Old 08-19-2013, 10:38 PM   #501
Vernski
Re: Tricked-out Chevy six cylinder engines
Originally Posted by T.J. MCCAULEY View Post
I bought a Clifford intake for mine so I wouldn't have that problem.
X2 TJ Toms article was why I went with the Clifford instead of the Offy, but I did buy Toms cast iron headers and running his HEI ..Vernski
Vernski is offline   Reply With Quote
Old 08-20-2013, 08:55 AM   #502
sixtyeightchevykid
sixtyeightchevykid's Avatar
i have the offy intake ont the truck now but i do not have the headers or the water heat installed yet. the offenhauser intake i got was brand new never installed still had the tag and wrapping on it, the guy bought it from jc whitney 10 or 12 years ago. he sold the intake and 6 qjets to me for 100 bucks. thats a hard one to pass up.
1968 chevy c10 lwb, 250 inline6, 4 speed,
sixtyeightchevykid is offline   Reply With Quote
Old 08-22-2013, 03:30 PM   #503
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I have Clifford's headers. How good does Tom's HEI work?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-22-2013, 04:31 PM   #504
Vernski
Seems to be a noticeable difference quicker starts and a we bit more power over the points. You might find one cheaper off a V6 in a wreaking yard the V6 they had in cars and S10 pickup in the 80's. Same firing order and everything so GM stuff is handy..Vernski
Old 08-22-2013, 06:20 PM   #505
chevy_mike
Never Ending Projects
chevy_mike's Avatar
V6 ones are not a drop in. Tom modifies the shaft with a new coller to allow it to sit correct in an inline 6. Don't buy a junk yard one expecting it to drop in.
As for Tom's HEI, made a big difference in mine. Runs so much smoother, little more power and starts easier.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-22-2013, 07:31 PM   #506
Vernski
Thanks Mike I didn't know about the collar, I wonder if it's an easy mod though?..Vernski
Old 08-22-2013, 08:14 PM   #507
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I put the pertronix ignitor in mine with the 40,000 volt coil. Pertronix used to make a 6 cylinder hei and now all they make is the points to hei conversion and it perrty cool. You take a stock distributor and pull the points and the pertronix bolts on the original plate. I plan on buying a Davis Unified Ignition Hei. Much more expensive but puts a hot 50,000 volts out! And is advanced the same as the original Gm HEI. My buck. T.J.
Old 08-22-2013, 08:15 PM   #508
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Has anybody here used the Davis Unified Igntion HEI?
Old 08-23-2013, 05:28 AM   #509
Sharps40
HEI, plugs and Weber 32/36 from Tom are on my 65 with 250 I6, factory style exhaust with Thrush Muffler. Awesome. Best money I've spent. Most recent fuel mileage was rural highway, 19.4 MPG. Will be talking with Tom about a T5 swap as soon as the shop opens back up from vacation.
Sharps40 is offline   Reply With Quote
Old 08-23-2013, 11:30 AM   #510
The Rocknrod
Moderator
The Rocknrod's Avatar
This is my old GMC. I'm thinking of a new build to include a newer model very soon.
Old 08-23-2013, 11:54 AM   #511
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Very Nice! Great work! Is that a 228?
Old 08-23-2013, 12:04 PM   #512
awbrown
To say that you have to have the manifold heated is like saying a tunnel ram or an air gap manifold won't work ... my triple setup on my 261 has no heat and I am sure that if I dont run it in the winter i will be fine .. If you drive yours all year in a cold climate , then I would for sure heat the manifold...
awbrown is offline   Reply With Quote
Old 08-23-2013, 04:10 PM   #513
Twisted6
Twisted6's Avatar
I have the DUI stuff in my stock HEI and I have never had any problems. And My dist. has seen 8000 rpms more then once
Larry /aka Twisted6
Twisted6 is offline   Reply With Quote
Old 08-23-2013, 04:35 PM   #514
65chev
larry. Give us info on your engine posted in your profile. I like.
Mike
65chev is offline   Reply With Quote
Old 08-23-2013, 05:42 PM   #515
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
What Mike said! And if I remember correctly those are triple 450 cfm holleys and it looks like a Kay Sissel head design??? If that is a stock type lump port head that will amaze me! What size plug wires should I run for an hei? I am running Napa premium 7 mm hei wires, but am thinking they may be to small. Would a thicker 8.5 mm wire be better and what company makes good high energy wires? Thanks. T.J.
Old 08-24-2013, 06:27 PM   #516
Twisted6
Twisted6's Avatar
Well the dist. has the DUI stuff 50,000 coil and mod. If I remember right 8m. wires and it has been set-up using a dist. machine to handle the 8000.That intake was first on my old 250 built up with a crane cam 38-7200 power band beefier springs then what crane called for. Pistons started life as a 12.5-1 for a 307.They were fly cut .225 to clear the 583/607 lift cam which turned the pop-up in too a 3staged piston dome. Stock rods with ARP studs,
bottom end is other wise stock. Stock oil pump. The head on the main build was a 194 which put the more between 13.9-1 an 15-1. The head gasket would only hold up to about 3, 1/4mi passes before blowing it. So to be able to run a 3day weekend event I swap to a larger head to bring the compression down to around 11-12-1. And yes this is just a stock cast iron head. And at that time had no lump ports.
This new motor is now at 13-1 with a New cam which is just under 700 lift. which also had (key word being had) my first style bolt-in , which has now been replaced with My newer
G2 lump kit. The same tunnel ram will be used till I finish my newer Alum 3x4 one with other improvements to it.
On that older motor which was just over 17yrs old. When I was testing different intakes
Offey 4b, Clifford 4b, and dual 4b. My 3x4 out ran and performed the best. and the ETs showed that.
And yes they are holley 450s Pretty much stock out of the Box. And I am now also working on a billet air cleaner for it. Or at least a better looking one kinda maybe old school but none the less it will still be of billet.
Larry /aka Twisted6
Old 08-24-2013, 07:30 PM   #517
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Thanks for the info Larry. For the intake and headers what is a good gasket to use? Is the one Clifford gave me sufficient? I have an exhaust leak and no doubt a small intake leak and its because I am using a stock type gasket( The metal style).
Old 08-25-2013, 06:11 AM   #518
Twisted6
Twisted6's Avatar
I run the felpro 1025 head gasket and the MrGasket gasket and I have not had any problems and I have ran the Mrgasket for 20 some yrs. I heard the felPro gasket is vary good as well.
Larry /aka Twisted6
Old 08-25-2013, 04:08 PM   #519
The Rocknrod
Moderator
54 - 235c.i.
Old 08-25-2013, 05:27 PM   #520
The Rocknrod
Moderator
Originally Posted by JR25 View Post
Ok......... I think I finally finished the engine build, not in the truck and running, but here is as close as I could get to "tricked out" for an old timed 235!...
That came out sweet. Great work!
Old 08-29-2013, 04:57 PM   #521
KroAutomotiveInc
KroAutomotiveInc's Avatar
found this video it has some really nice sound quality of a dual exhaust straight 6 running.
KroAutomotiveInc is offline   Reply With Quote
Old 08-29-2013, 05:02 PM   #522
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
1955 GMC-250 six with Purple Horneys - YouTube
Yup, I've seen this one before.
Old 08-29-2013, 05:03 PM   #523
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Here's a video of my 64 292 running after 13 years. Sorry about my fingers getting in the way. I was afraid to rev it up to high cause I didn't want to blow the bent pushrod.
Old 08-29-2013, 05:12 PM   #524
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
How about this 292 with dual webers?
Old 08-30-2013, 01:09 AM   #525
JR25
JR25's Avatar
Originally Posted by mr andrerson View Post
wow!! JR25... i just saw your mill...thats one sweet 6!! i hope you put a vid up of it running!!
Ok..... As requested. Had to upload it to youtube to link it!
1955 Chevy 3200
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=582898
JR25 is offline   Reply With Quote
