02-18-2016, 01:50 PM | #501 | |
Re: Starting my engine build
02-18-2016, 01:52 PM | #502 | |
02-18-2016, 02:22 PM | #503 |
02-19-2016, 12:17 AM | #504 |
Great advice! I bet you could find one in a wrecking yard for under 30 bux. Easy swap and by far the best bang for the buck. Any bar off a 2wd from a 73-87 will work as well.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
02-19-2016, 04:15 AM | #505 | |
I ran a wire from the fuse panel heater location to a switch on the aftermarket tach mount direct to a new blower motor. They are fairly simple systems, everything is covered in electrical. What is not there you can figure out by the wiring diagram and some basic electrical google search. Again the nice thing about these rigs, simplicity. |
02-19-2016, 07:39 AM | #506 | |
(They are bigger and mount different than after market) (I saw a picture of your rear axle and it shows 2 springs mounted to the rear axle with u bolt clamps ? Take a few pictures of your rear suspension so we can see whats going on ?) ( there are more wheel/axle choices for 5 lug ) |
02-22-2016, 05:09 PM | #507 |
Back to work finally! I went with the Performer RPM, no air gap this time. Saw a lot of dyno sheets showing about 6-7 hp increase with the air gap, but I want to keep the drivability
02-22-2016, 05:45 PM | #508 |
What's the best way to make sure the timing is set right and to drop the distributor in? I read to rotate the engine to 5 degrees BTDC, then put distributor in with number one wire lined up with the pointer
02-22-2016, 06:54 PM | #509 |
I went with the satin finish and I think that was a good call by somebody earlier in the thread. The combination or satin and bits of chrome here and there will look great
02-22-2016, 06:57 PM | #510 |
Front
02-22-2016, 07:00 PM | #511 |
If you lined up the dots on the cam and crank gear, don't forget to rotate crank 360 degrees before installing distributor pointing to plug wire #1. If you don't, you distributor timing will be 180 degrees out.
02-22-2016, 07:24 PM | #512 | |
Ok so it was at #1 TDC and I adjusted half the valves, then I turned it one full rotation so the #6 was at TDC, then adjusted the remaining valves. I haven't rotated it since, so just to clarify, I need to rotate one more full turn to be back at #1 TDC and THEN drop the distributor, correct? |
02-22-2016, 09:10 PM | #513 |
One other thing, can I make the #1 cylinder any spot I want on the distributor? And then go with firing order clockwise from there?
02-22-2016, 10:06 PM | #514 | |
If you where on 6 oclock on the cam gear and 12 oclock on the crank gear when you started out, then at that time you where on #6tdc. To be safe on whether you're on #1 or #6 tdc, it's easier to pull #1 plug, feel for compression, line up your timing tab at zero, then install your distributor with rotor pointing at #1. |
02-22-2016, 10:18 PM | #515 | |
02-22-2016, 10:20 PM | #516 |
I pulled a rookie move and a few weeks ago I bought a water pump and painted it before I compared it to the old one. Parts guy said it was for a 70' but it's a short pump when my old one is a long pump. Can't return it cuz it's painted, so how much changes from long to short? Pulleys? Other stuff? I'm switching to electric fans so no need for the clutch fan if that matters
02-22-2016, 11:39 PM | #517 |
Probably a silly question but is it okay that there's paint on the surface where the water pump gasket sits?
02-22-2016, 11:51 PM | #518 |
What can I use safely to clean up this starter? May just get a new one if I can't clean this one up
02-23-2016, 12:29 AM | #519 |
60-66 Nut
All trucks '72 and earlier came from the factory with short water pumps. The pulleys and accessory mounting brackets are different between a short and long water pump. If your engine previously had a long water pump and all the pulleys l;ined up, then you will need another long water pump. Be aware that there are 2 variations in the V-belt type long water pumps for the small block. The difference is in the boss for the alternator top bracket and the hole for the power steering pump bracket. It will be either a smooth bore or threaded.
02-23-2016, 03:14 AM | #520 |
It's almost midnight I'm throwing in the towel
02-23-2016, 03:17 AM | #521 |
Pic
02-23-2016, 03:21 AM | #522 |
Looking like an engine again finally. I got new MSD plug wires but I wanted to see how it looked with the old ones. The old ones aren't long enough for the wire looms so I'm gonna ditch them and use the new red MSD ones
02-23-2016, 04:59 AM | #523 |
Did you put RTV (coolant resistant) on the water pump gaskets? Or did they have the sealant on them? Did you put thread sealant on the bolts that go into the water jacket?
Per the paint on the water pump gasket area, i always scrape it off with my gasket scraper off so i cant tell you if it matters. Per the starter i would probably use what ever i could find available, carb or brake cleaner, or the stuff you cleaned the block with.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-23-2016, 12:27 PM | #524 | |
02-23-2016, 01:38 PM | #525 |
spark plug wire crimping tool
Google this.... click images
