Old 02-05-2011, 12:09 AM   #501
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
A brass punch works well too.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-05-2011, 12:11 AM   #502
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Originally Posted by MARKDTN View Post
I am interested to see how you handle the HVAC, Which column you use, and the instrument cluster. I will keep an eye on this. Great work!
New HVAC because it will actually cool the whole truck, and it is free. Extremely difficult to install !!!
Old column because I want it to still look old.
Old style cluster for same reason.
I may have to add a lower valance instrument panel to house extra things I need.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 02-05-2011, 12:12 AM   #503
drewskiren
drewskiren's Avatar
Originally Posted by VA72C10 View Post
you can also use a scrap piece of copper pipe with one end flattened in a pinch...
I've got that!
Drew
Old 02-05-2011, 12:30 AM   #504
silverboy02
you can get one from autobodytoolmart.com
or here:
http://cgi.ebay.com/ebaymotors/Coppe...item2a0ddd4f75
silverboy02 is offline   Reply With Quote
Old 02-05-2011, 12:57 AM   #505
mcbassin
Still Learning
mcbassin's Avatar
Nice work Drew! Thanks for the update with pictures. I can't wait to see the sandblasting pics. I just did some of that a while back.......fun.
mcbassin is offline   Reply With Quote
Old 02-05-2011, 02:42 PM   #506
drewskiren
drewskiren's Avatar
Morning pics.
Final prep before blasting.
Working with my 2 boys!
Drew
Old 02-05-2011, 07:12 PM   #507
VA72C10
VA72C10
VA72C10's Avatar
Looking good guys
Are you sure my schedule wasn't right....you're really moving on the truck right now...you might be done before your target date if you can keep this pace up
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-05-2011, 11:30 PM   #508
drewskiren
drewskiren's Avatar
Looking good guys
I wish I could finish early, but I'm sure I will run long.
Prime in, out, and under Everything, complete airbag system, build rear suspension, finish all body work, edge in everything, paint everything white and blue, convert A/C system, convert brake system, convert steering system, trans linkage, convert complete wiring systems, mount all under hood items, reassemble entire truck after paint, redo entire interior, whew!
Drew
Old 02-06-2011, 12:41 AM   #509
drewskiren
drewskiren's Avatar
Saturday night pics.
Gotta make progress right?
Sarah and Elizabeth, the master blasters.
Drew
Old 02-06-2011, 12:44 AM   #510
drewskiren
drewskiren's Avatar
Sweet tailgate from Arizona cleaned up really well.
Raised floor section for gas tank is ready for seam sealer, then we can paint the bottom of cab floor, bed floor, and inside bed on Sunday.
Drew
Old 02-06-2011, 01:31 AM   #511
VA72C10
VA72C10
VA72C10's Avatar
Looking great!!!
Old 02-06-2011, 01:32 PM   #512
Dieselwrencher
Very nice! It's great the whole family gets involved!
Ryan
Old 02-06-2011, 06:49 PM   #513
extremesounds13
Looks great!! I can't believe how fast you work!
extremesounds13 is offline   Reply With Quote
Old 02-06-2011, 09:05 PM   #514
drewskiren
drewskiren's Avatar
Sandblaster with good air pressure is the bomb!
Cowl panel is perfect, how better to get the paint off all the grooves?!
Bed is painted up, but night time pics are no good. Ready to undercoat bottom of the bed, and I might go ahead and Rhino line inside the bed now instead of waiting.
Drew
Old 02-06-2011, 09:07 PM   #515
67chevy1series
67chevy1series's Avatar
wow looks clean! if i had a metal floor i would have hoped it would be this nice....
67chevy1series is offline   Reply With Quote
Old 02-06-2011, 09:09 PM   #516
lolife99
67-72 parts collector,…
lolife99's Avatar
Be careful sandblasting sheetmetal.
I've seen it warp the panels.
Keith
Convert to disc brakes.
Old 02-06-2011, 09:16 PM   #517
drewskiren
drewskiren's Avatar
I have seen it myself, I figured the bed bottom wouldn't matter since it's so beat up anyway. The cowl only had the factory paint and it was so thin it took all of 3 minutes to blast the whole thing.
Drew
Old 02-06-2011, 09:41 PM   #518
VA72C10
VA72C10
VA72C10's Avatar
Looks good! I'd say since it isn't perfect according to you and you plan to use it, I'd line the underside and the top.
Old 02-07-2011, 12:54 PM   #519
drewskiren
drewskiren's Avatar
All trucks can go forwards and backwards and side to side.
I think mine should go up and down too.
Drew
Old 02-07-2011, 01:05 PM   #520
MARKDTN
I will be waiting excitedly to see the HVAC. Are you using late as in 2000 up stock GM truck? I thought about cuttting that section out of a new firewall and grafting it in. Might also could move it out a little if necessary to clear the dash inside. Cool project!
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-07-2011, 01:19 PM   #521
67cheby
67cheby
67cheby's Avatar
cant wait to see it " GO UP AND DOWN " !!
67cheby is offline   Reply With Quote
Old 02-07-2011, 01:33 PM   #522
ERASER5
ERASER5's Avatar
Tease!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 02-07-2011, 02:12 PM   #523
VA72C10
VA72C10
VA72C10's Avatar
The body on the crewcab goes up and down....up and down......
Old 02-07-2011, 02:15 PM   #524
drewskiren
drewskiren's Avatar
Nice one Barney.
Pretty stinkin funny.
Drew
Old 02-07-2011, 03:14 PM   #525
VA72C10
VA72C10
VA72C10's Avatar
My helpers are a little younger than yours so I think the purple dinosaur did in fact influence my comment (3 and 6yr old girls)
