04-16-2017, 08:05 PM | #5201 |
Re: What did you do to your truck today? Chapter II
Built some sway brackets to match the width of the 3rd gen camaro rear sway bar for the rear of my 67 c10. Also fabbed up some exhaust clamps with a wider base for the bushing to mount it to the axle.
1967 c10 stepside 6.0L 4L80E Last edited by 3rdGen.c10; 04-16-2017 at 08:23 PM. |
04-16-2017, 10:22 PM | #5202 |
Gave the neighbors a break from the hammering and grinding, spent some time with a tape measure taking notes down for a the 4 link and step notch.
04-16-2017, 11:57 PM | #5203 | |
What size muffler clamps did you use? What did you use to make the frame brackets? Do you have any installed photos?
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
04-17-2017, 12:02 AM | #5204 |
That's funny. I also gave my neighbors a break from hammering and grinding, instead I ran the pressure washer all day.
04-17-2017, 12:06 AM | #5205 |
Replaced my rear shocks. I also cleaned up some rust I found behind my master cylinder when took it off last week.
04-17-2017, 02:01 AM | #5206 | |
1967 c10 stepside 6.0L 4L80E Last edited by 3rdGen.c10; 04-17-2017 at 07:56 AM. |
04-18-2017, 08:11 PM | #5207 |
Freed a truck from paint jail.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
04-20-2017, 08:15 AM | #5208 |
Got the rear sway bar brackets fabbed up and painted. Final install.
1967 c10 stepside 6.0L 4L80E |
04-20-2017, 08:58 AM | #5209 |
Looks good. Thanks for sharing.
04-20-2017, 09:22 AM | #5210 |
Got my Mcgaughy's 4.5/5 kit installed and all new ball joints. Rear tires are rubbing a little (20x10) but other than that it rides so much better than before with all new suspension components!
04-20-2017, 07:13 PM | #5211 |
70+ ( Old Skool Club )
Got the Booster /Master combo I bought from Frank's Pickups installed on the truck. Works great.
http://67-72chevytrucks.com/vboard/s...d.php?t=581862
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-20-2017, 07:29 PM | #5212 |
I can now drive at night and in the rain. New harness and wipers.
See any problems with this harness? |
04-20-2017, 08:15 PM | #5213 |
That looks like my high quality work.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
04-20-2017, 10:25 PM | #5214 |
04-20-2017, 10:31 PM | #5215 |
Replaced the voltage regulator and park bulbs....chipping away slowly but surely
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
04-21-2017, 10:01 PM | #5216 |
How did I get this OLD!
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
04-21-2017, 10:02 PM | #5217 |
wow.... nice job!!!!
88 Suburban Silverado (original 48,000mi) 99 GMC Z71 stepside 01 GMC 2500HD crew (Texas truck) 07 Chevrolet Suburban LT 84 Chevrolet S10 short box 355 V8 |
04-21-2017, 10:05 PM | #5218 |
http://67-72chevytrucks.com/vboard/a...1&d=1492826636
Install new carpet and freshened up door panels
04-21-2017, 10:08 PM | #5219 |
04-21-2017, 10:10 PM | #5220 |
http://67-72chevytrucks.com/vboard/a...1&d=1492826952
Installed Chevelle wheel and freshened up gauges.
04-21-2017, 10:55 PM | #5221 | |
04-21-2017, 11:47 PM | #5222 |
Yes for sure "Already Gone"! It was so weird to take the on ramps in Edmonton. So use to anticipating the roll. I love how it feels. Have a 1" front sway bar that I will be installing in the other truck.
04-22-2017, 01:52 AM | #5223 |
I don't know if you purchased the front sway bar new but there is cheaper alternative that works really well. Any 1973/1987 C30 or GMC 3500 truck has the 1 1/4 inch front sway bar. Some of the heavier GVW C20 and GMC 2500, like the camper or trailering special ones have the 1 1/4 front bar too. Get one from a wreck in a salvage yard, usually 40/60.00 and buy a new set of bushings for it and use it.
04-22-2017, 09:52 AM | #5224 | |
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
04-22-2017, 11:24 AM | #5225 |
got the bed off and took apart.
