04-13-2019, 11:41 AM | #476 |
Re: What did you do to your truck today.The 3rd chapter
The small blue unit is my FM radio, blue tooth, sd card, usb, and 1/8" jack. It has uhf remote so I don't need to point the remote like infrared.
Do it, Do it right, Do it right the first time |
04-13-2019, 07:18 PM | #477 |
Got the front part of the frame cleaned and painted. First coat, still need to remove the steering box and idler arm and paint behind them.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-13-2019, 08:00 PM | #478 |
After putting the shroud and fan on and taking it off at least 5 times...
I finally got my truck upgraded to a fan clutch, closed coolant system, new 6 bladed fan, new raidaitor with new hoses and clamps! Also learned how to bend some new transmission cooling lines. Easier than I expected. Very excited to put it all back together.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
04-14-2019, 12:06 AM | #479 |
I'm afraid we're going to need more than just "the small blue unit". Even zooming in I can't read the brand name on it.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
04-14-2019, 09:18 PM | #480 |
Finally got my grille guard installed
04-14-2019, 09:23 PM | #481 |
Finished the door seals and window felts, put door panels on and got the dash painted and put back together. Next week windshield and alignment.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
04-14-2019, 09:55 PM | #482 |
Painted some stuff, and rebuilt the rag joint. The parts are original less the disc, pins, sleeve nut and wave washer that came in a kit. The coupler and flanges are ceramic coated
Some gibberish, kind of cloudy. I take a lot of notes, though this little project called for captions. Took me a little while to figure it out, cuz I'm slow Might help others build one. Doubt I'll ever build another, but who knows. Glad to have rebuilt this as opposed new. The old parts are nice. On a side, I used blue thread locker on their nut where the kit calls for a lock washer. Lock washer don't fit.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-15-2019 at 12:08 AM. |
04-15-2019, 12:45 AM | #483 |
They're made for motorcycles, I got it off Amazon. The new ones have blue tooth built in, I use a small adapter.
04-15-2019, 12:51 AM | #484 |
Working on installing some new front speakers, made a new bracket and think about what I did with the old speaker screw. It pays to be organized, it was blasted, painted and stowed in the bag marked dash.
04-17-2019, 06:42 PM | #485 |
I made some progress buttoning up the rebuilt engine for Old Red. All I have to do is put on the exhaust manifolds and it's ready to plunk down in the engine bay. I went ahead and primed the oil and set the distributor in on #1 so I won't have to crawl in the engine compartment to do that.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
04-17-2019, 09:04 PM | #486 | |
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
04-17-2019, 10:26 PM | #487 |
Yes I was able to remove the engine with the hood on. I lifted it up and forward and then rotated it so the distributor would not hit the hood and then lifted it enough for the oil pan to clear the core support. It's close but it came out.
04-18-2019, 05:09 AM | #488 |
3 inch lowering spring and 2 inch block in the rear. New bilstein shocks and adjustable panhard bar!!!
04-18-2019, 11:05 AM | #489 |
I did some web research and ordered new inner door panels that will be arriving today. It was a bit of a wait for them to be customized. Will post pictures when I get them in.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-18-2019, 09:37 PM | #490 |
Active Member
I got my camper on and bolted up last night. I made some mounts for stake pockets. Needs a back door , insulation and couple other things but it’s on.
Posted via Mobile Device |
04-18-2019, 10:59 PM | #491 |
looking good, I like your pocket mounts.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
04-20-2019, 10:28 PM | #492 |
How did I get this OLD!
I bored out 67 wiper knobs to 1/4" and added some aluminum tape to simulate deluxe knobs. Added the knobs to my under dash A/C unit. Fabbed up some brackets and installed the under dash unit.
http://67-72chevytrucks.com/vboard/a...1&d=1555813380
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
04-21-2019, 08:58 AM | #493 |
very nice
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-21-2019, 09:01 AM | #494 |
I cant tell from the pictures is your exhaust tucked up in the frame ?
04-21-2019, 06:59 PM | #495 |
I put a 1 1/4 front sway bar on my truck today,also pulled my gas tank,had a annoying vibration when tank was full, must have had no deadner behind it,put some glued on deadner on the back of the cab,reinstalled tank,and good to go,brought in the 85 c10, gonna go over it and get ot ready for a safety check and put it on the road.
04-21-2019, 08:28 PM | #496 |
I have a radical idea!
Sanded and painted my 6” steelies for the front and waiting on the 8’s to get back from sandblasting to put my “new” ‘72 on steelies.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
04-21-2019, 09:40 PM | #497 | |
04-22-2019, 11:06 AM | #498 |
Yes. I don't have a pic from the side but it is approximately even with the bottom of the frame rail, you can see the headers a little bit though.
04-22-2019, 11:46 AM | #499 |
Put some on new Tires and painted my steels a nice bright white.
1969 Custom w/Turquoise Interior. 75k miles, 350 Auto, (Almost) All Original |
04-22-2019, 02:29 PM | #500 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
