02-24-2019, 09:40 PM | #501 |
Happy to be here
Re: "Crewcab Jake" the 84 to 74 conversion
Scot I played conservative due to lack of time. We used the same set up that I ran on Scarlett and Elwood. They are 265/35/22 on 8.5" up front and 285/35/22 on 10.5 in back. Tires are Nitto 420s. I'm considering the 305/40 in back. I want the width, just not sure how the staggered sidewall will look.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-26-2019 at 11:08 AM. |
02-24-2019, 09:53 PM | #502 |
Happy to be here
Thank you sir
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-25-2019 at 01:28 PM. |
02-25-2019, 11:08 AM | #503 | |
The 285/45's yield 5.04" sidewall height. From what I remember, Nitto offered the 305/40 so it comes in @ 4.80" sidewall which better matches the fronts. The 265 section width on a 8.5" wheel also better matches a 305mm section width on a 10.5: 265/8.5 = 31.1764 31.1764 x 10.5 = 327.35
02-25-2019, 01:41 PM | #504 | |
Happy to be here
Right now I have a visual rake with a wheel gap that appears to visually balanced. I'm afraid the the 305 will bee too much sidewall. I wont know for certain till I have the front spring rate dialed in. I still need to add the rest of the sound deadner, glass, and seats before I can weigh the truck and set my spring rates.
02-25-2019, 01:54 PM | #505 |
Wow Ken, Jake looks like a million bucks!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
02-25-2019, 02:54 PM | #506 | |
67-72 parts collector,…
I'm really off my tire game. A 305 would look nice.
02-25-2019, 03:23 PM | #507 |
Happy to be here
Thanks so much
I guess I'm used to them by now. this is the third set of the Nitto 420s I have had in this size.
02-25-2019, 03:27 PM | #508 | ||
02-25-2019, 10:13 PM | #509 | |
Happy to be here
* I edited my original post to prevent confusion in the future.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-26-2019 at 11:09 AM. |
02-28-2019, 11:31 AM | #510 |
Happy to be here
Now that the LST dust (mud) has settled its time to coordinate with Aaron at Homegrown Hotrods and discuss our next step.
We decided that the interior needs to be completed for the next phase. That means that the cabin needs to be enclosed. Before I install the windows and Precision Replacement Parts seals, he needs to fine tune the door adjustments. Since I built this truck from at least eight donors the fitment was not great. Aaron did a good job in a short period getting them close, but its time to dial them in so they can be sealed up with Tamco sealer. I'll post updates as the progress continues.
03-02-2019, 11:36 PM | #511 |
Happy to be here
This evening I got home from running service calls and started the next stage of the build. Since Aaron will be working on the doors soon, I want to ensure they are ready for him.
I started working on hanging the door panels. I have a set of Suburban panels that should do the trick. I plan dye them then update the inserts to match the seats.
03-02-2019, 11:48 PM | #512 |
Happy to be here
I had a spare dash pad so I swapped them to see if I liked the black on top, andvI'm not feeling it. It looks like the light pad will get dyed to match.
03-02-2019, 11:54 PM | #513 |
Happy to be here
My plan is to modify the existing inserts to allow room for the Silverado brushed aluminum inserts. The lower door will have black carpet kick panels with chrome trim accents.
To give a visual of what I'm thinking I installed the maroon panel that has similar trim to what I'm planning to use.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-02-2019 at 11:59 PM. |
03-03-2019, 10:32 PM | #514 |
Happy to be here
I had planned to meet with the guy that did the bodywork on Jake's doors to pick up the internal parts he had removed. He had to work today and couldn't meet with me.
I decided maybe it would be better to install the Vibro Solutions sound deadner before the regulators went back in. It was a good decision that cut my install time and blood loss in half. If you have ever worked inside of these doors, you know it's like trying to give a cat a bath....in alcohol.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-03-2019 at 10:46 PM. |
03-03-2019, 10:37 PM | #515 |
Happy to be here
Due to poor lighting I couldn't get a quality picture inside the door. The 5 mil I used was a older version of the 2 mil that had a silver foil layer. The new version is satin black like pictured on the inner door. That area is under the door panel for an additional layer of thermal barrier.
03-04-2019, 10:34 PM | #516 |
Happy to be here
Chris came by for a short shop session this evening. We want to get as much of the interior mocked up as possible before we send it to Homegrown Hotrods.
I got the door panels in position and held secure with enough screws to ensure that they were stable. We needed to install the new carpeted panels on the doors. Since we had a mixed set of doors, panels, and carpet we had to check the old one for fit then use them as a template for the new ones.
03-04-2019, 10:35 PM | #517 |
Happy to be here
The new panels dont come with the chrome trim. I decided this interior color needed the bling so I collected a good clean set. We transferred them to the new set
03-04-2019, 10:50 PM | #518 |
Happy to be here
If you use a bit of imagination you can start to visualize where this is headed. The door panels will be dyed to match the seat color. I have vinyl that matches the seat inserts that will be used to cover the inserts on the door panels.
Note that the front insert will be cut shorter for the full length Silverado brush trim to fit both doors
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-04-2019 at 10:56 PM. |
03-04-2019, 11:02 PM | #519 |
Happy to be here
While Chris worked on the panels, I continued to push forward with the Vibro Solutions sound deadner install. The back door was a bit more challenging due to the smaller access opening.
I managed to get it wrapped up in between assisting Chris with his project.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-07-2019 at 11:44 AM. |
03-05-2019, 10:55 PM | #520 |
Happy to be here
I had a really long day at work and my allergies are wreaking havoc with the pine pollen in full bloom. Consequently my shop time was a bit limited tonight.
I discovered the the passenger front door had GMs version of sound deadner installed inside it. I'm not sure if it's to prevent rattles or actually to dampen the panel. What I do know is it was not effective, and it was in my way.
03-05-2019, 11:05 PM | #521 |
Reflectix R-3.7 Double Reflective Insulation 2' x 100' at Menards I have used this over top of regular sound deadener (FAT MATT, Dyna, ect) on the outer door skins. AND on the inside cavity of these plastic door panels. It really made a difference. For low-low dollar build we used just the foil wrap & doubled it in places it would fit anywhere in the cab.
03-07-2019, 11:51 AM | #522 | |
Happy to be here
I have used it as you suggested under the door panel. Rather than attach it to the inside of the door panel, I cut a piece to fit the door instead. I attach that piece with duct tape (color coordinated of course) to reduce thermal transfer AND wind noise. The duct tape allows me to remove it if necessary to do any repairs inside the door.
03-09-2019, 11:03 PM | #523 |
Happy to be here
This past week was insanely busy at work. The weather was bad pushing people to find indoor activities. Combine that with Mardi Gras festivals and crawfish season our accounts were extremely busy. Combine that with me fighting a sinus infection and I didn't get a lot done in the shop.
Instead, I was productive by ordering parts. I played the price match game with Summit Racing. They have gotten much stricter on matching but I still got some great deals.
03-09-2019, 11:15 PM | #524 |
Happy to be here
To take advantage of the free shipping and compound my savings I made orders that were right above 100.00 each time.
I wanted all new inside door handles, and window motors. Once the inner and outer door parts go together I dont want reliability issues. I bought Dorman door handles and A/C Delco window motors based on feedback from reviews and experienced restoration shops.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-10-2019 at 10:53 AM. |
03-09-2019, 11:23 PM | #525 |
Happy to be here
This morning I finally got some shop time Chris and I ran a few errands and went to my buddy Berdos shop. Hes one of my C10 Club friends and a Squarebody parts scrounge.
I had sourced the rear power doors from home along with door panels and several other parts early on in my build. He recently picked up a Suburban that had a pristine power door harness that was perfect for my needs. He had an extra rear door panel to replace one I had cracked while trying to remove it. I also grabbed a headlight dinger module to replace mine that had died. I loaded
