Old 05-02-2013, 11:55 PM   #501
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Greg65 build thread
Originally Posted by Ta2Don View Post
Very Nice Repair... Great work as always!!!
Originally Posted by sdailey View Post
Nice work as always.
Originally Posted by Bomp View Post
Like it!
Thanks Guys!!
Originally Posted by da_bears_da1 View Post
Very nice patches and work! Did you use a repop patch or donor or form all of that?
I used repop parts. BTW thanks!!
Worked the cab corners and welded the main harness hole on the firewall and also a hole in the dash from a PO. Still need some more work on the cab corners.
Alan's Classic is offline   Reply With Quote
Old 05-03-2013, 11:14 AM   #502
aggie91
I'm just glad to be here!
aggie91's Avatar
Question for you Alan, you mentioned you used OMNI epoxy on this one but you prefer the PPG DP line of epoxy. How well has it been working with it while doing the filler on top? Once your done with the filler are you going to recoat with the OMNI epoxy or go straight to slick sand or something else?
Anyway, looking good.
Greg - those powder coated parts look great too!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-08-2013, 11:25 PM   #503
Alan's Classic
The Omni seems to be working out just fine. After the filler work I'm using the new product of slick sand, Evercoat "Super Build 4:1". Pic attached of the can.
Pics of the new version of slick sand. I'll report what it's like. It actually comes with a quart of catalyst so you get 5 quarts of material instead of 4 with the old. I also ordered the 3M Platinum filler, it sands good and cheaper than rage extreme. The only problem I have with it is pin holes.
The double walled area where the steering column comes thru the floor had some cancer. I cut it out and will treat what I can.
Old 05-09-2013, 09:39 AM   #504
aggie91
aggie91's Avatar
Thanks Alan. I am going to try the Omni this weekend on some bed parts. Looking forward to what you think about the new Super Build primer.
Karl
The LST Challenge:
Old 05-09-2013, 03:17 PM   #505
Low Elco
Hmmmm.... Slick sand, G2, and now this? Wonder what kinda cannon you gotta use to get this stuff on?
Low Elco is offline   Reply With Quote
Old 05-09-2013, 05:12 PM   #506
flips72
flips72's Avatar
nice work alan, and thanks for the info,i too am kinda curious about what size tip will be needed to shot this primer or will you thin it,ifso what will you use to thin it with? sorry for all the questions but i put alot of stock in your expertise when it comes to this body stuff.
flips72 is offline   Reply With Quote
Old 05-09-2013, 10:59 PM   #507
Bomp
Bomp's Avatar
Awaiting your further information on applying said products.
Cause I'm takin' notes and I needz to Knowz.
Great job Man.
Bomp is offline   Reply With Quote
Old 05-10-2013, 09:05 AM   #508
da_bears_da1
Funny how this stuff works out. I was just doing some research on Slick Sand last night. It gets very good reviews on other forums. Glad to see Alan is going to try it out for us.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
Old 05-10-2013, 05:36 PM   #509
Alan's Classic
Todays progress, I'll comment on previous post later. I got to run
Old 05-11-2013, 11:23 PM   #510
Alan's Classic
As I was sanding the Omni epoxy tonight I can't tell the difference between it and PPG DP90. It is very hard to sand. I used 80 grit paper to scuff it up for the Super build.
I'll post my review once I spray it.
Thanks, I'll let you know what happens. It shouldn't be long. I did shake the can by hand. It sound pretty runny. Maybe it is separated I didn't open the can. I hope it's not as runny as it sounds. If so I'll send it back.
Great job Man.
Yes Sir, I'll get right on it.
I love slick sand, while it is tough to spray. I used it on my build and also 198plus's build. This is the latest and maybe greatest version of it. We'll see.
I've been able to spend some quality time on it Friday and today. I've got a few more filler spots to work, but started scuffing the rest of the cab getting it ready for some Super Build. The fire wall, outside of the back panel and right door jamb is scuffed. I was also able to push some dents out of the dash. It's amazing what you can do with a baseball bat as seen on the cab floor.
Old 05-12-2013, 02:24 PM   #511
greg65
greg65's Avatar
Not sure if anyone has told you or not but you do some pretty good work. Lol. The Louisville Slugger is a nice touch. I can't wait to come check out the progress in a couple weeks.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 05-12-2013, 02:31 PM   #512
Ta2Don
Ta2Don's Avatar
Very Nice, I too like the Louisville Slugger
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 05-12-2013, 08:52 PM   #513
Alan's Classic
Haha,
I hope to have it in primer by the time you get here.
A bat has a nice round end to push on some metal if you can get to the back side. BTW thanks
Today was a day of rest for me as far as doing work in the shop.
Old 05-12-2013, 11:36 PM   #514
likaroc13
Rollin' Old Skool
Don't give him the "big head!" He might start upping the prices before I can get mine over there. Alan, that's crappy work. Keep it up!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 05-13-2013, 08:47 AM   #515
Low Elco
Ball Bat, ha ha! I have a broken Sledgehammer handle I use for similar purposes. I was using a Stanley spud bar to get behind a quarter and push up a big low this week. High tech, Baby! Whatever git's 'er done!
I usually run SS/G2 with a splash of lacquer thinner to get it moving thru a HF HVLP with a 1.8 tip. "Splash", that's a highly technical paintin' term.
Old 05-13-2013, 04:39 PM   #516
coulter
coulter's Avatar
some killer looking work on that cab!! keep it up
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 05-16-2013, 06:34 PM   #517
flips72
flips72's Avatar
x2 wont be long now.
Old 05-16-2013, 08:55 PM   #518
greg65
greg65's Avatar
Thanks guys. Alan is knocking the cab out pretty quick. When you consider working a full time job, doing this at night, and helping at another body shop on Saturdays. Not sure how he does it.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 05-18-2013, 11:02 PM   #519
Alan's Classic
I'm glad someone finally realized that.
Splash=TLAR which is That Looks About Right. What's G2, I'm drawing a blank.
I hope not.
Not too mention the kids, HAHA. I actually work at the other shop Tuesday and Wednesday nights. With the end of school and all the award ceremonies and band concerts over. I will be getting more done.
Originally Posted by Woogeroo View Post
Coffee?
-W
Yes Sir!!
Worked some tonight trying to get it ready to prime and found some more areas that needs work.
Old 05-19-2013, 11:05 AM   #520
Jeff La
My exact thoughts
Jeff La is offline   Reply With Quote
Old 05-19-2013, 11:25 AM   #521
Bomp
Bomp's Avatar
Drooling. Can't wait til Im at this stage. Nice work
Old 05-19-2013, 08:44 PM   #522
Alan's Classic
Originally Posted by Jeff La View Post
My exact thoughts
You'll get there!! One thing at a time.
Some more quality time today. I worked the outside of the door, cab is ready for the first coat of high build. I also seam sealed a little.
Old 05-19-2013, 09:10 PM   #523
Low Elco
Featherfill G2. Supposedly the same/ slightly lighter than SS. I like it, works well. Nice work!
Old 05-19-2013, 09:44 PM   #524
greg65
greg65's Avatar
Great work as always. Thanks for the pictures and updates.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 05-21-2013, 12:32 AM   #525
Alan's Classic
The cab is a different color. Here's a teaser pic ill get more soon.
