05-24-2011, 04:33 PM | #501 |
Re: Extreme Powder Coating '65 C-10 Shop Truck
This is the process for top-coating the C-10 frame...we sanded the frame down, and blew the dust off ... wipe down with wax and grease remover... tag rag off the dust and apply top-coat.
edited by staff Last edited by kart34; 05-24-2011 at 09:26 PM. |
05-24-2011, 04:44 PM | #502 |
The frame moved back into the paint booth where it got its final coat and headed into the curing oven...came out looking like glass. Tiger Drylac Ral.7042 gray 90 -95 percent gloss . You always get a good finish with Tiger products. We used about 4 lbs. of powder for the topcoat on the chassis and misc. parts.
edited by staff Last edited by kart34; 05-24-2011 at 11:13 PM. |
05-24-2011, 06:17 PM | #503 |
Wow, that looks incredible. Nice work, now get that pig back together!
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-24-2011, 06:31 PM | #504 |
OK assembly starts Wed. AM Powdercoating inside of cab / roof /firewall soon .. maybe Friday.
edited by staff |
05-24-2011, 06:55 PM | #505 |
67-72 parts collector,…
Quality work in those pics!
There are alot of powdercoaters should take a look at your process. I wish you were closer to me,... so I could send you some business!
05-24-2011, 09:02 PM | #506 |
Lolife99, We are working on a small parts powdercoating program. You ship it too Extreme .... we pay the frt. back to you via US Post office.
edited by staff |
05-24-2011, 09:21 PM | #507 |
I want to see a shot of Nate's bridge in that color in the sunshine. Damn that frame looks so good.
05-24-2011, 09:47 PM | #508 |
Going to have a little pinstriping done asap on the Porterbuilt bridge. Looks like we will have the rolling chassis at "Back to the Fifties" June 17,18,19, on display in the Extreme Powder Coating booth.
edited by staff Last edited by kart34; 05-24-2011 at 09:48 PM. |
05-25-2011, 03:13 PM | #509 |
Rear End Housing and Pallet of parts for the C-10 coated!!
Organizing other parts for powdercoat! Cleaning up the C-10 shop today
edited by staff |
05-27-2011, 11:57 AM | #510 |
Awesome as usual. I can't imagine the time you guys have into that beast.
05-27-2011, 11:59 AM | #511 |
This truck isn't back together yet? Man, I am dying to see this bridge with the pin stripes.
05-27-2011, 01:15 PM | #512 |
Working on it this weekend... stay tuned in !!!!
edited by staff |
06-01-2011, 02:49 PM | #513 |
Got the cab back from the sandblaster.. GT Blast-Tech. We have to fix a few rust spots that appeared in the blasting process. We will shoot a red oxide epoxy powdercoat primer on it asap. Then fix the rust spots and starting working with the powdercoatable bondo product we will be testing. stay tuned.
edited by staff Last edited by kart34; 06-01-2011 at 08:41 PM. |
06-01-2011, 02:52 PM | #514 |
Jesse is getting it put back together... should have a rolling chassis this week. Relic Pinstriping is going to work his magic on Monday.
edited by staff Last edited by kart34; 06-01-2011 at 08:38 PM. |
06-02-2011, 01:23 PM | #515 |
The center council has a built in tray for the Garmin - Dynamat is in - fixed up the floor in the cab - this is our powdercoat bondo we will be using - and the frame and parts are coming together!
edited by staff |
06-02-2011, 01:27 PM | #516 |
more shots of putting the C-10 back together
edited by staff |
06-02-2011, 01:29 PM | #517 |
What is your exhaust coating process? What type of material is used?
06-02-2011, 01:38 PM | #518 |
Man, that looks awesome. Love the exhaust, too.
Scoti, there is a powder I have used that looks exactly like that called "header coating" that cures at 400 and is supposed to be good to 1500 degrees or so once cured. I was going to use it on my street bike project until I round the titanium ceramic. The ceramic coating worked better than the powder as far as engine performance, but did not hold up to daily driving like the powder does. I hope to see that chassis in person some day, that powder looks incredible.
06-02-2011, 02:51 PM | #519 |
Hey Kart, been following your build for a while. The frame is looking great(and everything else). I just noticed that it looks like you might be using an early mustang or falcon gas tank. Is this true? If so I'm curious about what you did about the sending unit ohms or do you have a guage that matches? I'm seriously thinking with going with that tank on my 66 LWB with stock fuel guage and need to adapt to the stock fuel guage.
06-02-2011, 09:09 PM | #520 |
Scotti, The exhaust was custom built in house . I purchased some mandrel bends on e-bay and Jesse worked his magic. The coating process is burn off all oils ( bake in oven for a few hours or more) . Then we blast them with alum. oxide and apply the liquid ceramic . This is the same coating that we sprayed on the 2011 Ridler Award winner for Bruce Ricks.
edited by staff |
06-02-2011, 09:17 PM | #521 |
The gas tank is from Tanks Inc. and is for a 65 Mustang or Falcon ? We have not done any wiring yet but will be using Classic Intruments elec. gauges. Von Hot Rod white faced with blue pinstripng limited edition gauges so I hope we can get it wired up to work with the Mustang sending unit.
edited by staff |
06-03-2011, 12:05 AM | #522 |
It should be easy if you can get a guage that is for the early mustang with the proper ohms. It not I found this link to a vendor that can modify or build a sender to work with your guages. You might check them out. I haven't contacted them yet because I'm not quite ready to install my tank.
http://tristarrradiator.com/Custom%2...ed%20Page.html |
06-03-2011, 01:02 AM | #523 |
chevy only
wow thats a bingo!! killer job duudes great skills
CHEVY ONLY... Nothin Else ! |
06-03-2011, 01:04 PM | #524 |
You used ceramic on the exhaust! Bravo, sir. This build is top shelf at every level.
06-03-2011, 03:15 PM | #525 | |
Saw the picture of the garmin nuvi and thought I would give you a heads up, there is a nuvi 765t that can be purchased as a refurb unit for $133.00 on amazon. I build motorcycle audio systems and this little power house has all the same features as the 900.00 brothers, a micro sd card slot, audio output, and mike out put, bluetooth for the phone......keep it in mind on your next build. Kieth |
Tags |
'65, c-10, carter hickman designs, extreme powder coating |
