Old 06-10-2015, 01:47 PM   #501
Baddflash
Re: Dutch '59 Fleetside Longbed
I hate to suggest this as you are so far along, but, what about moving the drivetrain closer to the firewall to gain the clearance you need for the steering rack. Last resort kind of thing but if you're stuck it might be a way out.
Baddflash is offline   Reply With Quote
Old 06-10-2015, 05:09 PM   #502
RockinKees
RockinKees's Avatar
Good point Baddflash, but that's no option for me.
If I find the right headers, maybe modify them, then it's all good.
Remember, I'm just at the point of buying my fourth set
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 06-11-2015, 04:41 PM   #503
RockinKees
RockinKees's Avatar
Sold the headers again.
Now wait for new ones to arrive
Bolt on the brakebooster, MC and brakepedal yesterday, finally going to built something
Plumbed the brakes and booster today:
Brakepedal is in, it's all black, so a bit difficult to see...
After the brakes I testfitted the steeringpump. I've got a bracket with the pump from the same '76 Chevy Van as is the steeringcolumn.
Its a bolt in!
Just have to make a bolt and bushing to bolt it the header later on.
Now that it fits so nice I have to make the steering hoses, to mate the GM pump to the Jag rack. I asked around and that shouldn't be a problem if I know the thread sizes of the connectors.
So looking for that.
One off the list.....
Cheers!! Kees.
Kool Guyz CC
Old 06-11-2015, 05:22 PM   #504
Advanced Design
Advanced Design's Avatar
Good progress Keys. I have to ask about the copper colored brake line...of course that isn't copper is it?
Advanced Design is offline   Reply With Quote
Old 06-11-2015, 06:10 PM   #505
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-12-2015, 07:31 AM   #506
RockinKees
RockinKees's Avatar
Thanks Kim and Doug!!
Doug, what is the problem with copper brakelines?
I've used them for 30 years and never had a single problem with them.
Just not overtighten them!
There legal too, overhere
Cheers!! Kees.
Kool Guyz CC
Old 06-12-2015, 08:54 AM   #507
jkeating1
jkeating1's Avatar
Originally Posted by RockinKees View Post
....I've used them for 30 years and never had a single problem with them.
and--use a lot of rubber isolated clamps and don't let them touch any steel parts (vibration abrasion)
JK
jkeating1 is offline   Reply With Quote
Old 06-12-2015, 11:32 AM   #508
Advanced Design
Thanks Kees, I learn something every day.
Old 06-14-2015, 05:13 AM   #509
RockinKees
RockinKees's Avatar
Sure I use a lot rubber isolated clamps
I know what can go wrong when the line breaks....
Cheers!! Kees.
Kool Guyz CC
Old 06-14-2015, 09:00 AM   #510
OneOffStroker
I will lend you a hand since I've already worked through a few problems with the Jag IFS in my '57.
For headers, I ordered the Flowtech 11108FLT from Summit. The drivers side has the right bends to get away from the steering box, but I will have to run 3 steering joints and a support bearing, but if it works then I'm good with that.
The Jag steering ports are 1/2"-20 inverted flare and a 5/8"-18 inverted flare. I bought flare to AN adapters so that I can simplify my lines with AN fittings. Those adapters are also from Summit, part numbers RUS-640330 and RUS-640380.
I hope this helps. Keep p the good work!
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 06-14-2015, 12:02 PM   #511
RockinKees
RockinKees's Avatar
Yep, that sure helps a lot!!!
And right on time
I will have the lines made for me this week.
For headers, probably I go with the Ramhorns I have, I will testfit them and see of those will work.
If not, I will look into your Summit numbers.
Thanks a lot OneOffstroker!!!
Cheers!! Kees.
Kool Guyz CC
Old 06-15-2015, 11:39 AM   #512
RockinKees
RockinKees's Avatar
Will a set of '88-'95 headers fit my '71 SBC?
I mean, is flange at the head the same where you bolt the headers on the heads?
I ask this because the Ramhorns doesn't fit either...
The rack and pinion is playing with me
Cheers!! Kees.
Kool Guyz CC
Old 06-15-2015, 12:10 PM   #513
jkeating1
jkeating1's Avatar
just eyeballing it, this gm truck header from summit looks like it dumps far enough back to be behind the engine mounts and steering.
SUM-G9014
$179.97
JK
Old 06-15-2015, 12:21 PM   #514
RockinKees
RockinKees's Avatar
Thanks John!
I found some headers too, I just want to know if I can use headers made for SBC from '88-'95.
Does those fit the boltflange at my '71 heads?
Cheers!! Kees.
Kool Guyz CC
Old 06-15-2015, 12:27 PM   #515
RockinKees
RockinKees's Avatar
Here can you see the problem.
They clear the rack and pinion, but the height is too short to make a decent downpipe. Now the u-joint get in the way...
They sure look cool thou!
Cheers!! Kees.
Kool Guyz CC
Old 06-15-2015, 01:36 PM   #516
Advanced Design
Thanks John!
Kees, I am not sure and hopefully someone else will chime in. I vaguely recalled something about exhaust manifold bolt placement and came across this picture showing a change in 1983. Best bet is to Google the headers you are looking at to determine if they will fit the bolt positions for sure.
Old 06-15-2015, 05:17 PM   #517
RockinKees
RockinKees's Avatar
Well,
I thought, I give Sanderson a quick email....
Instant replay:
Date: 2015-06-15 12:51:41
Message:
Hello Kees:
Yes, headers for 1988-1995 engines fit your early heads.
The concern is the flange, not the bolt pattern. Some newer performance cylinder head designs feature D-port or different plug angles. If the headers fit stock type late model heads they will also fit your '71 heads.
Best Regards,
Sanderson Tech Support
http://www.sandersonheaders.com
So, that's my answer right there
If the're made for stck type heads, it should fit with no problem.
Super service overthere by Sanderson!
Now I can go on looking for some new ones, pair number five
Cheers!! Kees.
Kool Guyz CC
Old 06-17-2015, 10:56 AM   #518
tpimuncie
tpimuncie's Avatar
Nice progress!
1959 apache 1948 chevy coupe
http://67-72chevytrucks.com/vboard/s...d.php?t=562949
1964 gmc burban build for pops
http://67-72chevytrucks.com/vboard/s...d.php?t=724632
tpimuncie is offline   Reply With Quote
Old 06-18-2015, 05:10 AM   #519
Nev68
Nev68's Avatar
I have the same problem even though my steering rack spline is on the other side.
I have tried stock cast manifolds, block huggers, tight block huggers, long primary headers.
None of them give enough steering column / shaft clearance.
I have come to the conclusion that a fabricated header, at least on the driver side (RH side for me ) is the only way to solve this one
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 06-18-2015, 06:08 AM   #520
bogape
Good work Kees, you're getting on well...
I'm still a long way off this point with mine, but have you thought about altering the rack mounts, or making some spacers, to rotate it or/and move it back a bit?
might help, might not!
bogape is offline   Reply With Quote
Old 06-18-2015, 06:12 AM   #521
bogape
maybe even...
rotate
+back
+down
+to the left (if you have enough lock spare)
Old 06-18-2015, 11:56 AM   #522
RockinKees
RockinKees's Avatar
tpimuncie
Nice progress!
Thank you Sir!!
Nev68,
I thought you would have the same problem
Bought some new headers, that I think clear the steering rack, but have to modify the shaft.
We'll see in a few weeks how that ends....
Bogape,
Never thought of that.
Great tip!!
I will look into that.
Rotate and a bit to the left.....maybe.....
Cheers!! Kees.
Kool Guyz CC
Old 06-24-2015, 03:51 PM   #523
RockinKees
RockinKees's Avatar
Not much done last week.
Only repaired the hinges.
I took out the old pins with nylon bushes (don't think they are stock, don't they??) and pushed in some new bronce bushes and new pins.
Hinges work like new now
Old and new....
Now that's done, while waiting for headers to arrive, I want to know if someone can point me in the right direction of mounting points for three-point safety belts.
I have a small window cab, someone allready made shoulder mounts and post some pictures of that??
Thanks!!
Cheers!! Kees.
Kool Guyz CC
Old 06-26-2015, 05:05 AM   #524
RockinKees
RockinKees's Avatar
Finally finished the trans cover.
Ground off the upper part off of the old beat up cover and welded it to a new steel plate.
No holes anymore
Looks a lot better now!
Cheers!! Kees.
Kool Guyz CC
Old 06-26-2015, 08:04 AM   #525
Advanced Design
The trans cover looks really good. Nice work!
