Old 03-08-2012, 01:35 AM   #501
Kim57
Kim57's Avatar
Re: My 57 Pro Street
Well I finally got it in. It turned out to be a bigger pain than I expected.
The original frame stands put the engine too far forward and my power steering pump wouldn't fit. I ended up using some after market stands and cutting them down to fit. Had to move the engine back about 3"s. I was able to get everything to work except for the stock AC pump which was on the lower passenger side. They make a bracket to raise it so that won't be a problem.
Got the oil pan to sit level with the cross member.
I still need to get the cab back into position. I need to modify my firewall now that the engine is farther back than expected.
I still need to do the final welding on it all but it was a good day over all.
Here's a few pics to show what I ended up doing.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-08-2012, 07:22 AM   #502
OKGMC4
OKGMC4's Avatar
Looks good. I went through a lot of trial and error to make that bracket assembly for the AC but got it right. The spacing is critical with serpentine systems. I need to find a way to post the templates for the parts because I think lots of people could use this for the same reasons you and I need it. When I had my father in law machine mine I had him make a second set and it 's just sitting here in a bag...
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 03-08-2012, 11:25 AM   #503
oldman3
oldman3's Avatar
Kim, install looks great, nice job. Without going back in your post, I believe you have a camaro clip, correct?...Jim
oldman3 is offline   Reply With Quote
Old 03-08-2012, 12:02 PM   #504
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
It's looking good. Why don't you just put a notch in the crossmember? That's what I did to make my fit.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 03-08-2012, 01:53 PM   #505
ambryatim
ambryatim's Avatar
Check the link in my sig about mounting an a/c compressor to these engines.
I have the bracket just have not done it yet. Looks pretty easy and it puts it in a better location keeping you from having to notch the cross member.
Kim
ambryatim is offline   Reply With Quote
Old 03-08-2012, 02:20 PM   #506
65Pickup
65Pickup's Avatar
I've been in that thread. The biggest problem I had with my set up is that I have a chevelle clip. There is a ton of very good info in there though.
A Chevelle clip , I guess that's why no LS people weighed in, that would make your set up unique. Looks like your well on your way. Viva la progress.
65Pickup is offline   Reply With Quote
Old 03-08-2012, 03:49 PM   #507
_Ogre
_Ogre's Avatar
looks good kim. making progress!
shop air compressor timer
Old 03-08-2012, 04:05 PM   #508
Kim57
Kim57's Avatar
I could use your template to make my install a little easier if I end up making my own.
My clip is from a 67 Chevelle.
Tri5
If your talking about the AC unit the swap plates I have won't let the bracket mount to the block. There's a couple of work a-rounds without spending a ton of money though.
I've seen that fix and am really considering it for mine also.
These guys make a decent priced bracket to raise it also.
http://www.kwikperf.com/lsx_ac.html
Thanks for looking at my thread guys.
Kim
My build thread
Old 03-08-2012, 05:22 PM   #509
OKGMC4
OKGMC4's Avatar
Holy cow, that's cool! It's awesome what people can accomplish when they have to be conservatively creative with the cashflow. We can't all afford to go out and buy a Vintage Air frontrunner system, can we?
Old 03-08-2012, 06:25 PM   #510
OKGMC4
OKGMC4's Avatar
Here's a pic of the parts. Mostly there are really only the three plates that need a template. The rest are just bushings. My idler bushing has a step but it's poossible you could do it with two pieces instead. You'd still have to have the 2002 Z28 tensioner, a sanden compressor, and a couple really long metric bolts to get into the head. It's just like the kwik setup but I had to figure it all out with a tape measure and wooden templates. I don't know how hard it would be to scan these and post them as a pdf file.
Old 03-09-2012, 01:24 AM   #511
Kim57
Kim57's Avatar
Those are nice pieces.
Kim
My build thread
Old 03-09-2012, 06:22 PM   #512
ambryatim
ambryatim's Avatar
Kim, question about your engine mounts.....Did they end up being cut the same length?? I know you are using a Chevelle clip in all, but in mine I am using a 78 TA clip. I have seen some people use the old 68 Camaro frame mounts (actually the same mount for the C10's and Blazers and a few other vehicles too) but, they seem to be using 2 of the same mount and for some reason I cannot get the same distance on either side....if I do it is either not centered or not level.
Thanks Tim
Old 03-09-2012, 07:00 PM   #513
Kim57
Kim57's Avatar
They are the same length.
Here's how I did it.
I took pieces of wood the same width as the front of my oil pan and put them on the cross member and let the front of the pan rest there. I used my floor jack to raise the rear of the trans until I got a downward angle between 1 and 5 degrees.
I made sure everything was centered and level side to side and cut the mounts to fit in the space.
It took a lot of time and I checked everything a bunch of times before I tacked it in.
If I were you I would try and measure the front clip to make sure it's symmetrical from side to side. It's possible the factory had the engine farther to one side to make room for things. I would think any extra room would be on the drivers side.
I ended up moving my engine back 4.5"s from the stock location for my clip so my P.S. pump wouldn't hit my steering box.
Hope this helps.
Kim
My build thread
Old 03-16-2012, 12:22 AM   #514
Kim57
Kim57's Avatar
I made some more progress on the truck.
Seeing as I had to set the engine back farther than expected I needed to make the cab fit around it. I made a new cad dolly to make the work a little easier.
Lots of measuring and painters tape and I had something I thought would work.
I find it better to cut as little as possible at first. It's always easier to take more out than to add it back in.
Kim
My build thread
Old 03-16-2012, 12:25 AM   #515
Kim57
Kim57's Avatar
This was the first go around.
The trans is still hitting and I didn't like how it fit around the heads.
Kim
My build thread
Old 03-16-2012, 12:30 AM   #516
Kim57
Kim57's Avatar
After a little more time with the cut off wheel I'm almost there.
It's hard to see the difference around the heads but I made the lower part of the opening a little straighter.
Every thing fits but I'm going to open the trans a touch more.
I just have to get a set of headers now and make sure they're going to fit.
Kim
My build thread
Old 03-16-2012, 12:33 AM   #517
Tri5Nerd
Tri5Nerd's Avatar
Looking good Kim.
Tri5
Old 03-16-2012, 07:00 AM   #518
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome work Kim!
ChuckDriver is offline   Reply With Quote
Old 03-16-2012, 08:28 AM   #519
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: My 57 Pro Street
Coming along good!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-16-2012, 12:12 PM   #520
oldman3
oldman3's Avatar
Nice job, like the way it looks....Jim
Old 03-16-2012, 01:05 PM   #521
Daze57
Daze57's Avatar
very nice work !
Daze57 is offline   Reply With Quote
Old 03-17-2012, 11:05 AM   #522
Kim57
Kim57's Avatar
Thanks for the kind words guys.
Kim
My build thread
Old 03-29-2012, 06:50 PM   #523
Kim57
Kim57's Avatar
Making some progress on the fire wall.
I started by making a template out of some heavy card stock and cutting a couple pieces of 16 gauge. After tacking them together I honestly hated how it looked. The 90* looked bad.
Kim
My build thread
Old 03-29-2012, 06:56 PM   #524
Kim57
Kim57's Avatar
So here's the fix.
I took some more sheet that I had bent. I used my shrinker/stretcher to create an outside curve and an inside curve and then welded them together. I took my original piece for the back and cut it to fit my new piece.
Sorry i didn't get more pics of the process but I just got caught up in making it work. Got it all in and it's much more appealing to the eyes.
Kim
My build thread
Old 03-29-2012, 06:58 PM   #525
Kim57
Kim57's Avatar
Here's the pics of it around the engine. I still have to final weld it but that's for another day.
Kim
My build thread
