Old 11-25-2019, 02:37 PM   #501
joe dirt
joe dirt's Avatar
Re: Post Pics of your Static Drops!!
my 64 gmc with unknown drop
cut front coils and remaining 6 leafs in rear ( previous owner)
235/60/15 front 255/60/15 rear 10" wheels
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 11-25-2019, 11:24 PM   #502
rcnutt
rcnutt's Avatar
My 64.....2.5" spindles with 3" springs in front....6" springs with 2" blocks in back
64 short fleet
rcnutt is offline   Reply With Quote
Old 12-13-2019, 04:55 PM   #503
Robert Haas
65 with 4/7 c notch, and spindles and springs.
Our 1965 GMC big block pro mod build http://67-72chevytrucks.com/vboard/s...d.php?t=746098
Robert Haas is offline   Reply With Quote
Old 12-17-2019, 10:49 PM   #504
Heater63
Heater63's Avatar
2.5 spindles/ 4" lowering coils.
235/60/ 17"
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-10-2020, 11:14 PM   #505
J Williams
J Williams's Avatar
Originally Posted by SIR View Post
...3/4 drop,1"drop springs with 2 1/2 drop spindles,front, 4" coil rear....
Okay, that is by far the best looking stance I have seen. What is your tire sizes? Well done man that thing is gorgeous!
J Williams is offline   Reply With Quote
Old 03-24-2020, 03:48 PM   #506
lowroder
Lets See Some Static Drops An Details Focused On The 1960-62s Please. I Have A 62 I'm Looking To Do A Static Drop On.. Not Sure If Going The Full Disc Brake Swap Or Just Torsion Bar Tweaking. I Also Will Be Pulling A 13ft Vintage Camper. So Thinking Maybe C Notch For Travel Or Not
lowroder is offline   Reply With Quote
Old 03-24-2020, 09:37 PM   #507
forestb
forestb's Avatar
I would not recommend dropping your truck much more than 2-3 inches by loosening the torsion bars. So you can probably get the front down around 5 inches safely with torsion bars and drop spindles. Some people might disagree with that. As far as the rear goes it is harder to do a c notch on a 60-62 because of the x frame. They don’t sell kits for it like they do for a 63-66. With that being said I would start out using 2 inches drop blocks and coils to figure out the rest. When I dropped mine in the rear I could not drop it 6 inches without the axle hitting the frame going over bumps but I have heard if people getting away with 6 inches but that is without a camper. From what I have read in order to level the truck out it needs to be dropped 2 more inches in the rear than in the front but that will be different with a camper. Maybe air bags in the rear to give you proper adjustability. If you are pulling a camper you probably are going to want disks in the front anyway. I will leave it to you to look through this thread to find photos of 60-62’s
forestb is offline   Reply With Quote
Old 03-25-2020, 09:34 AM   #508
verdell
verdell's Avatar
This was a few years back before I changed the wheels and tires. 2.5” dropped
spindles with the T-bars turned down a little. 15 x 8 inch wheels. 255-60-15 front and 275-60-15 rear. 4 inch lowered rear coils. No C-notch.
verdell is offline   Reply With Quote
Old 03-27-2020, 02:50 PM   #509
lowroder
did you use the adjustable pan bar too with the 4" drop coils?
how much travel is there without a "c" notch. Ill be pulling a small 13ft camper.
about 2-250 tung weight
Old 03-31-2020, 11:11 PM   #510
Brim
Brim's Avatar
Do you have headers on the truck?
Brim is offline   Reply With Quote
Old 06-16-2020, 04:28 PM   #511
kdad
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039
She may not be the prom queen but at least she puts out..
kdad is offline   Reply With Quote
Old 06-16-2020, 05:01 PM   #512
verdell
verdell's Avatar
No, Sir. I'm running a '65 12 bolt rear so I had to modify my existing panhard. It's not adjustable. I don't recall the amount of travel I had but didn't have issues bottoming out or hitting bump stops. I've since switched to bags and honestly prefer those better, especially for heavier loads.
Old 06-16-2020, 05:04 PM   #513
verdell
verdell's Avatar
Yes, Sir. On this photo, I was running Hedman 69260 headers with a 383/700R4 drive train.
Old 06-22-2020, 09:33 PM   #514
lowroder
Right on..
I'm definitely looking for good safe ideas
Old 07-03-2020, 08:09 PM   #515
gatch
My 1963 C10, 350 with a nv3500. Drop spindles, disc brakes, dropped springs and lowering blocks.
gatch is offline   Reply With Quote
Old 07-03-2020, 09:43 PM   #516
J Williams
J Williams's Avatar
Haha, My 63 with 350 and NV3500, disk brakes but no drop spindles yet! Little jealous, yours looks a little more road worthy! Love the truck man, well done!!
Old 07-04-2020, 06:51 PM   #517
gatch
Thanks man, any upgrades to the nv3500? I bought the Hurst handle upgrade.
Old 02-22-2021, 07:42 PM   #518
lowroder
any 62s out here? looking to drop my 62 fleetside soon.
Old 02-22-2021, 07:50 PM   #519
forestb
forestb's Avatar
Please search through the thread if you have not already. There are several 62's posted.
Old 02-22-2021, 08:31 PM   #520
lowroder
Originally Posted by of13swc View Post
Beautiful truck. Awesome job.
did you adjust the torsion bars? i have a 62 looking to lower. i also pull a vintage camper. so can u haul with a 5" drop in rear?
Old 02-22-2021, 10:09 PM   #521
forestb
forestb's Avatar
On my 62 I originally dropped it around 2 inches with torsion bars and 2 inch drop spindles. I have a 5 inch drop in the rear and I would not try to tow anything with it. If you do you should probably use bags in the rear just to make sure you don’t bottom out.
Old 02-26-2021, 02:10 PM   #522
pdxhall
pdxhall's Avatar
It's getting close to being on the road. Sanity has 2 1/2" spindles and 1" coils in front and 5" drop coils in the rear.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 02-27-2021, 12:03 PM   #523
lowroder
Originally Posted by 62ChevyStep View Post
First pic is no drop (stock), Second is 3.5/5 (finished), third is front (3.5) rear (stock). Yes those are 20x8.5 Boyd Coddington Smoothie II's
did you do a crossmember swap to use coils upfront? i have a 62 all stock with torsoion bars looking to lower
Old 03-01-2021, 12:24 PM   #524
verdell
verdell's Avatar
'62 will have the same stock suspension as a '60..
Old 03-01-2021, 07:46 PM   #525
lowroder
yes sir... i know 60 to 62s all had torsion bars.
im looking to lower mine . looking at all options .
