12-10-2010, 07:24 PM | #501 |
67cheby
Re: 68 S/C update.....
WHO DID YOU FIND HAS THE BEST PRICE ON CUTOUTS ? I ONLY NEED ONE , MY EXHAUST IS GOES INTO ONE RIGHT BEFORE THE MUFFLER RIGHT BEHIND THE CAB, I WOULD LIKE TO PUT ONE THERE TO ...MAKE I SOUND LIKE IT HAS MORE THAN 300 HP ...lol
12-10-2010, 07:25 PM | #502 |
67cheby
I hope you get tired of those wheels real quick like, so i can buy them
12-10-2010, 09:08 PM | #503 | |
12-11-2010, 01:09 PM | #504 | ||
Will do. It will be after the first of the year before I start that project. R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-11-2010 at 01:10 PM. |
12-11-2010, 04:02 PM | #505 |
truck looks awsome hart rod
12-25-2010, 12:24 PM | #506 |
Thanks! Still waiting on my headers and then I will take it to my exhaust guy for some new pipes! Merry Christmas and a Blessed New Year for all!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-25-2010, 03:33 PM | #507 |
you make me want to drop my truck like you did and put the same rims
12-26-2010, 01:10 PM | #508 |
sweet!!!!!! good looking truck and alot of work,keep on truckin''
01-20-2011, 11:04 PM | #509 | ||
**** I'm trying to finish up my exhaust "renovation" that ended up in the removal and replacement of the transmission crossmember and the trailing arm crossmember. Both will be replaced with ECE units. Sooooo, out with the old and in with the new.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-20-2011 at 11:05 PM. |
01-20-2011, 11:08 PM | #510 |
as always hart rod excellent!
01-21-2011, 12:23 PM | #511 |
I can see the finish line!
I tried the link on post #492 but it did not work.
BTW, check out my new build thread here. I used your project list (with a nod to you) and am also adding the post numbers as an index. Love the thread. Pete Last edited by rou; 01-21-2011 at 12:24 PM. |
01-21-2011, 03:23 PM | #512 | |
Thanks!
01-28-2011, 12:15 AM | #513 |
Found a quick way to remove the trailing arm crossmember, . I also, flipped the trailing arm crossmember mounting brackets upside down to help improve the pinion angle. I have to buy a long drill bit tomorrow in order to finish the install. My header should be in tomorrow also, .
01-28-2011, 12:28 AM | #514 |
wow off to the florida scrap yard right rob?
01-28-2011, 12:32 AM | #515 |
01-28-2011, 12:33 AM | #516 |
01-28-2011, 12:35 AM | #517 |
VA72C10
Looking good! Keeps getting better.
Looking for a 67-72 swb or blazer project in or around VA. |
01-30-2011, 05:34 PM | #518 |
Thanks!
Finally got the ECE trailing crossmember in. It wasn't as bad as I thought it would be and I really like the clearance it provides. The exhaust should tuck up really well...
01-30-2011, 06:20 PM | #519 |
big guy
looking great, i love what you have done to it.
on a side note thanks for the help with my truck. Ray |
01-30-2011, 06:41 PM | #520 |
Look good. Let's get a shop. Lol
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
02-12-2011, 04:24 PM | #521 |
Old School
Great job! I have been building my truck back 80% stock, but reading your thread makes it very hard to stay with my plan. Question, are your rear inner fender wheelwells widened? If so, how much? And did you have to remove the rubber axle bumper mount from the side of the frame?
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
02-13-2011, 04:21 AM | #522 | |
Thanks there'a bout 5 inches wider. You don't have to remove it, but I did since I installed a C-notch.
03-22-2011, 09:52 AM | #523 |
Finally something to update! I can't believe this "2 week project" has taken almost 3 months, . Oh well. I have the new headers installed and they tuck up real well. I just need to find time to take the truck to my muffler guy so he can do a complete new exhaust system that will include 3 chamber Flowmasters, H-pipe, new tips and electric cutouts.
03-22-2011, 10:00 AM | #524 |
67cheby
man i bet that thing sounds unreal with the cut outs !!
03-22-2011, 10:17 AM | #525 |
Restoration Virgin!
I've been wondering where you've been Rob....I thought maybe you been working on your sons truck
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
