Old 02-15-2013, 06:29 PM   #501
gdavis
gdavis's Avatar
Re: 1968
bondo te rear fender that had some whopp-d-doo's Some people call it dents I call them whoop-d-doo's. They still need to be sanded andprimed.
gdavis is offline   Reply With Quote
Old 02-15-2013, 06:32 PM   #502
gdavis
gdavis's Avatar
Re: 1968
also mounted the bed rails for the floor.
Old 02-15-2013, 06:36 PM   #503
gdavis
gdavis's Avatar
Re: 1968
In the above picture is a center bed rail. Can anyone tell me where it fits. Or send me to a place of a build where someone has a picture of the rails on the truck.
Old 02-15-2013, 07:22 PM   #504
Low Elco
Re: 1968
Ask and ye shall recieve-
http://67-72chevytrucks.com/vboard/s...=501131&page=6
Low Elco is offline   Reply With Quote
Old 02-17-2013, 01:24 PM   #505
gdavis
gdavis's Avatar
Re: 1968
Well, whereshould I start. Finshed sanding the rear fender where the bondo was applied. Primed it so the rust will not form on it till I get time to prime the whole truck with K2 primer. Here is a picture of one of my little herpers.
Old 02-17-2013, 01:27 PM   #506
gdavis
gdavis's Avatar
Re: 1968
Then I welded the end caps on the bed sides. Still need to do a little magic so they can be primed. I am going to sand blast them first. Then a slight bondo to cover all my sins.
Old 02-17-2013, 01:29 PM   #507
gdavis
gdavis's Avatar
Re: 1968
Here is a picture of the door after I finshed welding bondo and primed. All dome with it.
Old 02-17-2013, 01:35 PM   #508
gdavis
gdavis's Avatar
Re: 1968
I need someone to tell me where the center bed rail on a 1968 stepside shorty goes. I installed the others and the center will stick up above the rest of the bed rails. I put a 6 ft. level across the bed rails and the center want work. Am I doing something wrong. Or maybe over looking something or over thinking it.
Old 02-18-2013, 09:04 PM   #509
gdavis
gdavis's Avatar
Re: 1968
Today, I finshed welding up the end caps on the bed sides. All done with that small project. Except sand blasting them and a small bit of bondo on the end caps. Then I wire wheeled the drivers side bed side. Going to sand blast them when I return from Dennis Truck Parts. In St. Petersburg, Fl. He has a lot of my parts in so I am going to pick them up tomorrow. Let you know what I have tomorrow Night.
Old 02-18-2013, 10:11 PM   #510
Xeen
Xeen's Avatar
Re: 1968
For a wood stepside bed You should have a total of 4 cross sills, 1 bed reinforcement strip and 1 rear cross sill, refer to page 31 of the online LMC Truck catalog for a picture and parts listing.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 02-19-2013, 07:50 PM   #511
gdavis
gdavis's Avatar
Re: 1968
On page 31 on LMC it shows 5 4 bed rails and 1 center piece. Where do the center piece fit.
Old 02-19-2013, 07:53 PM   #512
Bhelton
Bhelton's Avatar
Re: 1968
looks good!
Bhelton is offline   Reply With Quote
Old 02-19-2013, 08:37 PM   #513
gdavis
gdavis's Avatar
Re: 1968
Today I went and picked up some of my parts in Pineallas Part, Fl. I was a little disappointed. The price he has on the item is not what I had to pay. He charged me for his shipping. There should not be any shipping if I pick them up. Well I only got a few items, so now I am going to serchfor another dealer.
radiator core support used
rear door pillar
floor pan section
radiator mounts with bolts
cab mounts with bolts
outer rocker
inter fender
Old 02-19-2013, 08:38 PM   #514
gdavis
gdavis's Avatar
Re: 1968
pic
Old 02-19-2013, 08:47 PM   #515
gdavis
gdavis's Avatar
Re: 1968
So, when I returned I sarted working on the core support. It had a few pin holes on the bottom. I welded another plate over the bottom . I Prime it and paint it black.t probably would not have made any difference but now I know. Going to sand blast it tomorrow If I have time.
Also A picture of my adophed boys play? working? They seem to have fun so what is the difference.
Old 02-19-2013, 08:51 PM   #516
gdavis
gdavis's Avatar
Re: 1968
Radiator core support mounting hardware with bolts.
Old 02-19-2013, 09:06 PM   #517
Xeen
Xeen's Avatar
Re: 1968
Hmm that looks like the 69-72 core support mounting kit to me. I thought you were keeping the 67-68 front end?
Old 02-20-2013, 08:12 PM   #518
gdavis
gdavis's Avatar
Re: 1968
Nothing gets by you my friend. It is a 69 to 72. I just went outside and checked and it is . Looks like I will have to call him tomorrow.
Old 02-20-2013, 08:35 PM   #519
gdavis
gdavis's Avatar
Re: 1968
Today, I installed the rear door pillar. The floor pan section. Boy what a job the floor was. I cut the floor out before I got the panel and it was to large. A lesson learned. Don't cut the section out before you have the panels. So I had to add some metal to the front and rear of the panel. The pillar went on without a hitch. I went to harbor Frieght the other day and I picked up the wrong cutting wheels. So tomorrow I will have to buy them local. They are the same price but they seem to last longer.
Old 02-20-2013, 08:39 PM   #520
Bomp
Bomp's Avatar
Re: 1968
I hear ya on that one. "Have panel before you cut".
I cut cab in half before other cab section was present.
Bomp is offline   Reply With Quote
Old 02-20-2013, 08:40 PM   #521
gdavis
gdavis's Avatar
Re: 1968
The floor section took me about 6 hours. I don't want to do that any more. It was a bear. My own fault anyway it is done.
Then I wire wheeled the pass bed side and the core support.
Old 02-20-2013, 08:43 PM   #522
gdavis
gdavis's Avatar
Re: 1968
Tomorrow I will maybe sand blast them and paint the core support black. and prime the bed side.
Old 02-20-2013, 08:46 PM   #523
gdavis
gdavis's Avatar
Re: 1968
I want even do that again. First I will have parts then cut.
Old 02-20-2013, 09:07 PM   #524
oilyrag80
oilyrag80's Avatar
Re: 1968
Great job on the floor looks great!
oilyrag80 is offline   Reply With Quote
Old 02-20-2013, 10:52 PM   #525
mcbassin
Still Learning
mcbassin's Avatar
Re: 1968
Cool project(s). Looks like you have more than your share of fun cut out for you. Subscribed.
mcbassin is offline   Reply With Quote
