04-17-2018, 09:56 AM | #501 |
Happy to be here
Re: "Elwood" the 77_remix
This position lead us to the obvious choice for an exit point for the supply lines. We opted to use the RestoMod Air "Slimline" bulkhead. They offer a huge selection of styles, shapes, and colors of the bulkheads. We wanted the least amount of surface exposed so this was an obvious choice.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-17-2018 at 10:12 AM. |
04-17-2018, 10:19 AM | #502 |
Happy to be here
The location of the bulkhead was dictated by position of the Haymaker and our desire to utilize one of the existing holes. Beyond a clean install, our objective is to maintain structural integrity.
04-18-2018, 10:44 AM | #503 |
Happy to be here
With the Haymaker location determined, holes drilled, and interior lines routed, we moved on to the control panel. Restomad Air makes a direct fit control panel that makes this segment of the install simple. It takes more effort to remove the factory controls and cables than to bolt this unit in place. Once installed it looks right at home in our original dash.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-18-2018 at 10:55 AM. |
04-22-2018, 07:14 PM | #504 |
Happy to be here
Now that we had the system mocked up we pulled everything back out. I needed to create a pattern for the filler panel that Mike Losh would make. It will have raised panels to clear the obstructions on the firewall, and a recessed area for the bulkhead.
I put the temporary panel back in place once again to ensure the holes all lined up. It came off after some adjustments and a template was laid out. The shape was cut and holes were marked and opened up.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-23-2018 at 10:34 AM. |
04-23-2018, 07:42 AM | #505 |
Still Learning
Looking good Ken!
04-23-2018, 10:35 AM | #506 |
Happy to be here
04-23-2018, 11:24 AM | #507 |
I'm just glad to be here!
Now off to Mike for him to work his magic. Progress looks good Ken!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
04-24-2018, 11:59 AM | #508 |
Happy to be here
Mike has been patiently waiting for me to get this done. I cant wait to see the finished product.
04-25-2018, 01:03 PM | #509 |
Happy to be here
One step closer to production. Here's the lay out for the production piece from Slosh Tubz The area around the bulk head hole will be recessed. The two shapes to either side will be raised.
04-26-2018, 10:03 AM | #510 |
Happy to be here
Mike Losh sent a sneak peak of his first production panel. He is shipping it out for me to test fit to determine if any final adjustments need to be made. Hopefully the last few pieces from RestoMod Air needed to finish the dash install will be here today.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-26-2018 at 11:24 AM. |
04-26-2018, 11:48 AM | #511 |
Happy to be here
We designed this panel to be as simple as possible to install. It can be bolted in as I have done. We designed the outer flange to fit flush so you could use panel bond as well. If you choose to, welding is another option.
Initially I had hoped to keep the factory pinch weld seam. Unfortunately it would really be obtrusive and defeat the look we were after. After cutting it off and grinding it flush I felt comfortable it did not compromise the structural integrity.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-26-2018 at 11:53 AM. |
04-26-2018, 11:56 AM | #512 |
Nice! Dumb question time, will that panel fit a stock truck with standard wheel tubs?
04-26-2018, 10:58 PM | #513 | |
Happy to be here
Actually its a very good question. Yes, it will work with stock tubs.
04-30-2018, 12:14 PM | #514 |
Happy to be here
While waiting on parts from Restomod Air We worked on the audio system update. I teamed up with Retro Manufacturing to install some of their audio equipment in Elwood. I really like the Retro sound Long Beach receiver. It has a great classic look with contemporary features and can be customized to fit your application.
Its features direct link to Apple or Android devises via built-in Bluetooth connectivity The authentic push-button styling offers AM/FM RDS tuner with 30 pre-sets. There are two rear-mounted USB ports for USB cable or flash drive, and two auxiliary inputs for portable devices. It offers 25 watts x 4 channel built in power, and dual RCA pre-outs plus subwoofer output for external amplifiers. The patented InfiniMount adjustable shaft system can almost any dash with no modifications, and it can be mounted remotely for custom installation using optional extension cable. I opted for the chrome face with black buttons to match my dash and the Restomod Air control panel mounted above it. The face can be customized to look right at home in any classic install with five unique styles:Chrome with chrome push-buttons, chrome with black push-buttons, chrome with ivory push-buttons, black with black push-buttons, black with chrome push-buttons. They offer optional "screen protectors" for the display face to give it a true vintage look when the power is off.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-30-2018 at 12:36 PM. |
05-01-2018, 06:25 AM | #515 |
Niceeeee!
05-01-2018, 11:45 AM | #516 |
Happy to be here
After Chris got the Long Beach reciever installed, he added the dash speaker to test it out. Since the 73-80 dash only has a center speaker opening we opted for the RetroSound 4x10 Triax
This is a dual voice coil speaker that gives you full stereo separation from your single dash speaker location. It actually has left and right channel inputs.
05-01-2018, 03:32 PM | #517 |
chevy truck fan
ken,
nice looking radio. I am more familiar with the retro audio models are they the same? anyways kinda along the same lines.... I was wondering if the 73-87 models had a "radio delete" option like the earlier 67-72 models? I am thinking that I might do the same as I did in my '72 where I used a radio delete plate & put the "hi-end" radio & gear under the seat & still be able to use the radio remote |
05-03-2018, 09:54 AM | #518 | |
Happy to be here
05-03-2018, 10:36 AM | #519 |
Happy to be here
As always we are thrashing and crashing to get things put back together. The drivers side of the engine compartment is back together now. That gave me an opportunity to mock up the Eddie Motorsports hood hinges. The stock hinges were worn out, and it was time for an update. I wanted a cleaner look than a new pair of stock hinges would offer so I contacted Eddie Motorsports. They offer billet hinges for 73-80 GM trucks that are a work of art.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 05-03-2018 at 10:45 AM. |
05-03-2018, 10:44 AM | #520 |
Happy to be here
They offer a variety of finishes to fit your needs. I opted for the gloss black version to match the black panels under the hood. Stainless steel button heads are included. I gave them a quick polish to match the existing hardware under my hood.
Once installed they blend in nicely. They are nice to look at, but I wanted them to go with the flow and the gloss black does that very well.
05-03-2018, 02:28 PM | #521 |
Those do look nice. Hope you get it all done for this weekend. I'm headed to Salt Lake City to watch my daughter's last Gym competition for this season this weekend. Hope ya'll have a good time!
05-03-2018, 03:42 PM | #522 | |
chevy truck fan
In the square body I am going for the opposite... I would like to add a push button ignition (keyless start?) the DBW gas pedal & incorporate the cruise system too (if I am smart enough to figure all of it out! I hate to say it but I might cut the dash to add a din size new radio... please don't yell at me! although the USA & Retro sound radios have all the features as well, As far as the radio goes, I would just like to have the wireless bluetooth option so as to be able to do calls like I do in my tahoe and maxima... Thanks for letting me chime in & being able to partake of your knowledge & talents!! Jake |
05-07-2018, 10:00 AM | #523 | |
Happy to be here
After adding the Wilwood master cylinder, I determined I had almost no pedal function. I could stop, but the pedal was to the floor. Unfortunately I had no time to play with the brakes. I figure stopping is over rated. We loaded Elwood up on the trailer, and went to strap it down. Thats when I discovered a cooloant leak. It was coming from the radiator hose where it meets the water pump. I assumed it was a bit loose and tried tightening it. That made the leak worse. i realized it the hose section was not on far enough so I loosened the clamps to push it on further. Yes, I knew it was a bad idea to be directly under the hose looking up at it, but it was the only way to access it while on the trailer. I attempted to push the hose further on. This forced the hose off, and a massive stream of hot water and coolant gushed down. It went in my eyes, ears, nose, and a large quantity was swallowed. After cursing profusely, I hosed myself off. I looked at the truck, shruggged my shoulders and decided "It ain't fixing itself" and crawled back under. An hour later I was all cleaned up and headed for the C10 Nationals.
05-08-2018, 11:49 AM | #524 | |
05-15-2018, 12:10 PM | #525 |
Happy to be here
I have some catching up to do in my yard, but I should be back on this project soon. I am working with Eddie Motorsports to continue updating the motor. I'm going to install and document a S Drive serpentine system. This will tie in with the RestoMod Air A/C system.
