08-01-2021, 09:01 PM | #501 |
Post Whore
Re: Facebook Marketplace finds
08-01-2021, 10:07 PM | #502 |
Going to look at these two tomorrow the GMC first. If I pass I'll post the listing .
I really think I'm going to buy the 69 GMC. 283 4x4 SWB hasn't run in 12 years but not all rusted out . The 68 is nice too but not really needing another LWB . God I hope I dont buy both
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 08-01-2021 at 10:24 PM. |
08-01-2021, 10:22 PM | #503 |
https://www.facebook.com/marketplace...4-4a04dd55be5a
1972 Chevrolet chev $5,000 Vehicles Listed 3 days ago in Bangs, TX About This Vehicle Driven 100,000 miles Automatic transmission Exterior color: Yellow · Interior color: Yellow Fuel type: Gasoline This vehicle is paid off Clean title This vehicle has no significant damage or problems. Seller's Description $5,000/Trade/ Best Offer - -Barn fresh, doesn’t run at this time, would make a good builder truck. Serious inquiries only. Call Leonard at [hidden information]
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
08-01-2021, 10:34 PM | #504 |
Post Whore
08-01-2021, 10:35 PM | #505 |
Post Whore
08-01-2021, 10:38 PM | #506 |
Post Whore
08-01-2021, 10:40 PM | #507 |
Post Whore
08-01-2021, 10:41 PM | #508 |
Post Whore
08-01-2021, 10:46 PM | #509 |
Post Whore
1970 Chevy C-10, 350 V8 very desirable double hump heads, Turbo 400, Mosier rear. Truck is primed and rust free, needs TLC, heavy work complete.
Transmission is from a newer vehicle it's a turbo 400/375. I changed the oil and filter in it put a better pan on it. No debris in the oil.I installed new pushrods and steel roller rockers in it. The truck has a new battery, starter, alternator, p/s pump, p/s lines, all pulleys, electric fan, B&M tranny kickdown, shift linkage, vent windows, door seals, windshield, rear end cover and fluid, wiper arms & blades, (blades need replacing again), plugs and wires, air cleaner, heater hoses, SS tailgate chains, new tailgate, signals tail lights, headlights, dome light all new. Fuel tank sender new. Sherman, CT . https://www.facebook.com/marketplace...a-1d4c945dcbb6 |
08-01-2021, 10:49 PM | #510 |
Post Whore
1986 Chevy C10 2 wheels drive short bed. Originally a southern Georgia truck so it’s not a rust bucket. Very nice condition. https://www.facebook.com/marketplace...a-1d4c945dcbb6
08-01-2021, 10:52 PM | #511 |
Post Whore
08-01-2021, 10:56 PM | #512 |
Post Whore
I’m Selling my 1968 C10. Short box truck to explore other options -
Big block 396 - 12 bolt posi rear - Brand new FTI 700R4 transmission with over drive from Summit - New big block coil springs in front - New high torque starter - New steering box - New upper and lower ball joints - Up dated disc brakes in front - Everything works as it should. lights, wipers, original gages, everything! NO RUST Great driver! Runs great starts right up. Sounds good to. Nice little truck. $23,500. https://www.facebook.com/marketplace...a-1d4c945dcbb6 |
08-01-2021, 11:00 PM | #513 |
Post Whore
08-01-2021, 11:02 PM | #514 |
Post Whore
1979 gmc jimmy k5 blazer for sale.
4in lift 35” Mickey Thompsons 350 4 speed manual Bought this to make it a fun toy but when I went to redo the interior I saw that the front floors should be redone or addressed at least and that’s more of a project than I have time for. Would be a great start for a restoration. Needs some brake work. everything bled fine so I’m guessing it needs a master cylinder. Engine seems to run strong just did an oil change plugs and wires. Have not driven it much because of the brakes. The rear window and tail gate are in great shape and work as it should. Frame is in excellent condition. Floors are ugly but rest of the truck is surprisingly clean. Comes with clean title. Asking 7500 obo. https://www.facebook.com/marketplace...5-29b28d1b0606 |
08-01-2021, 11:07 PM | #515 |
Post Whore
08-01-2021, 11:10 PM | #516 |
Post Whore
GMC Long Horn, 8.5’ bed, big block 402, 4-speed manual transmission, 2WD.
New complete brakes all the way around, all new brake lines, new fuel lines, original rebuilt carburetor, new fuel tank, new wires/plugs, new HEI Mallory distributor, new tires rims lugs, frame was sand blasted and painted. Comes with replacement cab corners, rockers and bed kit 1971 GMC 1 ton Long Horn $7,900 https://www.facebook.com/marketplace...7-f5a73e66ec2b |
08-01-2021, 11:40 PM | #517 |
Post Whore
Updated, 1969 GMC custom long bed step side with spare tire fender. New long block straight 6 engine installed 8 years ago however truck was never driven much after install. Belonged to my grandfather then my father now I am the 3 owner and having to sell . I have installed the following. Master cylinder, dual core aluminum radiator, alternator, carburetor , heater core, heater hoses, points, plugs, wires, coil, fuel filter, oil filter, oil, tires and front shocks. Greased ball joints and front end , inspected drum brakes and repacked front bearings. Repaired modulator valve on transmission ,new gas tank /sending unit,new door mirrors and 4 antique hub caps. Lights work brake lights work . Turn key driver.
Great patina!!! This truck was used in the dairy business in the early 70's Then hauled firewood and lumber building houses in the 80's. Original engine slung a rod in 2002 then parked until engine was replaced 292 ci . Bill of sale only . Thanks for looking! https://www.facebook.com/marketplace...d-5e23e6e6c3e9 |
08-01-2021, 11:43 PM | #518 |
Post Whore
08-01-2021, 11:47 PM | #519 |
Post Whore
https://www.facebook.com/marketplace...d-5e23e6e6c3e9. 1968 GMC C/20 64k miles, rebuilt 350, 4 sod manual trans. Longbed, lowered two inches new exhaust nice patina, typical rust in cab corners, runs nice. $8200.00
08-02-2021, 01:42 AM | #520 |
What's up with all of the square-body and non 1967-1972 Chevy and GMC's postings?
I thought this was the 1967-1972 part of the forum? |
08-02-2021, 08:26 AM | #521 |
Neat seat in that black stepper
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
08-02-2021, 09:38 AM | #522 |
I remember it too. Somebody unloaded the JC Whitney catalog on it.
Dave R. 1972 K20 1972 C20 Highlander 1957 Chevy 210 Delray 1967 C10 |
08-02-2021, 05:03 PM | #523 |
Post Whore
08-02-2021, 06:39 PM | #524 |
Ha, well said Dave, I hate when guys do that.
08-03-2021, 12:21 AM | #525 |
Post Whore
1972 Chevrolet C-10 pickup
-350 CI engine -Factory power steering -Factory air conditioning -Highlander Package -Rebuilt transmission 2019 -Great daily driver https://www.facebook.com/marketplace...Anull%7D%22%7D |
