running and driving it more and more. Pws lines are done also. Then just button everything up. I still need to do a tach and speedo conversion also.
Old 03-07-2018, 12:26 AM   #491
oldman3
oldman3's Avatar
99, shouldn't be long now, nice work...Jim
Old 03-12-2018, 07:57 PM   #492
99 to Life
99 to Life's Avatar
https://www.youtube.com/watch?v=OXWi...ature=youtu.be
dunno why the embed video isn't working, I forget what little trick it is to get it to work these days. anyway. not the best video as I ran outta memory on camera and time today. But..... She starts up and the gears are working. need to bleed brakes and she'll be moving on her own.
I still need to hook up the temp gauge and efan and get it all up to operating temp.
Old 03-12-2018, 10:43 PM   #493
OutlawDrifter
Good progress!
1991 Z/28, 6.0L/T56
Old 03-12-2018, 10:48 PM   #494
NorCalGal
NorCalGal's Avatar
Wow! You have been busy. Looks good
Jan's 53
NorCalGal is offline   Reply With Quote
Old 03-12-2018, 11:12 PM   #495
lower50's
lower50's's Avatar
Good job buddy sounds great.
1951 MG TD
Old 03-12-2018, 11:34 PM   #496
Advanced Design
Nice! Always a good feeling when they fire up.
Old 03-13-2018, 11:13 AM   #497
SalvagedSouls
SalvagedSouls's Avatar
Nice work!
1949 - 3600 Update suspension, engine and drive it.
http://67-72chevytrucks.com/vboard/s...d.php?t=691034
1953 - 3100
1955.1 - 3100 Bare Metal Build
http://67-72chevytrucks.com/vboard/s...d.php?t=691261
1965 - Buick Special & 1965 Buick Skylark
SalvagedSouls is offline   Reply With Quote
Old 03-14-2018, 12:34 AM   #498
99 to Life
99 to Life's Avatar
Thanks guys. Here is a pic of the trans controller handheld. What is really cool about this is, it will do live data so when I'm driving I can check trans temp and speed etc. It is also nice that my speedo output will wire directly into the trans cpu, so no special sending units required. I'll be doing a tach and speedo conversion soon, so they will look like stock gauges but function with a modern touch. The trans controller was easy to set up a tune. I'll try it out and adjust if need. I think it read my TPS just fine which is cool also.
gonna get some driving footage and all that soon!
Old 04-17-2018, 11:05 PM   #499
99 to Life
99 to Life's Avatar
4-17 been slowing down a tad on the build. just alot going on again. But I should be wrapping this one up by next month. It will drive but I haven't taken it out of garage yet. Still working on wiring, but nearing the end of that. Got some chassis saver on the front fenders and grille, gonna raptor line them also. then I can put the front clip all back together. Windshield I bought from summit came with a chip in it, so not sure what I'm gonna do yet. Need to get doors back on. Still waiting for the seat at the upholstery shop, taking forever.
but on a brighter note, I dug myself some more debt with another patina truck 51' (my fav year!!) missing a fender and one door is roached out, but overall the truck is pretty darn solid. Got it out west. also the green truck I had my friend buy, I told him I'd go in on building it and then sell it as a project. Its on an s10 frame and very solid as well. I may sell or build this blue patina truck this year. after I finish geronimo I am going to try and get my 51' back on the road so I can have something to drive!
Old 04-18-2018, 12:46 PM   #500
Desert1957
Desert1957's Avatar
Which is the green truck again? I'm getting confused....
Desert
Desert1957 is offline   Reply With Quote
1954, ls engine, patina
